OT: (but serious post) Melting various metals
Steven Antonucci
steve antonucci
>Anyone here have any experience melting copper/brass alloys in "home based" environments? I have had some luck with pewter, but copper and brass seem to elude me. I can get them liquid, but not flowing...
Anyone have any pointers?
Steve
Re: OT: (but serious post) Melting various metals
Rick_Allen
>HEAT
You can get low temp pewter that melts at 400 F
Normal pewter melts as 750 F
Brass is an alloy which have different melting points but the range is 1650 F to 1720 F
Copper has a melting point of nearly 2000 degrees.
Steven Antonucci
I've melted all three
steve antonucci
>My question is more about how to keep them from getting impurities and keeping them liquid. I don't think I have enough heat from my plumbers torch...
I'm going to make a forge to get past the insufficient heat, but impurities are still an issue
Re: I've melted all three
Harry in Beautiful Downtown Kulpsville
>Steven, Do you use MAPP gas? It is considerably hotter than propane. It comes in cylinders that fit your torch. You can buy it at Lowes, Home Depot, etc.
Steven Antonucci
MAPP melts it, but not to a liquid
steve antonucci
>I suspect that I can get enough heat to make a liquid bead about 1/4" round, but I am trying to melt more than that (maybe a thick quarter sized round 1/8" ish)
I was thinking oxyacetyline next...
Or that forge I've been putting off :-)
S
Re: MAPP melts it, but not to a liquid
Ralph
>I've had some luck with low-temp copper allows using a propane weed-torch. It does sound like a jet engine, but it does put out a lot of heat.
I don't think most forges would work. My open forge (coal or char-coal) is not really suitable. Nor is the average (closed) forge used by blade or horse-shoe workers
I have used a friends casting pot. It's natural gas powered and uses a ceramic pot. It does work, but it really uses fuel
>An oxy-acetylene torch is so handy around the shop - will easily melt steel so it should handle copper. You can get a portable torch kit at a big box store but the tiny tanks don't last long. The industrial gas suppliers will lease but not sell the big tanks. I ended up buying the largest they would sell, 80 cu ft for the oxygen if I remember. Be careful - acetylene is naturally unstable and requires some special handling.
JKJ from Windows Mobile
Can't help you with melting metals, but...
Gary Evans--Tallassee TN
>I can show you how to melt the handle clean off a Craftsman screwdriver. I left one on top of the small wood stove today before I fired it up. I don't know how I kept from seeing that sucker laying there. I wasn't even drinking. 8^] Talk about a stench and a mess.
Gary
charlie belden
>FLUX!
Oxygen is THE enemy. And the hotter the metal gets, the more it wants to grab on to oxygen - and make oxides - think RUST. Oxides are what you DON'T want.
So you apply a material to the metal which melts and coats the metal BEFORE it can begin absorbing oxygen - and doesn't burn off at or above the melting point of your metal. Plain old Borax mixed with alcohol and painted on the metal is great for soldering. But you want to add pinches as you being to melt the metal and keep adding 'til your pour it. It'll float on the molten metal so no problem getting IN the metal.
Graphite rod 1/4" diameter to stir the metal. Graphite is carbon - and carbon LOVES oxygen - more than most metals. Stirring with a graphite rod once the metal is molten will pull out oxygen.
Flame - you want an oxygen lean, gas in excess flame. The carbon in the uncombusted gas will grab oxygen before it gets to your molten metal.
Ironically, to get the BTUs you need to melt metals, you really need oxygen - as in Oxy-Natural Gas, Oxy-Acetelyne (sp?) - or in a pinch, if you don't have much metal to melt - MAP (or is it MAPP) gas
And then there are the fumes to deal with. Brass has Zinc in it. And zinc + oxygen = something you don't want to be breathing. Might try BRONZE instead - no zinc - uses tin or bismuth instead. Might want to look into Nickle Silver or "German Silver" for casting.
You can buy 99.9 fine silver or sterling silver (92.5% silver, 7.5% copper) and melt and cast it. And of course there's always gold. . .- an absolute joy to cast and work with.
If you're going to get into melting metal - in small quantities - look into getting a graphite crucible, or a simple charcoal block and grind a depression in it.
But be aware - metal working, and casting can be just as slippery a slope as woodworking. Take it from one who still has a kiln, vacuum table and pump, centrifugal casting machine, buffers, torches and a ton of jeweler's hand tools. And if you think wood is expensive - be amazed at a) how much an ounce of gold - even 14KT gold is going for - and how little volume it occupies (take the first digit of your ring finger - that's about how much volume a ounce of gold takes up.
Jesper, Denmark
Jesper, Denmark
>Steve, your main problem is not high enough heat.
Copper is diffucult to keep from impurities - the main one being oxygen. The final copper refining step is done in a furnace with excess natural gas to remove the oxygen - difficult in a home environment.
The copper wire product -1/4 inch for working into wire products- even has a limited shelf life due to alloying with oxygen.
garbage can lid
>I laid the garbage can lid on the stove while changing the bag. My son had just finished lunch but I didn't know that. Fortunately it was a glass top and relatively easy to clean up.
Post on Hand Tool Forum
A. Kapocius
>Try posting on the Hand Tool forum. Think that casting brass has come up in the past.
'Nother suggestion is to try a hollowed cavity of several insulating bricks which should be available at welding suppliers. I've seen it used to anneal and temper tools with torches.
Al Kapocius
