Chainsaw help please...
Marc Phillips
>Hi all
I am being offered a Stihl MS 180C chainsaw for $30
It has sat unused for a long time, but the guy said it ran fine. I cannot find anything broken or obviously wrong with it, but I cannot get it started either.
I have cleaned the plug, removed the spark arrester screen, and checked all the things I know about... chain brake, and throttle and choke all seem to work fine. I took the plug out and grounded it against the engine and it sparks when the rope is pulled. The rope is pretty stiff to pull... but when the plug is removed it turns over very easily. One part of the manual said something about a compression release button, but I don't see one anywhere...
I have read the manual, but cannot find anything about the cold starting sequence, but have tried all the combination's of choke and throttle I can think of.
I am guessing a repair place will probably charge me quite a bit to do whatever voodoo they do to make these things run.
Your opinion: Is this small chainsaw worth the $30 plus whatever a repair place with probably charge to go through it and make it run?
.... or is there something you can tell me to do that might get it running?
I already have a couple cheaper chainsaws, but was thinking it would be a deal to get a Stihl (did that rhyme?)
Thanks for any and all input...
Re: Chainsaw help please...
Keith Tompkins
Keith Tompkins
>Mark, drain the tank, and add proper mix of fresh fuel/oil mix. Replace plug, gapped to correct gap. Apply full choke with throttle wide open. Pull starter until it "pops". Move choke lever to either 1/2 or completely off, and pull until it starts. Blip throttle to release it from full throttle. If it doesn't start, either it's getting no fuel mix or crank seals have dried out, causing vacuum leak.
Gary in Zirconia, NC
>If what Keith said don't work, I'd pull the plug again and put a teaspoon of gas in the cylinder and replace the plug. Then try it again.
miracle of wd40
J Byron
>spray a little into carburator -- should help to analzye if you're getting a spark. if it doesn't combust and cycle, then check on/off switch.
Gary Evans--Tallassee TN
>Hi Marc,
If it's getting spark and it has good compression, then the problem has to be fuel. Either the carburetor jets are stopped up, the diaphragm that provides fuel to the carburetor has a hole in it, the fuel filter is clogged, or there is a hole in the fuel line. There might be one more cause that I haven't run into, but I don't think so. This isn't rocket science.
Gary
Not rocket science eh....
Marc Phillips
>Funny, I seem to be able to fix almost anything just by figuring it out or reading up about it... but never a small 2 stroke engine.
Might not be rocket science, but I have kicked more 2 stoke powered tools to the curb than anything else... never seem to be able to fix them.
I know it is either fuel, air, or spark, and maybe combustion... that information doesn't seem to help me figure out how to actually repair the chain saw though...
Tried all the suggestions...
Marc Phillips
>... and now I have blisters on both hands, am frustrated, and the saw didn't even make the slightest attempt to start.
It must be something I cannot figure out... as usual. This saw has a combination choke/off switch...you move the lever all the way up to shut off the saw. That might be messed up or.... who knows.
Thanks for trying...
Air filter eh....
Jorge Castaneda~Downeast Maine
>Marc,
If there is an air filter remove it and try starting without it, if it does star is time to get a new one.
Stihl starting procedure
>Marc, as someone mentioned, there is a specific starting procedure that must be followed. It is the same on all my Stihl chain saws and for the 180c according to the manual. Of course, you have to make sure you have spark (remove plug, ground threads to engine frame, pull and watch for spark) - try a new plug if starting is stubborn. The starting procedure:
- pull the trigger (and interlock) and push the control lever all the way down (choke)
- pull the starter rope until the saw "blips" (you feel or hear it try to fire once or so)
- flip the control lever up to the next stop (without touching the trigger)
- still without touching the throttle trigger pull the starter rope rapidly until it starts, then immediately goose the throttle
The last step consistently takes three rapid pulls on my 250, 1-4 pulls on the others. Any deviation from the procedure and the saw almost always won't start. If yours is the easy start version on the last step just pull evenly as many times as needed. My easy-start saw usually needs three gentle pulls before the mechanism releases and spins the crankshaft. It also starts every time.
As for compression release, I only have one on my largest saw and it doesn't seem to matter if I use it or not - if I don't it's just a wee bit harder to pull but it still starts the same. One saw with easy-start has a priming bulb on the side that I do press a few times.
An old-timer taught me a trick I've used with a stubborn saw in cold weather - remove the spark plug and get it hot, either by running in another saw or with a torch. Insert quickly and start. Be very careful putting starting fluid or gasoline into the carb or cylinder of a small engine - use sparingly if you must.
Re: Air filter eh....
Marc Phillips
>It looks new, but I will remove it and try.
Re: Tried all the suggestions...
>Try the precise procedure I listed in the other message. Make SURE you have spark first. If it won't start then, remove the spark plug - if the end is wet with gasoline the engine is flooded and probably will never start until it is dried out.
Dennis Ford
>One more suggestion, spray a little starting fluid in the intake (with air filter removed) and give one or two pulls. If it does not fire at all, you have ignition problems. If it runs a few seconds and dies, you have fuel problems.
Keith Tompkins
Keith Tompkins
>Marc, Pull the plug out...is it wet or dry. If wet, flooded. If dry, no fuel. If dry, do this...pull the fuel line/filter from the tank. It may be collapsed,or have a hole in it. Replacing the hose solves the problem. Worse case, pull the carb apart...easy. Check inlet screen for being plugged with fine silt that got past the inline filter. Clean with carb spray. Check diaphram while apart...may have a hole in it. Last, if crank seals are shot, the motor cannot create vacuum enough to draw fuel throught the carb...the seals cause a vacuum leak...replace seals. You may need a pro for this. Alternative...trade it in on a bigger Stihl.:)
Dave Moore
>Like John said, pull the heck out of the starter rope with the unit on full choke. Then take out the spark plug and see if it's wet. If it is, you're getting fuel, and it's probably flooded. Let it dry out and try again with the start sequence already described. If you have a spark, it should fire.
