Sharpen on a Bench Grinder AND a Tormek
Don Geiger
Don Geiger
>Dear Fellow Woodturners:
I was looking at some recent threads where people were expressing an interest in using a bench grinder to shape their gouges etc. and then maintaining the grind on a Tormek. I offer just such a system. It slides right into a Wolverine receiver; so you need one under each grinder. It is provided with two adjustable positive stops so it can be moved from one grinder to the other in about 10 seconds. It provides very repeatable results at each grinder and when moved from one grinder to the other.
It also allows you to use conventional jigs such as the Ellsworth jig and the Vari-Grind etc. at the bench grinder AND at the Tormek. The system is called: Geiger�s Vertical Solution.
After having sold about about 1,400 Vertical Solutions for bench grinders, in 2009 I added the Tormek capability. I can't figure out how to post photos on this site. If someone wants to see some photos let me know and I can e-mail them to you.
Don Geiger
Re: Sharpen on a Bench Grinder AND a Tormek
Fred Bearman (Port Huron, Michigan)
>Tormek also has a solution, the BGM-100, which allows all of the Tormek jigs to be used on a dry grinder (including the use of their easy setting tool), and then moved directly to the Tormek after shaping for final grinding and honing. Had this been available at the time that I purchased my Tormek it would have eased my agony in deciding between the systems that are available for sharpening, since you have the best of both worlds. I have completed the setup for the BGM-100 and have begun to try it out. So far it works very well, and I hope to be able to write a review in the near future.
I am sure that your tool is a great option for those with Wolverine systems, and I am certain that it is well thought out, like all of your devices. I particularly like your dresser, thinking of using it with my dry grinder.
No disrespect intended, just wanting to include all available options for the Tormek.
Don Geiger
Don Geiger
>Some advantages to the one I offer are:
- It allows you to use conventional jigs such as the Ellsworth, Vari Grind etc.
- It includes a gauge for setting the distance to the face of the wheel
- It compensates for changes in the wheel diameter as they are reduced through dressing
- It includes a gauge to set the amount your gouge protrudes from the face of your jig
- It includes a 60 degree gauge that fits into your jig (Ellsworth, Vari-Grind etc.) for setting the angle accurately.
