Pepper Mills
Pepper Mills
Pepper Mills
Sean Troy
>What is the best place to get Pepper Mill mechanisims? Thanks, Sean
Re: Pepper Mills
Re: Pepper Mills-Any place with FREE SHIPPING!
Dave (PacNW)
Re: Pepper Mills
Re: Pepper Mills
Greg Haugen
>Sean,
What kind are you looking for? Steel or "crushgrind?" The steel option is offered more places and if they're "Made in the USA" there's a 99% chance they're all made in the same place. Some places, like Rockler and Woodcraft, are usually a little more but they do sometimes have rubber bungs and shaker tops included-if that matters to you, it doesn't usually matter to me I just want the mill so why pay more?
I ordered through Packard alot, unless Craft Supplies had a "sale" or promo going on.
Never used "Crushgrind", not too much help there.
Greg H.
Re: Pepper Mills
Re: Pepper Mills
david
>To eliminate the knurled knob on the top, I use the Crush-grind mechanisms with shaft. Both Packard Woodworks and Craft Supplies sell them, with a price break if you purchase more than 10 units. One offers a percentage off, one a lower unit price, but the price difference work out to be pennies. Both offer excellent service, but it seems that Packard is closer to where you are. The mechanisms need to be glued in place.
Re: Pepper Mills
Re: Pepper Mills *LINK*
Marvin Ewing
>This company is the one that most other woodturning stores get buy their mechanisms from. They are very good to deal with.
https://www.chefspecialties.com
Re: Pepper Mills
Re: Pepper Mills
Sean Troy
>Thank you all for the help, Sean
Re: Pepper Mills
Re: Pepper Mills
GaryG in MD
>Sean,
Crush Grind mechanisms are ceramic and can be used for salt as well as pepper. They don't force you to put a knob on top. The coarseness of the grind is set once on the bottom and forgotten, rather than it changing all the time, every time you crank the top. You don't need to fool with those tiny screws when installing -- you can turn a press fit and throw in a little glue to be sure.
Look at the tradeoffs before you go with one or the other.
Let us know how it turns out, Gary
Re: Pepper Mills
Re: Pepper Mills
Tery Scott
>Lovely work David
Re: Pepper Mills
Re: Pepper Mills
Miles Lunde
>Sean,
I've found the "Premium" mills from Craft supply to be excellent mills. Drill a 1&1/16 hole, then recess it the depth of the ring with a 1&1/4 forstner bit for more grinder movement.
The new crush grinders are very good too.
Milo
Re: Pepper Mills
Re: Pepper Mills
Sean Troy
>I got a Woodcraft Gift Card for a Christmas present so I'll shop there first. then I might try the crush grind. thanks, Sean
