DIY wood burner help, please. *LINK*
Steve Kubien
Steve Kubien
Hey everybody,
So, I want to burn wood and not in a fireplace. Basically, I am a cheap bugger so if I can save a few $$$, I will try. In this case, I'll save around $100 by building my own. I've seen the article on the Priddle Wood Vaporizer (linked below) and that's what I want to follow. So, for all you electrically-inclined types, I would like to know if this charger will fit the bill. Here is the description of the charger I am thinking of buying and using (no love on trying to find a second-hand one and I'm out of patience waiting for one to show up). Does this look about right? My thinking is that if I set it to 2amp, I'll be in business.
-Built-in intelligent microprocessor makes charging faster, easier and safer
-Up to 2 times faster than a conventional charger
-Suitable for all types of 12V lead-acid batteries, including gel cell and AGM
-Twenty minute charge to start and five hour fast charge
-Built-in microprocessor monitors battery status and regulates charge cycle providing a faster, more thorough battery charge
-Select 6A fast charge or 4A medium charge for charging large batteries, or select 2A trickle charge for charging small batteries
-Charger automatically switches from full charge to maintenance mode to maintain batteries during prolonged periods of storage without the risk of overcharging
-LED indicators display charge status and reverse polarity
I hope I can use this one. It's only $50 and I have a lot of the other parts. Thanks for your help!
Re: DIY wood burner help, please. *LINK*
Dennis in Southern Oregon
Steve, based on my experience with a "smart" charger whose specs sounds about like those you cited, I suspect that you will have trouble adapting it to a woodburning application. I believe that you will be better off with a plain dumb charger. Priddle's design uses a light dimmer to control the AC power into the charger and consequently the DC power out. The "smart" chargers have a microprocessor running off the DC output and probably expect to see a constant DC supply voltage. I would expect the microprocessor to quit when you try to reduce the output voltage (and Power). Even if it continued to run I expect that the microprocessor would exert unwanted control of the output current. I have not tried to use mine as a woodburner, but based on my experience with trying to charge batteries with one I would expect it to power down unexpectedly when you turn the heat down to far and to try to maintain a constant charging current when you try to turn the heat up. Let me hasten to admit that although I am an electrical engineer, I have not delved deeply into the guts of these chargers. Dennisjavascript:insertTags(":\\"); :\
Mike Brazeau
I agree with Dennis, Steve. I have one that would work that is getting close to 40 years old, but I still need it for lawn tractor etc. It has only a transformer and a diode rectifier. I also have the plans that were kicking around a few years back using a light dimmer and a transformer from Radio Shack. I built one and it works pretty much the same as GP's. Will certainly heat a coil of Nichrome wire. This Canadian Tire unit looks pretty simple. Create the light dimmer part of the system, pick one up and plug it in and monitor the output voltage as you play with teh dimmer switch.
Canadian Tire Charger
Jerry Klug
I just fired up my new wood vaporizer this afternoon. I used Sears MANUAL battery charger, not the fancy electronic automatic model. I know turners that use a charger from Harbor Freight, too. I too got tired of looking at garage sales and bought mine new for $45. I think the HF unit can be had for the low $30's if you catch a sale.
The only problem I had was trying to use a Radio Shack cord between the unit and my Burnmaster woodburner pen. The line was too light and wasted a lot of wattage heating up the cord. I constructed a cord out of the left over battery terminal hook up cord and it works great now.
I added an on/off sitch to the AC line in ahead of the dimmer switch.
Jennifer Indy.USA
Steve when Graeme was in Indy teaching at Marc Adams last summer the entire class got this charger from NAPA. It was a breeze to make them. Just follow the instruction on that website and you should be good to go. Graeme liked these becasue they are easy to convert and you have everything inside the nice box with a carry handle built in.
I'll try to take a picture tomorrow so you can see how the light dimmer is inserted into the side of it.
Good Luck!
Jen
CLICK HERE TO GO TO NAPA'S WEBSITE
Bob Macgregor
When I went to that site, it showed an automatic unit; does that mean that automatics work for this use? I also noticed the NAPA manual 6amp charger (NBC 85210) ...would six amps be enough?
BOB
Steven Antonucci
6A is plenty
Steven Antonucci
On thinner wire, you can't even carry 4A without melting it.
On thicker wire, I usually run about 8A, but I don't need to. It just recovers heat faster, so there's no waiting in between burns.
Steven Antonucci
I used heavy duty speaker wire
Steven Antonucci
it's flexible, so it doesn't drag, and can carry the load safely.
S
Ed in Leaside
A manual charger landed in the local "treasure chest" (aka dumpster) a couple of years ago. It works and you're welcome to it (I already have a charger but once a pack rat ...).
Steve Kubien
Sounds great Ed!
Steve Kubien
Yessiree I will take you up on that offer. Oooo, I can finally see the shop too! I'll take a look at my schedule and we'll see what next week looks like.
Thanks so much!
Steve
Steve I was going to build a wood vaporizer and simply bought the bottom of the line really inexpensive battery charger from another auto supply house. I thought bottom of the line and cheap would mean no fancy electronics. I could not get it to work as a wood vaporizer but did manage to get it back to battery charger mode so Now I have 2.
I purchased the Napa model but haven't even had time to open it up and see if it will work. With my luck they've changed part # and it won't work.
John, if you want an old manual charger I'll save one for you. I have one that I'm sure I bought before transistors were invented.
Jeff Brockett
Any clue as to the model # of the NAPA manual battery charger?
Tommy Holmes from NW FL
I've been wondering if anyone is going to post that information also. I found another one on Amazon. It's only 6 amp but Steve A. said that would be enough.
http://www.amazon.com/Schumacher-Handheld-Portable-Charger-Manual/dp/B0009IBJBM/ref=sr_1_11?s=automotive&ie=UTF8&qid=1267493596&sr=1-11
Bob Macgregor
Here is the NAPA 6amp unit I asked about:
http://www.napaautoparts.com/Search/Detail.aspx?R=NBC85210_0006389653
It's about the same price as the one at Amazon that Tommy referenced.
The NAPA ten-amp charger is here (for $52):
http://www.napaautoparts.com/Search/Detail.aspx?R=NBC85220_0006389653
BOB
NAPA #85-220 (manual charger)
david
