Safety demo
Safety demo
Safety demo
>I'm doing a safety demo at our club meeting monday. What would you put in there. I'm going to start off showing how I cut the end off a log and break it to find the depth the cracks go. It's important to start with sound wood.
Then I thought I would go into bandsaw safety showing how to keep your hands out of the line of the blade and how to use wedges to keep the wood from binding the blade. Then discuss how dangerous cutting round stock is and how to use a V jig if you must.
Then go on to mounting wood on the lathe discussing faceplate screws and drilling more holes in the faceplate. Follow that with chuck mounting problems.
Then I'll discuss how tools catch and how to avoid that. I'll also discuss how the shape of a bowl can cause a catch (dog bowl vs smooth flowing curve) I'll try to discuss grain direction the reason tools run on you.
dust collection and eye protection are the main reason for deciding to do this demo but that's a 2 minute lecture and warning at best.
Anything else you would add. I'm going to try to make a handout that can be given to new members as they join. I don't know if I have time to do a good job on the handout by monday so I'll probably re write it a few time. I'll post it when I get it right and then you can all proof read it and offer changes.
Re: Safety demo
Re: Safety demo
AndiWolfe
>Talk about the dangers of various finishes. Chemical solvents can be absorbed through skin and the membranes of the mouth, eyes, nose and lungs. Long term damage with periodic exposure accumulates. I don't think turners think about this all that much.
Re: Safety demo
Re: Safety demo
Carole Valentine
>You might talk about the grinder. I am almost as wary of the grinder as I am the bandsaw!
Re: Safety demo
Steven Antonucci
"You're going to need a bigger boat"
Steven Antonucci
>Cutting with a chainsaw is a topic unto itself. I've seen dozens of "experts" who cut in the middle of the bar instead of up by the head where the anti kickback pawls are...
Line of Fire, Line of Fire, Line of Fire!
Tool grip (over/under)- remember the thread?
Allergic reactions to wood, poison ivy, built up exposure...
Listening to the cut and understanding the feedback the sound gives you.
This is a week long course for college credit if you ask me...
steve
Re: Safety demo
Re: Safety demo
>Some ideas, off the top of my head (yikes, that sounds ominous):
Bandsaw: you could use my bandsaw experience (related to your checked/cracked wood warning) - I was cutting a very reasonably-shaped piece, well supported to the table. Suddenly (it's always "suddenly!")a small piece of the wood itself split off and the larger piece was instantly improperly supported. The blade pulled it downward, slammed it into the table, and destroyed a new blade. Fortunately it did not destroy my fingers.
Safety for all power tools: I like what I read somewhere which applies to pushing wood through a bandsaw, tablesaw, shaper, operating a chainsaw, drill, etc - always imagine what would happen to your hands (or other body part) if the wood were to suddenly disappear. (where things would go given the position and pressure at any time relative to the cutting edges.) Years ago I drilled a small hole through my fingernail when the wood I was holding suddenly split - stupid)
Important for any power tool use from chainsaw to lathe: good stance, footing, balance, floor free of clutter, lack of distraction, minimize chance of surprise from another person, animal, etc., mood, sobriety
Drilling on lathe or drillpress and holding the work in the hand - ack.
General chainsaw safety, the most dangerous tool a woodturner might use. Advise to actually READ the safety and operation stuff that comes with the saw. Don't be too proud to get training. Don't try to stop a moving chain with the hand or thigh. (I actually read that in a manual) Stop saw before sharpening (read that in Stihl manual)
Show examples of personal dust protection in order of usefulness, my list: ill-fitting paper mask, better fitting paper or cloth mask, powered helmet (nice but relatively poor filtration), industrial respirator.
Hearing protection, often overlooked. Chainsaws, air compressers, air tools, saws, even the lathe at times can be very loud. Speak nearly inaudibly (or very loud) when introducing this!
Grinding without eye protection, bad. (Not often done by woodturners, but power wire brushing without eye protection is unexcusable.)
Fumes from CA glue, finishes. Absorbing dangerous chemicals through the skin.
Fire safety - oily rags and paper towels, chemical reactions (I've seen paper towel smoke after soaking with CA), volatiles stored in the shop, smoking (of course), general housekeeping (mounds of dry shavings, guilty as charged), shop heaters in the winter. Keep industrial fire extinguishers both inside and just outside the shop - they are not that expensive.
Electrical safety - amateur wiring, grounding, GFI, extension cords, fire trees (bunch of cords plugged into splitters on a single outlet). A guy at work got a potentially lethal shock one time after some moron incorrectly wired an extension cord.
