Man, did I have fun today...
Steven Antonucci
Steven Antonucci
I started this morning with two must do's and one nice to do...
Must do #1:
I have been working big lately, and I needed to make a steady rest. I have had most of it in my head, and I finally got around to making it today. I made it from skate wheels and leftover shop scraps. I wanted to get to use it, but wouldn't you know it, I came up one lag bolt short of having all of the parts...
Must do #2:
I ran out during the week to buy some chunk anthracite coal. Wife was going out to Wally World and I gave her a $10 budget for a hair dryer to act as a blower for my forge. Wouldn't you know it, but the hose to my shop vac is a perfect fit to both the hair dryer and the blowepipe? Started a fire with some wood cutoffs and then slowly added anthracite...and then started feeding the fire with air from the hair dryer. After a few minute, she comes to life.
I know enough about blacksmithing to fill a thimble. However, I do enjoy swinging a hammer. The lady at the coal store told me that I'd get about 13,500 BTU's out of it, but the blacksmith forums I read put that into more understandable terms- about 3500 degrees! Here a small bit of metal that I was messing around with. (I actually burned the tip off!)
How hot it hot? Well, at that distance, the glove began smoking, and the spring to the visegrip failed (It softened, but I fixed it). Within 20 seconds, I attain welding heat, and the metal sparks like it's the Fourth of July!
The entire setup was about $50 in parts, and works really well. I'll be incorporating some metalwork into future turnings, so who knows what direction I'll be going next?
Fun, fun fun 'til daddy takes my hammer away...
Steve
Re: Man, did I have fun today...
The perfect cure for your "Mid-Winter Funk"
Mike Jones i9n Redding, Ca
Re: Keep the Fire Going
Fred Bearman (Port Huron, Michigan)
..... and Smores for dessert!
Randy Johnson
It�s best to never let steel get to the stage where little sparks are coming off of it. That was okay with wrought iron but even mild steel like 10-18 or 10-20 is better worked just a little colder. Welding heat for most steel is kind of an oily looking yellow.
If you have access to a welder lose the vice grips and weld what you are working on onto a long rod. When I had my blacksmith shop I made several pattern-welded knife blades and found that the rod welded on worked a LOT better than tongs.
It�s too bad you are so far away. I�ve got a couple hundred pounds of good bituminous metallurgical coal that I�ve been trying to give away for years.
I really need to fire up my forge. I need a couple of curved tool rests. I'm sort of collecting projects so I can spend a whole weekend working on them. I kind of have to move everything outside. Glad you got the forge going. I was going to build one and started collecting the parts when a friend had to move and sold me his for $50.
Steven Antonucci
I will be reading a lot more soon
steve antonucci
I knew that I had it hotter than I needed, but I wanted to see if I could get it up to welding heat. I need to get a bunch of things and make some tongs. And get a much bigger anvil. And a stump to put it on. And...
help me, I'm falling...
S
Steven Antonucci
hope you like them well done!
steve antonucci
Re: I will be reading a lot more soon
Randy Johnson
That's what happened to me, the falling part.
It started with the need for a heat source to make a spring for an old shotgun.
I actually had an anvil (180# Peter Wright) before a forge. The first forge, a 400 Champion, was was given to me by a relitive. When I gave it up I had a nice shop with lots of tongs, tools, a permanent cinder block forge, and even a 25# Little Giant.
The 'smithing was mostly part of my passion for muzzleloading and the trappings that went with that hobby. When all my guns walked out the door (along with just about everything else) in 1999 I lost all interest in the smithing as well. Added to that was a conviction that sooner or later I'd come home to an empty building that used to be a blacksmith shop. I sold the whole shebang to a couple of firemen from Indianapolis and used the money to start a woodshop in another location. And now, here I am.
I know that somewhere I have a copy of The Art of Blacksmithing by Alex Bealer (sp?) Email me your snail mail address and I'll send it to you.
Oh, and also......
Randy Johnson
If you don't mind a road trip try to find a way to attend the Southern Ohio Forge and Anvil (S.O.F.A.) gatering near Tipp City, OH. It's in the fall sometime. The information will be on their website.
Arrive early with lots of money and you will go home with everything you could ever want or need for blacksmithing. You will also have the chance to spend the weekend watching some of the most skilled blacksmiths alive demonstrate.
One year the guy camped next to me was from Maine. It's something worth traveling to see.
Wow !
Don Orr
That ought to get you fired up !
Burn baby burn !
I'm so jealous. I've been reading blacksmith books for years but don't have a place to set up a forge yet. I have been collecting wrought iron for . Once I started looking I found old things made of wrought iron around my farm and a bunch in friend's barns (you can tell the type of metal from a grinding spark test). I have several tons of mild steel stock here too so all I need is another shed to work in.
Looks like you made the forge from an old truck brake rotor. Anything tricky about that?
Steven Antonucci
Parts list and procedure...
Steven Antonucci
Depending upon what you have access to, you can build this for next to nothing...
1 brake rotor (I bought the biggest, deepest on I saw)
Plumbing parts underneath to funnel air
a piece of flat stock
Take the flat stock and put a hole in the middle. drill and mount the plumbing fittings with some bolts through the flange. My flat stock was a pulley from the tractor supply store that I cut the belt groove off of, but you basically just need something that you can fit inside the brake rotor. I put two bolts through the rotor into the metal plate too. Gravity probably would have held it just fine.
I lined the bottom with a fire brick that I broke into chunks to keep it from burning through. my blower is a $10 walmart hair dryer. The frame is an old bed frame. When I was done burning yesterday, my sone and I carried it over to the storage spot. Coals were hot, rotor was hot. Nothing else was hot.
If you have everything you need, it's a half day project.
Steve
Planning the V2.0 forge already...
Re: Parts list and procedure...
Great picture, thanks. I have nearly everything on hand, even a large brake rotor from the last time I let the brakes go too long on my diesel truck. I have a welding table on wheels that would be perfect, anvil, hammers. All I need is the space - maybe I'll extend my shed extension plans.
The empty area to the right of your forge looks perfect for a firebrick surface. I have a table like that that someone fastened support down the center to hold two rows of firebricks for welding and cutting.
Chuck Jones - West TN
I wish you'd go away with your darned forge!
I have a forge complete with the hand cranked blower that I picked up for almost nothing at an auction several years ago. I've been trying to ignore it because I don't need another time consuming hobby right now, but reading this is almost motivating me to dig it out.
Ironically I grew up in an old farm house in Kentucky with a coal burning stove, but I haven't a clue where I'd find coal now days... search the internet I guess... or make a road trip back to Kentucky. There's probably some lying around there.
Hope you have fun with your forge.
Re: I wish you'd go away with your darned forge! *LINK*
Randy Johnson
Check out the link.
Click on coal forges, look at the prices, and feel very, very, very, smug about the forge you picked up for next to nothing.
http://www.centaurforge.com/Forges/departments/279/
You might check this link (put in a city near you) or do an internet search. There is coal all around - I have a neighbor who works for a coal company that lets him bring home a pickup truck load when he needs it.
coal suppliers in TN
Steven Antonucci
If you can't stand the heat... :-)
Steven Antonucci
There goes my best excuse...
...to stay out of this forge thing. Martin is the closest one; about 50-60 miles. Lawrenceburg and Collierville aren't bad. I guess Collierville is trying to retain the rights to the town name.
Thanks for the information John.
