Instant Rust Help Please
Peter Hyde
Turning lots of wet wood on my Mustard Monster and I'm freaking out about the rust on the lathe ways. Yes I wax them but the
rust appears instantly the water hits. So I was looking for solutions and came up with BoeShield or TopCote and was
wondering which one is better suited.
TIA
Re: Instant Rust Help Please
I'm not a WD-40 fan because I think it's been used for many things it wasn't designed for but for turning green wood on a lathe it is the cats meow. Spray it before, during and after turning if necessary. I just roughed some oak bowls and my powermatic bed would start to rust before you even get the wood on the lathe.
Don Geiger
Don Geiger
An occasional application of Ballistol works well for me. It is a mineral based oil and bonds with moisture- preventing the moistire from causing rust. It is bio-degradeable.
You should be able to get it from a local gun dealer. If you can't: let me know, I stock it.
Don Geiger
Geiger's Solutions
Just wondering if ...
Charles Yawn
I have not tried either, but would a covering like wax paper, plastic or an oiled cloth draped over the lathe ways work?
Texian
Like John, a generous coat of WD-40 and plastic over that. The plastic is a bit inconvenient but beats a rusty bed.
Jorge Casta�eda
I am going though the same,
Spray DW40 before you start, and as the shavings build up, get ride of them, I have a brush and every time i stop the lathe get rid of the shavings, at the end of the session, a last clean up, if needed a light rubbing with steel wool 0000 and wd40 until everything is clean, then dry with a clean rag and rub with Renaissance wax, this works for me a lot better than Boshield or Top Cote, and I live in an Island in the Atlantic ocean, so the salt air is wicked. If it is really bad, I cover the ways with a cardboard or polyethylene or a board. Like when turning green oak, or even green cherry. This wax will take several days to rub off, then repeat, but the DW40 every time.
Re: Remove the Plug,
Dave (PacNW)
and attach it to a new Oneway 2436 with Stainless steel ways-- works every time! ;-))
or a Robust
Steve Kubien
That's playing dirty....
Steve Kubien
...Peter just got his 3520B and now you're telling him he needs to go shopping again? That's hitting below the belt. FWIW, I like those tactics!
Steve you should be buying Canadian
Peter Hyde
Well I picked up some TopCote and followed the instructions. I will see if it works and get back. I have a gallon of WD40 kicking around here somewhere's but I'm pretty sure the formulation is different up here in the Great Green North.
As for the the other suggestion about a No-way. well first off it's not cast iron, Then it's not the right colour and thirdly it needs an awful lot more of the colour green to bring it home :) So 3 strikes and your out right?. Plus it doesn't have a sliding headstock so now it's really out :)
I do have No-way chucks and also painted a No-way banjo the right colour so I'm still waving the Maple Leaf. :)
Dick Hines
Dick Hines
Peter, every day I spray a light coat of WD40 on the bed before I start to turn. If I do a lot of wet wood I still get rust. To get the rust off i will spread a light coat to 3in1 oil on the bed and use 320 wet-dry sandpaper and give the bed a light sanding.
Steve Kubien
Re: Steve you should be buying Canadian
Steve Kubien
I just wish I was buying something as an upgrade right now.
WD-40:  Water Displacement formula #40
Pete in Holland, MI
Seriously !
This is what WD-40 was designed to do.
A better option
Russ Fairfield
Dick,
Contrary to popular belief and advertising, WD-40 will cause rust in high humidity and the presence of water. I lived in FL long enough to learn that. Try using the 3-in-1 by itself.
Liquid Wrench is an excellent product for lubricating the ways of the lathe and preventing rust. It is also an excellent lubricant for chucks and any power tools with moving parts or screws that have to work while buried under shavings and dust.
Peter Hyde
Just an update :) After a few days of turning really wet green elm and maple no rust. The Topcote
is working fine. Applied as per instructions and not even a black stain and no finish sticks to it
either. I usually re-wax at least once a week but it's now well over a week and still going strong. No
problems with tailstock or banjo slipping either, but I think that has more to do with the MM
design.
