THE WOODRAT IS BACK!
snowed in nebraska
snowed in nebraska
snowed in nebraska
jim canning
>Ok I am snowed in, in nebraska and I just tryed to do some turning. Problem is that my shop is in the garage and man its cold out there, I lasted only about 1 hour. I need to find a CHEAP way to heat the garage, its a single car garage about 12' x 28' with a cheap garage door made of plastic. Does anyone have a good idea besides moving south.
Re: snowed in nebraska
Carole Valentine
>In my old shop, I used a couple of ceiling mounted radiant heaters aimed at me and the lathe. Worked fine for me and seem to be working well for the friend who has them now. They will only warm you and your lathe, not the whole shop or the air. Add a heated foot mat which keeps your feet warm and allows a little warm air to rise, and you should be able to turn for at least 3 or 4 hours. ;)
Barbara Gill, Remlik VA
>I use a wall mounted propane heater with a small tank outside. I have a tarp hanging so that it restricts the heating area. Of course I wear winter cloths including long underwear and insulated bibs. My hands stay warm and so do my feet. :-) I only turn on the propane when I am there.
Jim Sample------WebKitFormBoundary4+bM8dU5Q5ZoYOET
>Jim
Welcome, again, to the great Midwest in WINTER!!!! I remember when you contacted me about moving out here, about 3 years ago. The week you and Bea were looking for a house over across the river, Interstate #29 was closed from North Dakota to Missouri (across South Dakota and Iowa) and you took the back way into Omaha to the airport to get back to Washington.
I know this is a severe early storm, we are supposed to get about 6-8 inches with 40 MPH winds. Will spend tomorrow at home in Santa's
shop.
Spring is only about 3 1/2 months away.
Jim Sample
GalenV in Iowa
>Well your snow is overflowing into Iowa and everything is closing up here. Wish you would have kept it all there.
Move your lathe to the kitchen and your frig to the cold garage.
When your not turning wood you can use it to peel potatoes and apples.
Ian
>I have a two car garage, 25x28 detached from the house and uninsulated.
what I use is two heaters and my cieling mounted air cleaner.
first heater is a 85,000 btu propane bullet style heater, it will take the garage from 35 degrees to 70 degrees in about an hour. but the funes will can get to you. so I usually fire up the heater and go have another cup of coffee while it does its job. I get about 12 hours of run time from a 20 lb propane tank.
the second heater is a 15,000 btu radiant propane heater, fumes are not a problem and it can run all day, I get close to 30 hours out of a 20 lb tank of fuel.
with the air cleaner running ( its wired into the lights) the air is exchanged 8 times per hour in my shop. the shop will stay above 60 degrees for the entire day.
may not be the best way to do it but it works for me, at arelatively inexpensive rate, I only heat the shop when I'm out there.
hope this helps.
IAN
>When propane burns, the by products are water and CO2. There should be no "fumes" like with kerosene. If you are using a finish, sometimes the smell gets funny. My wall mounted unit has a sensor which will turn the unit off if the CO2 gets too high. That has not happened yet in the 5 years I have been using it.
Carole Valentine
>Yeah, I thought if you got fumes from a propane heater, something was wrong...incomplete combustion or something. I used to have a bullet heater and got no smell at all. I just didn't like the noise.
>Narrow down the area as best you can. On really cold days I put up the same tarps that I use when I'm rough turning. This makes the area I have to heat about 8x8 instead of 24x24. Of course the heat leaks out but it really does help.
I use a 15K btu kerosene heater mostly because it does a better job of heating the shop. I also have a mr heater propane that is supposed to be the same 15K btu but it doesn't heat as well. It doesn't smell however. They run out of Kerosene around here so I try to keep 2 20lb tanks of propane and 5 gallons of Kerosene. That way I can use what ever is the easiest to buy.
I'm looking at the double burner Mr heater and a 100lb tank. The 100lb tank is considerably cheaper per lb than the 20lb tanks to fill. The problem is getting the tank to the refilling station.
John - propane refill
Jeff Willaford
>Check with your local propane dealer. At a former location I almost bought a tank from Home Depot but refill was an issue. I checked with the local dealer and they installed a tank on contract for them to refill. Saved me $$ up front and no hassle on refills.
Re: John - propane refill
>I'll check. I'm going by the propane dealer later this week to ask them about costs of tanks, refills etc. It's sort of a catch 22. I can't afford to work in the shop unless I sell work and can't make work unless I put out the money for the heating.
Jeff Willaford
>Quartz heaters and they work very well.
Texian
>Any chance your clothes dryer is in the garage?
Dick Hines
Dick Hines
>I heat with kerosene. I think the heater I have 20K. I picked it up a a yard sale years ago for $10. If I run it as low as it will go I can get the shop up 65 on the coldest days. I start the heater out side so the the fumes burn off and then move it inside. I change the wick every fall so it gives off no smell.
Right not I am heating a 25"x25" space. I am going to devide the shop after Christmas so I will be down to 15"x25". It should be down right tostie then.
Don Evans
>John
I don't know about where you are but here a person has the option of several dealers of propane to chose from. SHOP AROUND as the price is not regulated and varies greatly among dealers.
I'm talking about as much as 80 center per gallon!!!
Here, all dealers install a tank for you with no charge but it is their tank and no one else can put propane in it. So you are stuck unless you have them remove the tank and another dealer install his.
There are no contracts however, with most, so you are not stuck with them for a year as example.
They do charge for connection, copper, fittings etc.
Also beware that some of them will give you a price but that is for the first fill up ONLY. Then the price changes naturally it is much higher after the first tank full.
Price changes depending on weather which dictates demand, so I call and get filled before the cold hits, saves some once a year. Paid $1.98 a gallon last month.
Last time I called around price varied $1.39 from my dealer to as much as $2.16 for the most expensive guy. That was couple of years ago and during September.
Don
Ric Taylor
My $1 Solution
Ric Taylor
>I put an electric space heater on the table next to me on cold days, that I found at a garage sale for a dollar.
But then, I live much further south. On the other hand, I did live in Nebraska for nine years, so I can relate.
Ric
Re: My $1 Solution
>Jim
I have a small radiant heater that screws to the valve of a 20# tank, it heats only the area that it hits, not the air. Bought it at a local farm store, sure beats freezing. 20# tanks are around only it takes the new style safety valve on them.
Jim Sample
Roger in MO
Roger in MO
>John, I bought a used 50 gallon tank for my 24 x 24 shop. The tank guy will fill about twice each winter. My wall mounted heater keeps shop about 50 degrees all the time (turned as low as it will go) since I have water and drain in the shop. I supplement heat when working with a wood stove in another portion of the building or even with an oil filled electric heater if I'll only be working for an hour.
Its 15 degrees and very windy today, headed to zero tonight, and I turned the heater up slightly to maintain 50. Located east of Kansas City
Roger
