Turning pictures.
Turning pictures.
Dick Hines
Turning pictures.
Dick Hines
Ok, all you computer geeks. I have a question for you. I got one of those digital pictures frames for Christmas. I want to use it at some of my shows to show the making of a bowl from log to finish. The question is can I put the pictures I have on my computer back onto the chip that was in the camera?
Re: Turning pictures.
Rob Wallace
Rob Wallace
Dick -
Will your digital picture frame allow you to use a USB drive? I just got one of those picture frames for my parents for this past Christmas, and we used an inexpensive jump drive to move images around - really easy.
Does it require a smaller drive like a compact flash or the like? You can move images onto these, but I wonder if it is really necessary...
Rob
Steven Antonucci
Yes
Steven Antonucci
The hard part would be explaining it to you. The camera is essentially a flash card holder that acts like Storage. If you connect it to your PC, you can move files in either direction.
It's a drag and drop operation on mine. not sure how your camera is viewed by your PC...
S
Galen Vetterick
Dick
The Sony frame we have will allow you to download direct from a computer to the frame with a USB to USB-B cable. The cable was not included but still was easier to load and remove from the frame. Other method was by camera card and that was of little value for pictures downloaded in the past.
Frame now sits with no attention. It was surprising you can turn the frame up on end and the pictures would automatically switch to the new orientation.
Galen
Fred Holder
Hello Dick,
I have a SanDisk MicroMate that accepts a camera card on one end and has a USB connection on the other end. Slip the camera card into the piece and plug it into a usb port on your computer and the camera card becomes like an external hard drive. This is how I transfer data from my main computer to my little note book computer. It will work fine for your viewer.
Dick Hines
Dick Hines
The frame i have is a Dynex. It does have a USB port along with the slot for the camera chip. I will try some of your ideas. Thanks
Maybe
The Canon cameras we have do not allow connecting as a drive for copy in either direction.
The card could be placed into a reader on the computer itself or a reader that plugs into the computer. Be aware that transferring some photos to some camera cards MAY result in photos that cannot be viewed by the camera itself. This should not matter for the photo frame.
If the reason to put the photos on the camera card is simply a means to transfer to the photo frame, I think I'd go to Walmart and buy another card, or better, as someone mentioned, a USB pen drive. At least some of the photo frames will also connect directly to the computer for photo transfer.
BTW, I like to batch process the photos to the native resolution and aspect of the photo frame. This will save memory and speed display over using huge unedited photo files.
Brian George
You just gave me an idea! I have an older Toshiba laptop with Win98 on it.
I bet I can load up some pictures from the studio and, using power point, have the same thing but, with a larger screen. An AHA! moment.Why not?
Dick Hines
Re: Maybe
Dick Hines
I have a card that will hold 40 or so pictures. What I want to do is take the pictures, upload them into the computer, photo shop them and then down load them into the chip. The put the chip in the frame.
Upload,download,chip,computer, photo shop! Does all this tech speak make me a computer geek? I don't think so. Computers are why I retired. Couldn't even find a good telephone switch that was not a computer..
Re: Maybe
Ha! Since I retired I haven't even cleared off the desk in front of my bank of computers and video/audio gear. Working with computers and electronics filled most of my days for way too many years. These days I'd rather feed the goats and drive the tractor. :)
What you want to do should work fine. Once you put the chip into the frame do you want to leave it there (and display the pictures directly from the chip) or use the functions of the frame to copy the photos from the chip to the frame? If you want to display them from the chip itself, you could get another chip for less than $10 to keep so you could continue to use the first one with the camera.
If you are editing and your connection method allows it, if you reduce the pixel dimensions of each photo to match the photo frame, instead of 40 photos you might be able to fit 400 photos on the chip. Some photo frames are 800x600. Making the pictures smaller could speed load time as well. If you use the full-size photos and the transitions between the pictures are not smooth, you might try this.
What I would do....
Print out about 8 or 10 on nice stiff paper and cut them to exactly fit in the front of the Dinex frame and stick one to it. Then when no one was looking, I would swap it for another every once in a while. No batteries required. Low Tech. You can thank me at the next club meeting.
Dick Hines
Re: What I would do....
Dick Hines
Barry, that's the best ide I have heard so far.
Beware of "Digital Picture Frames"
charlie belden
Don't know if it's still a problem but some of the "digital picture frames" had a Trojan Horse in their software which would be downloaded and executed on any computer they were attached to. Unless you have fairly decent, up to date Anti-Virus software installed and running I'd pass on them.
Dick Hines
Re: Maybe
Dick Hines
I have already gotten another chip. I picked it up at Radio Shack. A 2 gb for $13. The one I ordered with my camera is 256 mb and I think I paid at least 3 time that. I have had the camera for a couple of years. I want to use the 256mb in the frame.
Memory is getting cheaper all the time.
Hey Ellis/moderator.....
Charlie's post above is doing the magic disappearing act like the one the other day. At least, it did for me, twice. Sends you back to the top.
cheap memory
You got that right! I once paid $350 for a 45 meg compact flash card. I hate being on the cutting edge.
Back in the '70s when you had to build your own computer if you wanted one, every kind of memory and storage was high. I had a 10 MEG hard disk drive: $1000. A dual floppy disk drive: $2300. Each 8 K (not meg, not gig) memory board for my computer was $250 and had to be assembled from a kit - 1434 solder connections. It's a welcome surprise to see the prices still dropping. Volume, volume.
Re: Hey Ellis/moderator.....
Barry, I sent Ellis a note about that earlier. He thinks he has it figured out. Weird software bug.
