For Steve - Coring
Carole Valentine
Steve, I am certainly not a master of coring - I still have a long ways to go - but I will try to explain what I was saying in the other thread. I may be right or I may be wrong...I am just saying what works for me. We are talking about fractions here, but in my limited experience, fractions count in coring. Couple of other things I have learned: Don't start learning with crumby, stringy, knotty, wild-grained wood. Resist the temptation to "pull" the handle towards you to force the blade around the curve...it will follow the curve set at entry on it's own. A little fish-tailing to widen the kerf is OK and I have found it to be desirable. Provide plenty of clearance for shavings - especially important on the tight radius blades. If the shavings stop coming out, stop and clear them. If you don't they will jam up everything and you get the big catch that causes our DVRs to halt.
If you get a big catch, clean everything out, go back into the kerf and take very light cuts until you get past the gouged out area where the catch occurred - otherwise you will just dig into the same divot all over again. Let the blade do it's work, but don't let it run away with you. There are some areas where you might have to hold it back a bit and others where you may have to push it more.
Now for what you asked me to photograph - I couldn't take a pic so I sketched it as best I could. In the lower diagram (slightly exaggerated for clarity) the view is from the back of the blade towards the workpiece. It shows what I suspect happens when you start a cut with the turret very close to the wood and the narrow part of the blade between the columns instead of the wider part. Once you get into the cut a ways, you can move the turret very close to the workpiece. This is about the sum of my coring knowledge, but maybe it will help a bit. I highly recommend both Mahoney's Second Edition video and and Reed Gray's video. I probably would not be be coring if I hadn't watched them.