Safety for children in the shop, working, watching, playing
Lifting log sections, etc (three hernia operations here)
Dull tools can be more dangerous - require more force and therefore more chance of slippage. Example, when carving by hand.
Re: Safety demo
Re: Safety demo, bandsaw and tablesaw
Ed Moore in SW VA
>John,
1. Bandsaw, clear the cutoffs before starting a new cut and don't wipe your hand across the table and engage the blade. My bandsaw accident occurred because of a cut-off at the back of the table which stopped the wood when it broke through and caused the piece in my hands to pivot. I was standing to the left of the blade and my right hand was pivoted into the blade as if I punched it.
2. Cutoffs. I went to move a small cutoff with my pushstick on the tablesaw. It was at the back of the blade. The pushstick touched the back of the blade and was propelled forward with considerable velocity. The pushstick struck my left hand which was back at the rail. Broken index knuckle. If I had touched the front of the blade the pushstick would have gotten a knick, but it would not have been thrust forward so violently.
I agree with Steve, you will have more topics than time to duscuss all the things a safety program should include.
Respect the bandsaw,
Ed
Re: Safety demo
Re: Safety demo
>Thanks Andy, I thought about wood dangers and since I use lacquer I'm well aware of those.
Re: Safety demo
Don Geiger
Don Geiger
>I just read through the replys to John's posts and they are all good. One I didn't see is the importance of having an on/off switch at the tail stock end of the lathe so you don't have to cross the line of fire to turn the lathe on/off.
Also, making sure the speed control to it's lowest setting before you start the lathe the first time. I have worked at Arrowmont and Campbell numerous times and the very first thing I do before anyone shows up is to turn all the speed control settings to ZERO!
You won't believe how many students come to me immediately complaining their lathe isn't working which means they turned the lathe ON without ever checking the speed control.
Don Geiger
Re: Safety demo
Ed- I think I'll just tell them woodturning
>is simply too dangerous and they should give me all their tools. Since some of them do segmented work that means they would have to give me the planers and surface sander as well. This could be a good thing. :D
Re: Safety demo
Re: Grounding
Bill Turpin in WNC mountains
>Make sure that all grounded cords are really grounded. Is the ground prong still there? Has the grounding been stopped by using adapters that are are not being used properly? Is the fat prong on double insulated cords still fat? If you are working outside, are you plugged into a ground fault outlet?
Those little nips from a metal framed device can kill! Check with a volt meter from the shock point to a true ground. Many times there will be 120 volts. It is time to fix it or to discard it.
Re: Safety demo
Re: Grounding
Bob Edwards
>John you have a very long list to which I would add lung protection. It is often overlooked and is potentiality a killer. It's not given the attention it deserves because it creeps up on you, like smoking. The longer you turn the more aware you become of the effects of working in all that dust. "Get a dust mask"!!!
Re: Safety demo
Re: Ed- I think I'll just tell them woodturning
><...too dangerous and they should give me all their tools
Ha! As cave divers in the Fla springs, that's very much like what we used to tell the obviously untrained sport divers who we encountered about to enter a cave. Looked them over and acting as if they were not present started seriously discussing their gear among ourselves and who would get what.
When asked what the h we were doing we told the truth - there were so many things that could go wrong that without proper training the chances of them all drowning was significant. Backed it up with examples. We just wanted to see ahead of time if any of their gear would make it worth our effort to make a recovery dive later in the day and haul their bodies out of the cave. Batted 100 - in every case they changed plans!
Oh, I thought of something else about fire safety: making sparks at the grinder with shavings on the floor.
Re: Safety demo
Re: Safety demo
Dick Coers
>There are really two points to made about chemicals, skin contact and inhalation. When I was young, I thought my skin was an effective barrier (was taught to wash my hands in gasoline to remove solvent based paint ARGH!!!!!!!!!!!!!!). I now understand just how porous our skin is. Sweat ducts, hair folicles, and permeablility will let the chemicals pass through and enter the blood stream. It thens gets filtered out in the liver and kidneys. So that little splash on your hands will end up almost everywhere. Eyes can absourb liquids very quickly. Rubber gloves are a must for highly toxic chemicals, good nitrile for oils.
Re: Safety demo
CA glue
Fred
>Spinning we CA glue will be damaging to the eyes without proper protection.
If you completely fill a deep hole with CA glue, the deepest part will not cure even though the outer skin has cured. Once the centrifugal forces take hold, the wet CA glue will vaporize into the air.
