>I have a Milwaukee 3/8 close quarter drill that I use for power sanding. The rear bearing finally failed. I can get it repaired locally for about $50. They cost something like $140 new. What's your opinion on having it repaired? ( To tell the truth, I also use a cheap HF ($29.95) that's been working just fine.) But the Milwaukee is a nice tool and it seems fine -- except for the bearing.
>The Milwaukee is a nice tool, except for the bearing. The close quarters drill has been through at least [two re-designs and the bearing problem has yet to be addressed. It is a shielded bearing and it should be a sealed one. A few cents extra on the part of the manufacturer and it would be solved. As it is, I believe if you search the archives, you will find lots of information on how to change the bearing yourself. The bearing, itself, only costs a few dollars -- the archive will tell you sources. Be very careful taking the side off the drill. If you disturb the trigger mechanism, you will never figure out how to put it back together again (guess how I found that out!). I believe the advice is to take a photo of the inner works before you disturb anything. Good advice.
You are lucky the drill only costs $140. Here, in Canada,, it is closer to $230. I went through two of them including several $80 rebuilds. Now I just use a Nokia knock-off. It lasts much longer than the Milwaukee and only costs $50. When they finally die, after a couple of years, I just replace them. The longest I ever had a Milwaukee last was 10 months.
Sioux/Milwaukee has discontinued the close quarters drill. You can't replace the drill you can only get it repaired. If you let it go to long the plastic which holds the bearing in place may have melted. In that case you can't get it repaired.
You will likely find that a repaired drill will last you many years longer than the new one. Not because the repaired drill is better but because you are better at using the drill.
To replace the bearing you take out the armature (you should likely remove the brushes first) and then cut away the bad bearing. Press on a replacement bearing, fit everything back together and you are good to go.
I have some spare bearings and I could bring one to the February meeting if you like. The bearings don't cost much but the shipping is the same for one or five.
You need a drimel and a cutoff wheel to remove the bad bearing. There are several ways to press on the new bearing, just be careful with any force that is not directed into pressing the bearing onto the armature.
>....having one of my Sioux drills repaired at an "authorized repair facility" for about $80+ and it came back with a damaged winding that shredded the first time I turned it on. Since then I have replaced the bearings myself with no problem, after I figured out the trigger puzzle as Bill mentioned. I now also have 2 of the cheap red copy drills which work well enough, but they are certainly noisier than the better quality drills.
>Woops, Steve -- I should have said Neiko! There are multiple sources on the Internet. I used to buy them from Boss Tools, but last time I ordered one, they seem to have been out of stock and I waited several months. While waiting, I went to the woodturning symposium in Ohio. I saw them there and boiught one. Guess what arrived in the mail from Boss Tools a few days later!
>Steve - Canadian Tire had the Mastercraft with three year warranty on the other day for about $30 or $40. I have one for close quarter drilling like between joists, but don't like the heft and balance of it for sanding. Have used a couple of times in deep somewhat narrow bowls or vessels.
>I have 4 of the Milwaukee/Sioux angle drills (note, they are drills, not grinders which is what we use them for). Each has been rebuilt a number of times, and I have had the plastic casings replaced on most of them as well. I used to get 300 to 350 bowls from a drill before they needed the bearings replaced. Then I tried some fancy sealed bearings, and got a little bit more from them. Then I took a hint from Vince (VincesWoodNWonders), and slowed the drill down to about half speed (piece of 1/4 inch cork under the trigger). The sanding goes as fast or even faster, and the drill is now good for about 450 bowls (all sizes from 16 to 4 inch). I use 3 inch discs almost exclusively, which is a lot harder on the drill than 2 inch discs. I don't press hard which will also cause them to wear out faster. I got one of the cheap $30 dollar drills, and it lasted about 3 weeks before the casing wore out. They just aren't worth the effort to me. Maybe I could buy them by the case, but I hate disposable tools.
>Your theory may well be valid. It is sort of like my theory that if I have the plow on my John Deere then it won't snow. We got hit once this winter and now they are making me nervous about this coming weekend. Oh well.
By buying two I figure that I save most of the postage on the second one. Maybe, maybe not.
Something I think that Bill wrote has me thinking. If I cut the speed and pressure, then I may be doing myself a favor all the way around. Also, it is less effort on my part.
"George, you can cut the old bearing off with a Dremel or with the corner of your grinding wheel. Cut the outer race first and get rid of it, then carefully cut the inner race so that you do not damage the shaft. A little nic won't hurt but don't get too aggressive. I cut the inner race on two sides and then twist off the halves with a pair of vise grip pliers. There are several choices for the bearing. The original one is likely a shielded bearing that is made in China and is a very low quality bearing. Enco sells a slightly better bearing or rather an equal bearing with a better dust seal. It is called a sealed or double sealed bearing. I prefer to spend a few dollars more and get a bearing that is made in Japan and is double sealed. It is a Koyo bearing, part no. EE 1 1/2 2RSM3GSR. I can't tell you how long this one will last because I have never burned one out. TD"
