beginner and purchases
Patty
>I visited a woodworkers show this past week and had the chance to try turning. It was great! My husband would like to get me a lathe / tools for Valentines day. So - suggestions for lathes are needed. We've looked at a Craftsman from Sears - around $150, a couple others in the $200 - $400 range. What is a good size, price, and is a pen mandrel universal? I would mainly like to start as a hobbyist, making pens, keychains, chainpulls, - smaller items. Bowls would eventually be nice, depending on my abilities.
Re: beginner and purchases
Jorge Casta�eda
>Patty,
Welcome to the forum and to the world of turning.
I suggest a mini lathe, Jet makes one with variable speed, that is the one that can help you learn faster and will keep being useful for a long while.
An you will need a tool of course, I highly reccomend to get only one, a 3/4" skew.
many are scared of that tool, but if you learn with just that one, when you get others it will be childs play, and you can do a lot of stuff with just that tool. You will need means of sharpening, I recommend a 600 grit diamond hone.
Have lots of fun. Some day you can get other tools.
my two cents
Jorge
>Avoid the Sears lathe. There have simply been too many complaints about them. The Jet, Rikon, and Delta mini lathes get high marks from everyone so you can't go wrong with them.
I'll let the pen turners tell you about pen mandrels.
>To echo what Jorge and John said.
Variable speed is nice. Turning on minis that don't have variable speed can be done and is fun. Changing the speed with the twist of a dial is much easier.
If you ever want to sell (if you upgrade) - the variable speed will probably retain more value. You may want to check out a used one anyway.
More power is better. If you want to turn a bowl, you may need it.
My $0.02.
Harry in Beautiful Downtown Kulpsville
>Leave a few dollars for a decent grinder with white wheels. Woodcraft has a decent one for a reasonable price.
If just one tool, I'd recommend a spindle gouge.
A pen mandrel must match the taper in the headstock. The Jet, Rikkon and Delta all have a #2 Morse taper. Unless you get pen kits from Berea, all other pen kits use the same mandrel. (At least in my experience.)
Re:The first and most useful tool ....
JamieDonaldson
>...for a beginner should be a 1/2" spindle gouge, but don't worry, it won't be your last!
mjonesrdg
>Patty,
Welcome aboard! My best suggestion for starting from scratch would be to find some local help...a mentor or woodturning club, for example. If we knew your hometown, one of us may be able to steer you in a helpful direction.
A local Woodcraft Store may have some weekend classes. There is a lot of free info in woodturners catalogs. Google "Packard Wood turning", or "Craft Supplies USA" and just ask for your free catalog.
Safe turning...and have fun!
Katherine Kowalski
Katherine Kowalski
>Hi Patty,
I would definitely recommend one of the higher-end brands of lathes -- the Jet, etc. I own two Rikon mini lathes and they've been serving me well for all the years I've been a full-time turner. Variable speed is a must -- it will allow you to expand your repertoire to other projects like bowls and boxes.
DEFINITELY save money for a grinder -- just honing with a diamond slip won't cut it. (When I first started turning, I was told that I didn't need a grinder, that simply honing the tools was acceptable substitute -- no WONDER my spindles kept breaking!) After I finally purchased a grinder, 3 months later, it was AMAZING how well the tools cut! :D
I would advise on getting a spindle gouge (3/8") as your first tool -- it can do *everything* any other tool does, and has a relatively easy learning curve.
And one thing I cannot recommend enough -- invest in classes from a professional turner. They're knowledge and experience is worth 100 times what you spend on it! They can teach you how to make the most efficient cuts, sharpen your tools, and techniques for creating everything you can imagine!
Enjoy yourself at the store, and remember to post back and tell us what you've bought!
Katherine
Dick Hines
Dick Hines
>You are going to find that wood turning a great hobby but can get hard on the wallet quick. Don't try to get all the tools over night. Most turners with lotts of goodies have been at it for years.
If you don't take care turning can be like a boat. It just a hole in the water to through money in.
Have fun.
Jerry Klug
>There is only three things you need to know...
1)find a local turning club
2)Attend a local club
3)get to know local turners
The happiness factor with your first lathe will increase with more weight (heavier lathes are more stable than lighter ones), more power (the higher the horsepower you can afford the faster you will be able to remove wood) and variable speed. The grinder is nice but the tools can be sharpened with a belt sander or some of the new sanding disc equipment. I use a slow speed grinder (1725 rpm from Woodcraft) and a Tormek wet stone grinder. Those are really nice but not necessary to start out. Get a basic 5 tool set to start (parting tool, spindle gouge, roughing gouge, shew and scraper) at a reasonable price. Keep with HHS (high speed steel) but they can be Benjamins Best or Crown. You will shorten them all when learning to sharpen.
Welcome to the all consuming virus that your health insurance won't cover.
Re: beginner and purchases *LINK*
Carol Reed
>Welcome to the slippery slope! :)
The best advise you got is to find a mentor. That will cost you a few bucks but you likely will save it all back and then some in ill-advised purchases. Those will be the best dollars you spend here.
