Gauge-T damage
Keiths tool is pretty tough but a fall from 7 feet was just little too much. I had bowl come apart and the piece flew up and knocked the gauge off it's perch. It hit the floor right on the brass parts. Fortunately it was repairable. The brass tube had a very slight bend and made it bind up when you pushed it in. I pulled it apart and used my arrow straightener ( I knew I kept that thing for something) to straighten it. It had a very slight flat spot that still caused a bind so I chucked it up in the lathe and sanded it until it moved smoothly through the reamed hole in the plastic. It's now working great again.
I guess that's what I get for trying to salvage a bowl that should have been tossed. Another example of staying out of the line of fire saving me.
Hi John, I'm not sure which pin you have; early ones had only black markings, newer ones have red and black. I changed to two colors for the reasons you describe. Would this help? I can send one with the marks you describe if you wish....Keith
