THE WOODRAT IS BACK!
Waste Block vs Glue Block?? (vote)
Doc Green
As you understand and use these terms, are the two the same thing or do they differ in some manner? Select a response. Thanks in advance. ~Doc
A. They are the same thing.
B. A waste block is typically rather small (2-3" dia) and used with a chuck.
C. A glue block is typically larger than a waste block and is usually mounted on a a faceplate.
D, Some other difference . . . please explain.
Re: Waste Block vs Glue Block?? (vote)
Carol Reed
A
Doc Green
Thanks, Carol. Gee, you're quick! ~Doc
Wally Dickerman in Arizona
A
Wally
Don Central Illinois
A
Lan Brady
I vote D.
I make threaded blocks to fit the spindle. Some I have used 50 times.
When i part them off, I will usually leave a thin layer of wood. Flattten the block and it is ready for the next project.
Lan
Cyril Griesbach
A.
However, I also do something similar to what Lan describes using a threaded glue/waste block.
Steve Kubien
I'm with Lan and Cyril
Steve Kubien
Texian
A
Gee....
Dave Belser
Now you have me obsessing about what to call that little bit that I glue on the other end when I'm trying to super accurately line up the piece or prevent the tailstock from messing up an assembly :)
Accurate terms do matter but in this case I don't see it as leading to any confusion. Why are you asking?
Ed Moore in SW VA
A
Don Evans
Answer is D
If you part off the item from this block and cut into the block it is a waste block.
If you part it off and don't cut the block it is a glue block if you glued the turned piece to it.
Also if you worry about such things instead of designing your next turning you need another hobby? :b :D
They are all waste blocks. Sooner or later you have to replace them. I glue square blocks to my hand mirrors with CA and Accelorator. It usually breaks at the glue joint when I remove it with a sharp blow. When you clean off the glue you end up removing just a tiny bit of wood. Eventually the wood gets so short you have to replace it.
The same is true with the mandrels I use for some projects. They are tapered and eventually get to where they won't hold the wood so I turn the taper down a little. Just like above, eventually you have to replace them.
I do of course have true waste blocks that are designed for a one time use to solve a problem.
Hijack - type of wood?
Any favorites on the type of wood? I usually use eastern cedar since I have a lot but have used various pines and oak. Oak seems too hard, especially if parting off, but the chuck jaws don't compress it as much as cedar if I want to rechuck.
Re: Hijack - type of wood?
Paul Zerjay
I use a wasteblock for more of a jam chuck than anything else. I want something thats a little bit less dense than the specie I am jam chucking, but not too soft either. A blackwood finial for example fits a lot better in a chuck made from pear, than one made from pine. Hard maple, Pear, and Red Oak seem to work well for me. Although sometimes Oak will splinter a little when cutting a recess for your tenon.
Steven Antonucci
Another vote for A
Steven Antonucci
And in my shop, I think I'd call them Epoxy blocks, since I usually use 2 part epoxy instead of glue or CA. Does my vote still count?
S
Emmett Manley, Lakeland, TN
D. A waste block could be an extra long blank thus assuring that you will have plenty of waste wood. And, a glue block might become -- intentionally, or by design opportunity-- a two wood piece. What's a faceplate? :D
But, usually, I would agree with A.
Allen Neighbors
A.
Regardless of how you use it, it's still a waste wood block... glued or threaded or mounted in a chuck.
Is this important? :D :\ ;)
Brad Vietje
A
Brad Vietje
A
Don Orr
But I don't usually use either.
Lyle Jamieson
My Definition
Lyle Jamieson
In my definition...none of the above. It would be a miracle if we all agreed here, and/or agreed about many aspects of turning. But it is awfully confusing when a beginner reads or hears the same thing called different names. It's hard enough to get started and confusing terms make it frustrating. Out of the 18 posts so far I only agree with Emmett. I think this is an important designation. In my shop and my process, a glue block is usually screwed to my faceplate and the glue block then CA glued to my bowl blank. I then create a waste block, (waste area) on the glue side of my bowl blank. The waste block is then defined as being the part of my bowl that I will turn away after I reverse it to finish the bottom of the bowl. The waste block gives me some fudge factor for my bottoms. I want to stay in control of the outside shape of my bowl and not let the chucking method influence the shape of the side-to-bottom transition or influence the scale or height of my foot.
What to use as a glue block?? I like to use hard maple. Tight grained wood works better then course grained wood like, oak or ash. Hard wood works better then soft wood, pine-poplar. I re-use the glue blocks many many times. When I get done with one bowl I just clean up the glue surface and I can get 25-30 bowls from one glue block before I hit the screws and have to replace it with a new glue block. And even then I don't replace the whole thing, but glue a 3/4" thick block on the old one and keep on turning. There are glue blocks in my shop that have been on my faceplates for 12-15 years and have done hundreds of bowls. I don't use chucks but for people that want to use chucks then the glue block must have another name. Call it a chuck block, chucking block??? or whatever you want to call it. I use a chuck block sometimes to reverse my hollow forms using the tailstock and driving with friction to sand and finish the bottoms of hollow forms.
Coyne
I vote for A, though sometimes my 'wasteblock' started out to be a beautiful piece of art to be preserved for the ages. ;)
I don't think it is important, but it is interesting, and I am glad someone has introduced a subject in which there is so much agreement and no almost violent, passionate disagreement.
We are a good bunch, and I'm glad to be a part of it (mostly a lurker)
Lyle Jamieson
Re: My Definition
Lyle Jamieson
OOPS, another subject I forgot to mention. I never use a parting tool with waste blocks or glue blocks. Even a sharp parting tool will tear things up and I don't like to have to sand all the damage. Even more important to me is to shape the inside of my foot area and leave some sort of turning evidence. When people look at the bottom of my turnings there is something of interest to see. The straight line of a parting tool shape is not what I want on my bottoms.
The CA glue is brittle and will break easily with the blow of a chisel right on the glue line. If the bowl is thin and fragile and I have not left enough waste block area to hammer on it safely, then, and only then, will I resort to using a parting tool. And when using a parting tool I never part the glue line. I will part the waste block wood or the glue block wood on either side of the glue line. The heated up parting tool on the glue line is NASTY. The smoke from parting glue burns your eyes and is no fun, don't breath that stuff.
There is a large portion of my DVD, "Bowl Basics, The Easy Way" dedicated to this glue up process. I think it is the best way to do bowls. It saves wood and it is the best method to transfer the power and stability of your lathe all the way out to the wood without vibration. The glue block method opens up possibilities where chucks have limitations that get in the way.
Bill Grumbine (Kutztown PA)
A glue block is only a waste block if you cut into it by accident. :D Seriously though - we used to turn tops using a glue block. When the top was finished, a couple of quick passes cleaned up the scrap from the top blank, and if one was careful, he could clean off the CA glue holding the blank and still leave the concentric pencil lines used for centering the next blank.
Bill Turpin in WNC mountains
A/D
We have an Axminster chuck about the same size as a Talon. It came with a set of profiled jaws (that we did not order), that is not in their current catalog. The jaws were made for a famous turner that I do not know the name of. The gripping portion of the jaws are convex quarter circles. Turn a 3/8" cove between centers and you have a waste block, jam chuck, etc that can be inserted/removed many times without losing orientation. We have never pulled a block out of the jaws with a catch! We have accumulated dozens of pieces that always go back to true. Why does nobody in the US stock Axminster stuff?
