Cocobolo box...
Cocobolo box...
Mike Stafford
Cocobolo box...
Mike Stafford
Here is a cocobolo box 2 1/2" tall and 3 1/2" in diameter that I completed Sunday afternoon.
I thought it would be appropriate to post it since we had the discussion about sanding with wax. I always sand cocobolo, tulipwood, kingwood, and most other dense exotics with wax to prevent heat checks. In this instance I sanded through 400 with Klingspor Gold and then switched to some wet/dry paper and sanded until 1200 using wax with each grit and cleaning between grits with odorless mineral spirits. I let this box and some others dry for a day or two before putting on the final wax finish which was applied with coarse cheese cloth and steel wool which totally randomizes the scratch pattern. Once the wax is dry I buff it with soft cloth followed by some soft felt.
Then a top coat of microcrystalline wax is applied to reduce fingerprints. My experience has shown me that boxes such as this are fondled frequently....
The exceptionally straight grain of this stick of wood created an almost perfect grain alignment at the join.
All comments appreciated....
Re: Cocobolo box...
Don Pencil
ABSOLUTELY BEAUTIFU!!!
Don Pencil
Re: Cocobolo box...
Re: Cocobolo box...
Greg Haugen
I'd sure be fondling that box. :D That's a beauty!! Simply Stunning!
Re: Cocobolo box...
Don Pencil
Re: Cocobolo box...
Don Pencil
Yes, fondling can be good on a beautiful thing but it must be done gently. One certainly does not want to leave finger prints behind after fondling. This finish will certainly aid in that.
Don Pencil
WWW.DONPENCIL.COM
Re: Cocobolo box...
Re: Fondle, fondle.....wow!
JamieDonaldson
Re: Cocobolo box...
Re: Cocobolo box...
fgvanatta
Very nice box. Don't ofter see grain that straight in Cocobolo - but then, I usually look for twisted grain.
Frank
Re: Cocobolo box...
Re: Cocobolo box...
Greg in Oshkosh
I have had problems with fingerprints on many wax finishes, especially with carnuba applied with the beal buffing system. Your comment indicates that you have found that microcrystilline waxes do not show finger prints or that a particular microcrystilline wax that you use does not show fingerprints?? What type of wax do you use for the sanding and what wax inparticular do you use for the final finish??
Re: Cocobolo box...
Mike Stafford
Re: Cocobolo box...
Mike Stafford
I use the most expensive wax that my local hardware store sells for sanding - Johnson's Paste Wax. :D
The truth is there is almost no wax on the wood after all the polishing steps and the microcrystalline wax is the top coat. I don't think you need much of anything for a finish for cocobolo except a little wax on a finely sanded surface.
I use Renaissance wax as the top coat and apply it with cheesecloth, allow to dry, and buff with soft cloth and soft felt.
Thank you all for your comments. My wife appreciates the kind words you are saying about the newest addition to her box collection.... :b
Re: Cocobolo box...
Re: Cocobolo box...
Carol Reed
Lovely, Mike.
Practicing for June?
Just a note: You are raising my expectations! :D
Re: Cocobolo box...
Mike Stafford
By the end of the week....
Mike Stafford
I will expect you to have turned 4 or 5 like this....
Actually I hope we can progress by the end of the week to the point where you will be able to turn this with some practice.
Re: Cocobolo box...
Thanks Mike
Galen Vetterick
Thanks Mike for repeating your finishing method for your boxes.
This time I cut and pasted your info into a more permanent record I can go back too!
Nice to see another great example to go alone with it!
Does this pic get added to your web site as a Gallery 5 addition? Your format is great to be able to enlarge the pictures to see each in greater detail.
Galen
Re: Cocobolo box...
Re: By the end of the week....
Carol Reed
Ahhh... you tell all the pretty girls that!
By the end of the week, I expect to be in the adult beverages! At the rib place. With a half dozen successful boxes in my suitcase. At least one with a finial. And one on a perky little pedestal. With the soft fit. Means the lid comes off when lifted by the lid, but the lid nests beautifully in its spot, not rattling around looking for a home.
Working on my sharpening skills. I plan to be READY!
BTW, I love the way you find the beauty in wood, and make a box out of it. Lovely finish as well. Do we get to do that too?
Re: Cocobolo box...
Mike can teach boxes ...
Ed Moore in SW VA
and he was a big help at JCCFS when I was teaching Ornaments and Boxes in 2008. He is with Ward, who arrived late and needed lots of attention. Frank Penta and Jamie Donaldson helped him and then Mike took over for awhile. I recall that Ward and Mike both enjoyed their time together.
Those of you in Mike's class in June are in for a real treat.
Re: Cocobolo box...
Re: Cocobolo box...
Philip Duffy
Amazing! BZ Phil
Re: Cocobolo box...
Re: Cocobolo box...
david
My favorite Mike Stafford shape...what's not to like?
