cleaning a fleece jacket
>Trying to stay warm in my shop I put on my fleece jacket. Kept me warm but was a very stupid idea. The shavings covered me and won't come off. It's like the jacket is acting like velcro to the shavings. Anyone have an idea how to get it clean. I'm thinking a brush might work but don't want to try that in the house. I'm finished in the shop tonight.
It doesn't look as bad in the photo as it really is. It's really covered with tiny dust as well as the bigger shavings.
Re: cleaning a fleece jacket
Carol Reed - Strawberry, AZ
>LOL! Been there, done that, John. Often. Brush and then compressed air - ah, before you come into the house. heheheh
Jim Pugh
>I brush my fleece jacket with a bench brush and blow off some of the dust with compressed air. Have also been know to put it in the dryer on fluff cycle. Oh, and I bought my fleece jacket from Ellis and it doesn't grab onto the chips like my other fleece garments do.
Steven Antonucci
I have three of them
steve antonucci
>and if I looked hard, I'd probably find wood in all of them. I usually shake them out by the collar to get most of it, and the washing maching gets the rest.
S
Thanks,, I may try the dog brush tomorrow
Thanks for the plug
>Our WC gray fleece really was a nice product. I'm just about out of them and I can't get any more. If there's any intereste, I might be able to find another good one.
My other fleeces are hopeless in the shop.
Dick Coers
>I think the dryer might work. It seems to remove any chips I have in the pockets of my shirts. If all else fails, try some blue RIT in the washing machine. Camo them chips!
Skip Beardsley------WebKitFormBoundarylsHY4+4w161B
>John,
I have one which I wear under my turning smock. It gets dust and stuff on the sleeves so I just leave in the shop next to the smock. That was I don't bring shavings and dust into the house. One reason I do that is that when my wife sees shavings in the house she calmly announces that I am going to clean the whole house.
Skip
Tery Scott
>Ive been there also ,I just turned it inside out so savings were on both sides
You could try water blasting
serious try a lint brush
Buy a hook :)
Dave Peebles Lyons, Ohio!
>Hi John,
No answer, just buy or carve a hook and leave it it in shop.
Been there, done that... very warm... very velcro like. It gets warmer the longer you turn :) When you can't fit through the door, beat it with a big stick.
Dave
tried the washer and dryer, it doesn't work
Power washing- my neighbor has one
>Do you think the other neighbors will wonder if I stand in the front yard and have him spray me. Of course it's been below freezing here for over a week now.
You made me laugh-thanks
Dick Hines
Dick Hines
>John you must have forgoten your vitamins the day you used the fleece jacket. Never and I do mean never wear something fuzzy in the shop.
I only did it once !
Don Orr
>Nearly impossible for me to get it all out. A stiff bench brush before it gets too stuck might help a little. A cheap windbreaker from a thrift store over the fleece helps a lot for me.
Oh, and once it goes through a wash/dry cycle it's pretty much permanent-DAMHIKT ;-))
Re: Give it to your wife?
Norm Smith
>John, Just hand it to your wife and tell her that you want it cleaned within an hour. When you wake up , problem solved. The jacket is probably burnt or in the garbage.
Norm
Re: tried the washer and dryer, it doesn't work
Barbara Gill------WebKitFormBoundarypTwA+e87REJF0d
>That surprises me. Get one of the adhesive lint removing rollers; that should do the job. If you can't find one, use the sticky side of clear tape or duct tape.
Now let me tell you how to dress for a cold shop.
First loose the jeans. A pair of long johns and heavy sweat pants will be your first change. Insulated underwate on the top followed by a turtleneck and several large sweatshirts. The fleece could go under a sweatshirt. Then top with a pair of insulated Bibb overalls. You can use a jacket but a really large sweatshirt will make moving easier.
Bill Grumbine (Kutztown PA)
>Tweezers! ;-)
Ric Taylor
Brass Works Great for Me
Ric Taylor
>I run my dust collector next to my lathe, and the bags are made from a material similar to flannel or fleece. As the chips fly around, many end up being stuck and embedded on the sides of the bags.
Periodically I get out my brass brush and sit down for about 10 minutes or so and brush away all of the chips. It takes a bit of a digging action, or short strokes, but it works. I have found that other types of brushes don't work nearly as well. My brush is only toothbrush-size, but I'm sure that a bigger brush would work better. Soon the bags are completely free of chips.
I've even used a small piece of 60-grit sandpaper which works fairly well at grabbing on to the chips, but the brass brush works better.
Ric
>Barb We tried the lint rollers. They don't work either. I think a good stiff brush is going to work. Usually I put a nylon windbreaker over it but it doesn't breath so I get hot. The nylon sheds the shavings.
I have a turning smock but it's half length sleeves so you still get shavings all over the bottom. Fortunately it's only for a few months that I have to put up with this. If I ever get my new heater installed it might be comfortable enough to just wear my long sleeve shirt with flannel on top of that.
I thought about borrowing one of the HASMAT suits from work. That would completely protect me but the FBI might be at my door wondering what I'm building.
Re:Same problem with microfiber towels, ....
Jamie Donaldson
>... and a wash and dryer cycle just seems to embed them deeper!
Re: John tried that routine, and now...
Jamie Donaldson
>... he doesn't have a wife! (;-D)
Chuck Engstrom
>Go to your local Goodwill and buy a selection of the cheapest thinnest nylon windbreakers they have, one size larger than your usual. Then wear one over your fleece -- chips, dust, etc just slide right off the nylon and it will add more warmth than you might expect. Plus you end up with a fun selection of logos to wear -- I'm counting on my "Sports Illustrated" to get me onfield at the Super Bowl (can I borrow something with a 500mm lens?)
Washer and dryer do seem to get a lot of dust and chips out of fleece. I could probably add some wax to my dryer lint and sell it for campfire starter.
best--
Chuck
Jim Rutten
>I don't know why but your reference to the Hazmat suit made me think of Monsters, Inc.
Vacuum, then wash.
>But I usually wear my LV smock - and if it is really cold, something other than a T-shirt under it.
