My first stab at piercing
Mike Foster
Pun intended. I finished this first try at piercing, finally. Did a lot of experimenting with it. Added a little texture and really experimented a lot with airbrushing guided by Bin Pho's DVD. I used a lot of masking to keep colors clean. I think the piece is overdone in aqua (titled it aquawave) but chalked it up to a learning experience. The piece was originally about 2 " taller, but a little inattention while the piece was spinning (and I was not turning) led to the loss of some height. I thought it looked good enough to practice with so went ahead and finished the piece. I also turned this from half a log, and as it dried the piece distorted rather unattractively but that is hard to see in the photo. I'm not sure where this will lead, but it is fun and I'm sure I'll try some more sometime. C and C welcome. Maple, 5.5"h x 6.5"d
Re: My first stab at piercing
Bill Youngblood
I think it's GREAT!!! The design seems to be consistant in the sizes of both the positive and negative spaces. Nice use of the color also. Good work. I also have been dabbling with piercing and am loving it. Good Luck.
I love the little feet. I know, you spent most of your time on the piercing. It's the little extras that make these pieces nice. You did a great job on the piercing. As was mentioned above. The negative spaces are as important if not more so than the wood that's left. Good job.
Cyril Griesbach
I can't expand on what's already been said other than to repeat that you've done a wonderful job on it and if this is a practice/experiment I can't wait to see more.
Well done.
Fantastic. I love the color gradients and contrasts.
Steven Antonucci
Did you make your wife sand it?  :-)
Steven Antonucci
Pretty nice bit of practice. Are you bringing it to Saratoga Springs?
s
Randy Gleckler
Very nice job.
That'll do nicely Mike !
Don Orr
Wonderful piece all around. I especially like the non-random pattern of the negative space. So many piercers do the same random piercing it's nice to see a different take. Your pattern must be more trouble to lay out but it shows attention to detail which you excell at.
I like the colors very much. How do you keep the paint used on the outside off the inside ? Is it masked off ?
Strong work-well done !
Wow! Simply stunning...Nicely Done
Greg Haugen
Steve Kubien
Steve Kubien
Holy cr*p! Very nice indeed!
fgvanatta
Beautiful piece, well executed.
Frank
Re: Did you make your wife sand it?  :-)
Mike Foster
Hi Steve,
No Susan wouldn't have the patience to do anything like sand it and I couldn't convince her to do it with a 2x4. Yes I do plan on bringing it to Saratoga. Will look forward to seeing you there.
Mike
Re: That'll do nicely Mike !
Mike Foster
Hi Don,
Yes a lot of masking on this piece. Inside, outside, outside, outside. Masking the piece actually took a lot longer than painting it. I am still in the beginning learning curve with the airbrush, and gained a lot of insight by viewing Bin Pho's DVD on the subject. Hope to see you in Saratoga.
Mike
thanks
Mike Foster
Thanks for the encouragement all, but you were supposed to critique it. This is a learning experience for me.
Mike
Re: thanks
Don at Central Illinois
If you want a critique, it won't hold soup! Other than that, I don't even aspire to that kind of turning, yet, so I can't really critique it for you. I do think it is well done and very nice.
Brian George
To me - That is an excellent example of the craft of turning being enhanced. In my humble opinion, too many times something somehow qualifies as a turning when a very minor part of the entire process is turned. Not that the finished piece is not artistic but, just doesn't qulify as a turning entry. Congratulations on a beautiful piece!!!
