Atlas Lathe?
Atlas Lathe?
Jim DeLaney, Austintown, Ohio
Atlas Lathe?
>In today's paper, there an Atlas lathe for sale. Guy says it's a 12 X 36, with cast iron ways, on a metal stand. That's about all he knows about it.
Can anyone tell me anything more?
I may be going to look at it tomorrow.
I have need of something to turn table legs on. I doubt I'll ever use it for much more than that.
Jim D.
Re: Atlas Lathe?
Richard Allen
Re: Atlas Lathe?
Richard Allen
>I suggest that you attend a woodturning club meeting and express that you are interested in turning some table legs. This has some terrific benefits for your intended purpose (making some table legs).
Getting into woodturning is going to cost somewhere around $400 - $10,000. Expect to look back and find that you have spent over $1000.
Ouch! How is that possible!?!?!?
Lathe $100 - $7000
Lathe tools $20 - $200 each, Parting tool, Spindle roughing gouge, Spindle gouge, Skew, a couple of scrapers $100 - $1000
Sharpening equipment (grinder, AO wheels, Jig) $100 - $200
Sanding supplies $20 - $100
Finishing supplies $20 - $100
Safety Equipment $20 - $1000
Books and videos $0 - $500+
Instruction $100 - $1000+
Go to a local club meeting, tell the members that you are looking to make some table legs. Make arrangements to do that at one of the club member's shop. Bring wood with you, Bring sandpaper (ask what grits you will need), Bring finishing supplies...
You will get some hands on help, make a friend and save a bunch of money.
You can go to the AAW web site to find the particulars about the woodturning club near you.
Good luck.
P. S. You think that you will only make a few table legs. You WILL get hooked and you will abandon corner work.
Re: Atlas Lathe?
Re: Atlas Lathe?
Lee Buck
>My first lathe was a 12x36 Atlas lathe. I acquired it without a stand or motor. I powered it with a 1 1/2 horse varable speed motor and had 4" inch riser blocks made from aluminum. Of course you would not need risers to turn legs or many other things. It was a very good lathe.
Re: Atlas Lathe?
Re: Atlas Lathe?
>[q]"Getting into woodturning is going to cost somewhere around $400 - $10,000. Expect to look back and find that you have spent over $1000.
Lathe $100 - $7000
Go to a local club meeting..."
Richard,
I already have pretty much all that stuff for my Jet Mini (that I hardly ever use).
The closest woodturning club to me is about 60 miles away.
As for turning bowls, I've never seen the big attraction/fascination with that - obviously very much unlike many of you. I also got tired of pen turning after about the first dozen.
I'm mainly into furniture, and making legs, chair spindles, and maybe a few half or quartered columns are pretty much all I'll be doing. Even on the mini, the last several uses have been turning chisel handles or plane knobs.
Jim D.
Re: Atlas Lathe?
Re: Atlas Lathe?
>Jim I think the Atlas wasn't all the different from my Jay-Line. It should be a decent lathe for turning furniture parts. I started some legs today. They will be 31" long tapered from 1" to 1 3/4 with a curved foot at the bottom. Turning long thin legs is tough. You get lots of chatter from the wood flexing. Plan to practice quite a bit. There are techniques to reduce the chatter to an easily sandable level. Start with short fat legs and work your way up to longer fat legs. Later on you can learn tricks like split turning to put fluted parts on the corners of your work.
Re: Atlas Lathe?
Re: Atlas Lathe?
Ken Oakley-Sunny St. Cloud, Fla
>I worked on an Atlas 12 X 36 lathe in a modelmaking shop in the 1960's.
I loved that machine. One of the projects I made on it was the prototype for the Comet Cleanser container which is still the one found on supermarket shelves today. It is the yellow one. Can't miss it.
Re: Atlas Lathe?
Re: Atlas Lathe?
DAVID J CHURNEGA
>If the cost is 600 or less buy it or post the sellers contact info.
There are a lot of people out there looking for this one.
Re: Atlas Lathe?
Roger in MO
Re: Atlas Lathe?
Roger in MO
>Jim, Many school shops had Atlas wood lathes after WWII. I acquired one about 15 years ago and made several spindles on it including a rocking chair and multiple table legs. Motor below the lathe, belt driven, 4 step pulley though some also had a jack shaft.
I still have the lathe, it needs a new bearing. I upgraded to a used Jet 1236 and last summer bit the bullet and bought a Jet 1642.
Roger
Re: Atlas Lathe?
Re: Atlas Lathe? - Bought it!
>Looked at the lathe this morning, and didn't see where I could go too far wrong. Cast iron bed, ball bearings, and everything is tight - no play in the headstock. #2 Morse tapers in Head & tail stocks. Has an indexer on the headstock. $125.00 brought it home.
Now, can ayone tell me where to get a 1 inch by 10 TPI adapter for my Nova chuck?
Jim D.
Re: Atlas Lathe?
Keith Tompkins
Re: Atlas Lathe?
Keith Tompkins
>Nice one! I love old iron! I am amazed that old WW equipment hasn't become collectable, like cars, guitars, etc. have. You can buy this stuff for a song, and the quality is superior to most anything out there available today. That lathe is probably 60 years old.
Re: Atlas Lathe?
Re: Atlas Lathe?
>Keith,
The guy I bought it from said it was his Dad's, and he thinks his Dad got it sometime in the early 1950's.
Other than needing some caked on sawdust cleaned out, and a new switch to replace that cobbled up one, it's actually pretty pristine.
Jim D.
Re: Atlas Lathe?
Re: Atlas Lathe?
Don Evans
>Jim, regarding a switch, you can still get the old style "drum switch" from:
www.surpluscenter.com
Do a search for it. This switch will also allow for reversing the motor if it has that capability.
Don
Re: Atlas Lathe?
Re: Atlas Lathe?
Bill Noce in Northeast Ohio
>Jim,
Check Best Wood Tools they carry spindle adapters they have 1x10tpi to 1x8tpi plus others in 1x10tpi.....here's their site...
http://bestwoodtools.stores.yahoo.net/precspinad.html
Re: Atlas Lathe?
Brad Vietje
Brad Vietje
>Nice find, Jim!
Teknatool makes 1" x 10TPI inserts, available in both both right- and left-hand threads. The inboard, RH thread is Insert C.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Atlas Lathe?
>Brad,
Teknatools website showed a U.S. 'mini-warehouse' in Parkersburg, WV. It's Tims Tool Crib, and he had the adapter in stock. $28.59, including shipping. It's on its way now.
Jim D.
