A while back I seem to recall seeing a project in a woodworking magazine on making a turned salt box with a lid that pivots on a pin. I have looked through most of my magazines and can't find it. Can anybody point me in the right direction ? I saw a demo at Totally Turning today on something similar and it triggered something in my aging memory.
I can't remember where I saw that, but if I find it I will let you know.
I have built a few salt wells which I think are similar to the one in the article. Here is a picture of one of them.
The only thing tricky about it is getting the holes for the dowel and the magnets lined up perfectly. I even came up with what I thought was a neat trick; place two bb's or buckshot on top of the base where the holes should be then carefully line up the lid and press it down. It makes an indentation at all four places. I still never got one lined up perfectly.
Whenever you want multiple holes (or hinge mortises or dowel joints or other drilling or machining operations) to all line up perfectly, the trick is to use a jig that registers positively on both mating parts, with bushings or accurately drilled (i.e., dead perpendicular) holes in the rim to guide the drill bit. In the case of a box like this, the jig might be a disk of dense, stable wood about an inch thick, with spigots on both sides to fit recesses or openings in the mating parts.
The important concepts are to not allow any drill runout and to have all the operations reference off the same jig.
I cannot determine the dimensions of the box, particularly its height so the suggestion I am going to make might not be appropriate.
I used to make a lot of swivel lid boxes and to ensure hole alignment I drilled the holes for both the top and the bottom at the same time by drilling through the bottom up into the top to a prescribed depth. I drilled one hole large enough to accommodate the head of a stainless steel nail then used a smaller bit the same size as the nail shank to finish the hole. The nail was inserted from the bottom into the lid where it was epoxied into place. A plug cut from the same wood covered the hole in the bottom.
If that idea doesn't work for you I would go with the jig and use brad point bits. Below are examples of swivel lid boxes I used to make. Not turning so forgive me...
