OT Computer question
Terry Quiram
I have been getting a little window that pops up. It reads "out of memory at line:233348554". Any idea what this means and how do I fix it?
Terry
Re: OT Computer question
Chuck Jones - West TN
Could mean a lot of different things. Try copying and pasting the error message into a Google (or your preferred search engine) and see what you get. Without having done that my first guess is you have a virus, but might be something else depending on how old your system is and what else is going on.
ooops didn't work in this case
I have tried searches on this error message (using several variations) and came up blank. Surprising. Try searching on just Out of Memory and you can get some pretty good general descriptions of what can cause it. But I haven't found anything on that specific line number.
Dinyar Chavda
I assume that this happens when you're running a large number of programs. If so, try the solution suggested at http://support.microsoft.com/kb/126962 and see if the problem goes away.
Also, run task manager, and see what process is taking a large chunk of your memor--if you want to read more about this, send me your e-mail (as I still cannot see e-mail addresses next to names), and I'll send you an article onhow to use it and iother free software.
Thanks Chuck and Dinyar
Terry Quiram
You are asking a question impossible to answer without more information and perhaps even without examining the machine. You didn't even indicate if you are running a Windows computer or a Mac or something else. This is like saying "Doc I have a pain, what should I do?" !!
However, there are some simple things you can do on a Windows computer which can provide information which may help.
Run Windows Task Manager (r-click on the Taskbar at the bottom of the screen and click Task Manager or press ctrl-alt-del and select Task Manager in most operating systems).
Look at the Performance tab. Look at the Total and Available physical memory and the Commit Charge, Total/limit/peak.
Click on the Process tab. Click twice on the Mem Usage heading to sort the processes to show the memory hogs at the top. If you don't see Mem Usage, add it with the View/Select Columns command. Note the largest, especially if one is huge.
Under Applications, see what is running.
Do the things above with the Task Manager at least twice: just after booting, and just after the error message if possible or if not possible just before you suspect you might get the error message. List these things in a message.
Speaking as a longtime software developer, beta tester, and software support person, some advice: When asking about a computer error, you may get more useful information quicker if you give some basic information in your message. The trick is knowing what to list. In addition to the numbers mentioned above, some things that may be useful:
- which operating system you use,
-what program(s) you are running at the time,
- the circumstances around the error message (i.e., is it repeatable - happen under the same circumstances with the same program every time or does it come up seemingly at random),
- if always the same program, what version?
- did the problem start suddenly and if so can you remember making any changes or installing or upgrading any software just before,
- make a careful list of what you did since booting the computer