Find a club. Click on the link below and enter your location information. And let us know where you are. We may be right around the corner!
Don't buy stuff until you have a mentor. You will be happier if you get advise first. Tell your hubby an IOU for Valentine's Day is just fine. This time. :D
Then get your ducks in a row.
If its pens you are interested in go to http://www.penturners.org/. Lottsa bowl turners here, but some penturners.
Overwhelmed yet?? LOL!
Find a club
Dick Coers
>Patty, I don't know where you live, but maybe the midwest since the woodworking shows are in the region now. If so, we are having a really nice penturner's gathering on April 17th. It will be in Champaign, IL. This will be the 3rd year, and last year we had 75 attendees. Lots of demos, door prizes, and vendors. Best of all, it's all free. Well, except for all the purchases from the vendors (which I am one of).
I agree with the Jet mini. I think it's the best machine Jet makes. You can put a pen mandrel on about anything. They make them for #1 and #2 Morse tapers, collets that thread on, or even some guys don't use the mandrel now. They use special adapters for holding a single blank at a time. Lots of info on the IAP site mentioned.
Midwest Penturners Gathering
Dave Kartzman
>I am a newbie as well, and completely agree with all of the suggestions that you read in all of the above messages. My wife and I wanted to learn woodturning, and we have a teacher that has been turning beautiful bowls, boxes, etc. for over 30 years. We did not buy any equipment initially. Our teacher/mentor let us learn initially using his tools until we were certain that we were serious about learning woodturning. Once we decided to move forward, he worked with us to identify the tools and equipment we would need to build our own workshop. He pulled out the catalogs and helped us find the best deals on what we would initially need, and it worked out wonderfully for us.
We ended up buying a Delta 14" bandsaw, grinder, and Delta midi-lathe, in addition to a basic set of full-sized tools and some mini-tools. We have added a few other pieces as we progressed in our learning.
We have a couple of woodturning groups in our area (southern SC/Georgia) but have not had the chance to attend any meetings so far (I travel constantly for my job). One cannot understate the value of learning from experienced people.
I would add one more thing to consider as you learn to turn. Our teacher/mentor highly recommended looking at the videos on youtube; particularly the bobham5 videos. They are great!
Best of luck in turning! :)
Brad Vietje
I'm With Carol & Jerry...
Brad Vietje
>Hi Patty,
Welcome to the addiction -- you're going to have a lot of fun!
I completely agree that the best initial investment you can make as a newbie turner is to spend the time and money to find and join a local turning club. The American Association of Woodturners, or AAW is the umbrella organization of most turning clubs in North America. They maintain a list of local chapters at www.woodturner.org. If you let us know your location, we probably have members of this forum that can help you get started.
I think you will get so much out of meeting other turners in your area, seeing and participating in turning demonstrations, taking classes offered, and meeting potential mentors, that even a 2-hour drive to attend meetings will seem well worth it. After you get established, if there's no club very close by, you can always start one.
Another benefit of joining up with other turners is the opportunity to try out different equipment before you have to spend an arm and a leg buying stuff. Some members may even have a used lathe for sale, which can be the best deal of them all. An older, heavier lathe can be a very good bargain -- ask around. A 50-year-old Rockwell/Delta or Walker-Turner lathe will be a better investment than most new mini or midi-lathes, and have a lot more mass. If you can find an old Powermatic 45 or 90, they make great lethes for a lifetime of fun. The best value in older equipment are the name brands with easily-replaced bearings, like those I've mentioned. I bought a Jet 1236 at an auction about 8 years ago for $175 -- not a great lathe, but a pretty good value, overall. Eventually I outgrew it, and bought a bigger Powermatic, but don't spend big bucks until you really know what you are going to be turning.
I don't agree about the necessity of variable speed -- it's handy and helpful at times, but not essential. Changing belt positions, or using a reeves-type drive is just fine for almost all amateur work. If you get a new lathe, the Jet mini or Delta midi are good values. Don't get a lightweight toy; more mass is better unless you have to carry it!
Safe spinning,
Brad Vietje
Newbury, VT
Here is my list for a startup shop
Jerry Hall
>Patty,
I am asked so often at fairs, demos and when mentoring that I prepared this page for answering your question:
http://docs.google.com/View?docID=adv8f4kvqjnq_148g682k7hc&revision=_latest
It is one point of view, and others for sure will have different viewpoints, but I think it should be helpful to you.
Jerry
Excellent handout- cover it all quite well.
>Patty,
You came to the right place to ask! You'll find woodturning fun and woodturners a great bunch.
A pen mandrel will work for different kinds of pens. You have to get one to fit your particular lathe, i.e., to fit the taper in your headstock (see note about lathes below). You need a different set of bushings for each type of pen - these are cheap. Unless you buy pre-drilled pen blanks, a drill press will be most helpful. An alternative is getting to know another turner who will let you drill a bunch of pen blanks on her drillpress! A drillpress can also be used to assemble pens. You need a way to flatten the end of a pen blank - some use a disk sander; an inexpensive pen mill works better. Also needed for pens: a drill bit for each pen type, glue, sandpaper, finishing supplies.