If the plug is not wet then you have a fuel supply problem.
If the unit has been sitting forever with fuel in the tank and carb from when it was parked, this would not be surprising. The carb could easily be gunked up, but first I'd check the filter on the end of the fuel pickup line inside the tank. You will have to fish around in the tank through the filler hole with a piece of bent tie wire or something and snag the fuel supply tube and wiggle it out through the filler hole. There's a filter on the end that could well be totally blocked from sitting in old gas.
You're right, if you have to pay someone to fix it, that can be brutal, but if you can rebuild carbs and such yourself it might be worth a shot for the cost of a kit. It could be the crank seals leaking too, as someone said, but that's less likely than a fuel blockage from sitting around without being cleaned out properly for storage.
I tossed a chainsaw in a pond once when I finally got PO'd at it, so I know the feeling. It's probably still there.
Husky
>Marc,
If everything fails, forget the Shtill and get a Husky Husqvarna, I forgot how the spelling goes, they are orange, you pull the blue tab, push in the decompression button and pull the cord, the saw starts every time even in subzero weather.
I have the 353, came with a 15" bar but when I installed an 18" bar, it came into its own, a sweet saw that cuts and cuts and cuts, I seldom clean it, shame on me and I do use it a lot, just about every day in the winter maintaining my wood lot and every time I prep a bowl blank.
Check the dealer's shop, you will be surprised how many Shtill's go to repair and how few Huskys.
Jorge
Bill Crommett
>Mark: You have had all the tech support you will ever get. All but one tip after you get the saw going. I use nothing but premium gasoline in my outdoor equipment because some of them lay around unused for extended periods of time and a petroleum engineer once told me that regular gas is made with "Dirty Technology" and will go sour much faster than premium. It works for me ! Bill
don lewonczyk
>You mentioned you had spark, if that is so shot a small amount of starting fluid in the air intake with the filter removed. Follow starting procedures and if it runs for a second then your carburator is more then likely your problem if your fuel filter isn't stopped up. A carb repair kit will run you $15 to $25. I would first take it apart and look it over for sticking reed valves, holes in diaphram, anything that don't look normal. I have 3 weedeaters to work on and a generator but the cows have been keeping me busy and I'm shot by 7PM. Good Luck, DonL
OK... getting somewhere now... maybe
Marc Phillips
>OK... cleaned the spark plug and checked for spark again... no spark.
Cleaned it again, check the connection with the plug wire, laid the plug on the cylinder head and got a very bright spark. Installed the plug and it started! .... ran for about 30 seconds but died when I tried to to blip the throttle. Now it wont even attempt to start again.
I checked again for spark, and it looked very weak. I took the plug out of my other chainsaw and tried that... no go, still wont start, or even try.
Put a little WD in the carb, still wont start.
I am worn out now... I really thought we had it figured out when it started and ran... but now I am still not sure what is up. It actually seems like it is both spark and fuel.
With the plug removed, and the throttle wide open, wouldn't there be fuel spraying out the spark plug hole a little?
I cleaned and reinstalled the plug at least a dozen times... no go.
It started and ran once... and that's all.
I will try it again tomorrow when my blisters pop and I am not tempted to see how flat I can make it with a sledge hammer.
Thank you all so much for the help... it really means a lot to me.
I don't really need another chainsaw, but I am frustrated that I can't figure out these 2 stroke engines... I even bought a 4 stroke weed whacker when the last one drove me nuts :)
Thanks again...
Re: Husky
Ken Oakley-Sunny St. Cloud,Fla
>I have both a Husky and a Stihl- The Husky manual states the chain lock has to be pushed forward to start the engine. I believe this is also stated in the Stihl manual. I do it on both. release the brake as soon as the engine runs.
Barry Turner
>And besides that, the Stihl manual specifies premium gasoline because chainsaws are high compression engines. A new spark plug and fresh gasoline will cure a lot of starting problems.
Re: OK... getting somewhere now... maybe
Dave Moore
>That sounds promising at least. If it ran for a whole thirty seconds then you know it's getting some fuel, and you know that the crank seals are not shot totally, though they could be leaking a little. (my guess is they're ok, but it's a guess).
It died when you opened the throttle, so it didn't get enough extra gas to go with the rush of air so as to power it up.
Starting to smell like the carb is gummed up on the high speed side of things. Not in the least uncommon with saws left sitting around for extended periods.
Could be that throwing a carb kit in there may just give you a saw that works. Though it still could be that the tank fuel filter is clean enough to tease you like this, but too dirty to let enough fuel through to actually run at high speed. I'd replace that before I got any more blisters if it was me. They're cheap and you need a new one anyway.
good luck
jared
>Go ahead and buy it for $30. If you cant get it running sell it on ebay and i can about guarantee you will double your money on it. I sold a Deere that absolutely would not run, for parts only, some of the electronics were bad and got $50 for it. Jared
Rather than premium fuel, add StaBil to gas
adrien
Texian
>Marc, One more thing to check that I haven't seen mentioned (but may have missed it). Just read that the saw started and ran briefly. Remove fuel tank cap and start the saw. Does it run now?
Bill Deak
>One more thing, Did you take the muffler off and check it to make sure it's not plugged? I had a line trimmer given to me that I couldn't get started and the guy that had it must have run too much oil in the gas mix and the screen in the muffler was plugged. If it can't breath then it'll never run.