Re: Safety demo
Re: Safety demo
robo hippy
>One quote I have used for years, from 'Pats Fan' on Wood Net Forums: "When sphincter tightening exceeds chuck tightening, you have a problem." I follow this with some thing like, if you are trying some thing new, slow your lathe down, and slacken up the belt. Mistakes are much more forgiving this way.
Another one I saw today, author at present unknown: "Anything with sharp teeth eats meat. Most power tools have sharp teeth. People are made out of meat."
robo hippy
Re: Safety demo
Steve Kubien
I'm with Carole
Steve Kubien
>The grinder scares me more than anything else in my shop, so much so that I only recently gave up my belt-sander as my prefered tool for sharpening. I just cannot imagine the chaos and carnage that would result from a shattered wheel or a tool that slipped below the centre-line.
Re: Safety demo
Steven Antonucci
Stopping the running blade with
Steven Antonucci
>your hand...
My neighbor had a willow fall over, and since it was covered in burls, I offered to help him clear it. I asked him if he wanted to make some of the cuts, and wouldn't you know it, he put his hand up by the tip of the saw to start the cut!
I have a safety practice that I use ALL OF THE TIME. Whenever I stop cutting, I bang the brake on with my left hand. Before I start cutting, I need to undo it. This prevents me from working differently every time I touch the saw. I also set the brake when I am done, so that the saw starts with the brake on.
On this day, it likely saved him a trip to the emergency room, since nothing happened when he hit the throttle. It's the things that you don't think about that usually hurt you, and why there are instructions to NOT STOP THE BLADE WITH YOUR HANDS.
If common sense was common, we'd all find some other way to hurt ourselves.
S
Re: Safety demo
Steven Antonucci
Went to the Emergency Room for this!
Steven Antonucci
>Exactly as described. Lots of CA glue, cut through the cured part, right in the eye...
The CA glue cures instanteously because of the moisture in you eye, which lets of heat, and cauuses a chemical burn. You need to get the hardened CA out, which is relatively easy, but that's not where the fun begins.
In my case, the burn cause blindness for about a day in that eye. Oh, sure, I could still see blurry, colored images, but I couldn't keep my eye open long enough to make any of them out because of the EXCRUCIATING PAIN. I cannot even describe how much agony it causes, but wait there is more.
If you had Pinkeye when you were a kid, you might recognize the term conjunctivitis. Chemical conjunctivitis comes with the package. As much as it hurt, you now have the itching, the goo, and the discomfort of that condition on top of it all. I drove myself to the hospital ER with one eye open, and it was the longest 20 minutes of my life.
DO NOT USE CA GLUE ON A LATHE WITHOUT A FACESHIELD.
This has been a PSA from someone who learned the hard way...
Steve
Re: Safety demo
Ric Taylor
Re: Safety demo
Ric Taylor
>When I was a pilot in the Air Force, two of my assignments were in Air Rescue. Two of my missions were to ships very far out from land (eight and ten hour missions), to pick up ship's crewmembers who had large pieces of grinding wheels lodged in their forehead and face.
Just as with my lathe, when I start up the grinder, I never stand in direct line with the grinding wheel. Then I try to spend as little time in line with the wheel as possible.
Ric
Re: Safety demo
Re: Grounding
>Bill In my old shop in a very old house I used to get minor shocks all the time. Everything was grounded but apparently something wasn't done properly. When I ran the 220 line to my new shop I did a lot of reading on how to ground and whether I needed one at the garage. Must have done something right because I have no issues here.
Re: Safety demo
Bandsaw Sled
Doc Green
>IMHO, a sled for a bandsaw is one of the best safety devices in the whole shop. But it does take a few minutes to make one, and you can probably get by without it, so why bother?
~Doc
Re: Safety demo
Re: Went to the Emergency Room for this!
>Steve I wish I had saved all the responses to CA glue accidents when we had that discussion here. I laughed so hard my ribs hurt. It would have made a wonderful handout.
Re: Safety demo
thanks Fred
>I had forgotten about that and I don't know now. I've had my share of CA glue accidents.
Re: Safety demo
Re: I'm with Carole
Scott in Falcon
>Steve,
I can tell you what having a tool fall below center line on the grinder is like. There is a loud bang and the tool that was firmly in your hand is no longer there. There is the sound of something hitting the floor and rolling. Your heart rate is elevated and you think you may need to get out of the shop for a while. All this takes place before you actually realize what just happened.
I have completely changed my approach to using the grinder. I wasn't injured but I sure won't forget that incident.
Scott
Re: Safety demo
Keith Tompkins
Re: Safety demo
Keith Tompkins
>Hey John, maybe you can do a "Fire Marshall Bill" style demo...."Let me show ya' somethin'!"