I also recommend staying away from the cheap lathe. I, like many others, bought a cheap lathe at first since I didn't know any better. I eventually gave it away and got a far more useful lathe. Some problems with low-end lathes: the spindle shaft (the part the spins) is usually too small a diameter, a weak point. The lathe is often too light in weight and construction making vibration a problem. The controls to adjust, tighten, and change speeds are difficult to use quickly and effectively. The motor is probably not powerful enough to do many turnings. The headstock spindle shaft on all lathes is bored with what is called a Morse Taper (MT). Cheap lathes are sometimes made with a smaller MT#1 taper in the headstock; the larger MT#2 is stronger and far more widely used.
I ended up with a larger variable-speed lathe, but I also have a couple of the manual-speed Jet mini lathes which are easy to move around, take places, and lend to people. You can do an amazing amount of turning on a good mini lathe.
In addition to protection for your eyes and lungs, here are some associated things I find necessary (as others mentioned as well) and useful:
- A few tools made from high-speed-steel (HSS). A small roughing gouge, spindle gouge, parting tool, bowl gouge, and round-nose scraper will let you make almost everything. I would also suggest a 1/2" or 3/4" skew chisel - many would disagree because they have problems with this tool, but I can guarantee that if you learn how to use a skew right away you will never be sorry. (I have taught people to use the skew as their very first tool.)
- Way to sharpen. If you can't sharpen quickly and effectively, you cannot turn wood, plain and simple. People who don't have this usually lose interest quickly since using dull tools is simply no fun. A bench grinder is perfect; a sharpening jig like the Wolverine will do everything you need.
- When you want to make more things than pens: A 4-jaw scrolling chuck will make many if not most kinds of turning easier. I even think bottle stoppers are easier with a chuck. You can certainly make many things with face plates and glue blocks the way they did it in the days before chucks, but a chuck makes it so much quicker and simpler to get to where you are actually spinning and shaping the piece of wood.
- In the long term, a band saw. This gives the you the flexibility to fit the wood to your idea, rather than suggest you change your idea to fit whatever wood you have at hand. The bandsaw is arguably the single most flexible power tool in a shop. You can often find a 14" bandsaw for very little.
I strongly agree with others about finding a club and meeting other woodturners in your area. I didn't have that when I started but it would have been helpful, although learning from books and experimentation has certain advantages. Turners will also give you lots of wood to get started. You should mention where you live.
Patty
>I'm in Fond du lac, Wisconsin
I did see a group listed in Neenah, however I did not see any contact information for them.
We do have some local woodcraft groups that meet in the area through local schools. I plan on checking into them to see what they have to offer. My husband and I already have some tools in our basement. Band, scroll, table saws, drill press, sander, bench grinder.. so I have a pretty good headstart. He and my son are heading to Appleton today to look around at Woodcraft. We did find a nice Rikon listed online in the $350 range. Appreciate all the advice and will definately stay in touch. Thank you
Cyril Griesbach
>Patty,
Welcome to Wood Central.
There isn't much that I can add to help out that hasn't already been said other than to say that, as a group, woodturners are more helpful, friendly, giving and sharing than any other group of hobbyists I've ever encountered. But then you've probably noticed that already.
Oh, and find your nearest AAW Chapter and join up. I sure wish I had when I started turning.
jack
>Hi newbie. Glad you are joining us in the black hole of turning. MY ADVICE...any of the mini lathes..JET DELTA, etc..if you have $ issues, get the non-variable. (it won't kill you to change a belt, truly it won't. people have done it for a century or better) Only one tool? For spindle turning (pens) a spindle gouge about 3/8 inch) Pen mandrels are not universal. There are 2 sizes A(WHICH IS ALSO CALLED A 7MM) and B...These are for pen kits from Berea harwoods.kits..7mm is the standard. Go to Penn State, BereaHardwoods and look over the online catalogs. It will help. If you have any more trouble just ask & I'll be happy to answer your questions
Hey, Cyril!
Carol Reed
>Patty is your neighbor! She's in Fond du Lac. See her response to JKJ.
Re:Patty- the Neenah club is a good ....
JamieDonaldson
>,,,gang of turners- I did a demo for them not long ago. The AAW chapter program is one of the best things that has ever happened for turning education.
Cyril Griesbach
>Carol, I now see that so I sent her an email offering to help out.
Jamie, thanks, my friend, we do have a good club in Neenah and although I'm not sure I believe our membership is full due to space limitations and thus not open to new members. I think we are limited to 80 members and all must belong to the AAW. But I'll sure do what I can to help Patty.
Cryil
Re:Cyril- I bet there are some regulations....
JamieDonaldson
>... about having to include a certain percentage of minority (as in female!) members in any public organization, especially if they are active and can make good coffee!!?? :D
LGuthrie - Merrill, Wi
>Northeast WI Woodturners - http://www.woodturningonline.com/Community/Club_Directory_US.html
