There have been many discussions on how to remove the air out of tung oil finishing cans. Lately when I buy Waterlox I divide up the quart container into several mason jars. But that only works for a short period of time because the jars are still to big and I open them often. Well, I just found a better and inexpensive solution. You can now buy sealed Aluminum storage containers in 2.5, 4 & 8 oz. sizes from www.bursforcarving.com. They work great and I have no connection to the website. The carving burs are excellent too.
After my second quart of Waterlox gelled up on me before a third of the can was empty, I posted a call for help on WoodCentral, and Bloxygen was recommended as a potential solution(thanks, guys!). On my third quart can I decanted it equally among my three quart containers, and topped them all off with Bloxygen. I add more air after each use. As I start the new use, it feels like there is sludge in the can, but I shake the container and the Waterlox seems good as new. Haven't checked how the other two containers are doing. The Bloxygen was an additional $10+, but the Waterlox at Woodcraft is nearly $30 a quart. Results not yet conclusive and the jury is still out on this process.
I use baby food jars for Waterlox. If you fill them to the top and put the lids on tight, they'll keep for decades. (I recently opened a jar that my dad put up in 1985 and it was good as new.) If you only have one jar open at a time, your downside is never more than a couple ounces, and, if it does skin over, you can poke through the skin and decant usable product. I even sometimes use the partially gelled stuff as a rub-on finish, just dusting off the congealed solids when done.
I've wondered how finishes would do stored in a heavy plastic bag, such as those used for battery acid or those with a closeable spout. The bag collapses as the liquid is withdrawn so there is no air inside. Anyone try that? Perhaps the spout would gum up.
I have heard it called that the wine in a bag in a box is the very best way to store partially used container of wine. As you stated, there is no air in the bag and the wine retains its character. The box keeps the light off it also. But it was used to package cheaper consumer wine and the snobs laugh at it.
Don't know if the exact same bags and valve would work for WaterLox, but it might be worth a try. The finish might desolve the bag or some of the parts in the valve. I've never had one, is there a filler on those bags?
As long as you could be sure of the compatibility of the finish with the plastic, you could use either valved bags or squeezable containers like shampoo or syrup come in...or even plastic pop-valve or screw-top water bottles. I'm not sure where to find out which plastics have the appropriate solvent-tolerances though...I guess it wouldn't take too much finish to run a home-grown experiment with a candidate plastic bottle.
I also recall reading a note a while back about one woodworker who dropped marbles into his finish bottle to displace the liquid right to the top so there was almost no air left in the container when it was capped.
I use jell varnish to finish some of my small projects. It seemed that no matter what I did the majority of it dried in the can. Squeeze tubes made for campers and hikers to carry peanut butter/jelly/etc. have allowed me to use the varnish down to almost the last drop if I squeeze all of the air out of the tube before recapping. I have not tried these tubes with thinner finishes, but don't see why they should not work.
I've used ketchup and mustard squeeze bottles for Danish Oil or Urethane Oil finishes. I squeeze out the air and replace the little cap, which works well. After a while you have to peel the hardened stuff off, and if you're like me, having a few spare caps is a good idea, too.
This indicates at least some bags are made with metalized film, which might not be affected by those solvents. This is the type of packaging often used for foods such as potato chips - JL is the expert here on this, maybe he would know.
The jelling of Waterlox is why I don't use it. But I did buy a can to try. the way I kept it form jelling was to put it into baby food jars and turn the jar upside down. That way any jelling is on the bottom.
Now all you have to do is find someone with a baby. They will have tons of jars that will just end up in the trash.
By the way I use Watco and put small amounts in a small container with a sealing top.
I started out using marbles, Bob, then tried the IV Bags used for food at the hospital... the tung oil still jelled inside it, but the worst was the valve tube getting plugged up...
So I went back to using marbles. I always have good tung oil now. Instead of marbles, though, I buy those little half spheres-clear ones, at walmart- couple of bags go a long way. They'll wash clean in a little mineral spirits. The sure do make the quart can heavy!
I use shampoo bottles with a flip cap. You can squeese most of the air out and flip the cap closed. BTW Waterlox must have either a drier in it or an oil that reacts more easily than linseed or tung. Seems like it gells more quickly than any other finish.
I've started using a vacuum food sealing device for my finish products. It's a Pump and Seal food saver. It's a hand pump and use it with glass jars and canning lids. I punch a small hole in the canning lid and put a small vinyl tab (resusable many times) with adhesive on the back that comes with the Pump and Seal that allows you to pull the vacuum through and then pull up to release the vacuum. Then just a few strokes of the pump and it's sealed up nice and neat. Pull up the tab, open and use, stick the tab back down and pull the vacuum again and it's ready to go the next time.
I think a kit is about $30. I had one in the kitchen, took it to the shop and had to buy another one for the kitchen.
I did pump too much with the oil too close to the top and the pump sucked the finish up into it. Took it apart, cleaned it and it's as good as new.
Good suggestion, Allen. I have a bunch of those lens-shaped glass thingies at home. Walmart, Michaels or any craft store would have them and I bet they are cheaper than marbles.
I've used several methods with varying success. The marbles work but are a mess to clean up and you still lose some of the finish. I have had 100% success using the boxed wine bags. I have some now in a box (I put the bag back into the original box) that I've had since 05/07. It's as good as new. And you end up using every last drop of the finish, no waste at all! Only problem is the spigot does tend to gum up. I keep spares around and just replace it. The other method that I'm presently trying has proven very successful for a fellow club member. You can buy a kit at the bed/bath stores (and some hardware stores) that has a cork sized to fit a wine or beer bottle. We use the beer bottles. The cork has a valve in the top which you place a hand pump (part of the kit) onto, pump it several times and it removes all of the air in the bottle. So far, it works great. I don't know about long term, you might need to re-pump occasionally if you (like me) seldom use the finish (Waterlox in my case). Sorry this ended up such a long post.
The metalized layers are fairly impermeable to oxygen or moisture. You just have to get a reasonably intact metalization and make sure you don't scratch it. The metalized layer is usually an interior layer. In addition, you have a sealant layer (which hopefully doesn't impart odor or off taste), a tie layer, metalized layer, OPP or PET and sometimes outer layers to add stiffness and to protect the metalized substrate film.
Bag in boxes work because they exclude oxygen from the start. As the wine leaves the bag, the bag collapses and makes sure that there is little or no headspace with oxygen to degrade the wine. It should work for finishes - except that the interior layers may be degraded by the finishing material (oil, varnish or whatever). Like has a tendency to dissolve like. If you used a sealable polypropylene for the interior layer (more appropriately a polypropylene copolymer), you might be able to get away with using it for finishes.
Thinking of metallized film, the rolls I got from you continue to come in handy. I've used it as a weed barrier under the gravel under my beehives and as reflective insulation for outbuildings. Getting ready to use some more tomorrow on another building.
