Looking for Woodburning Tool Advice
Joe Pack
>Also posted on the Message board, but posted here in case some of you don't read the other...
I'm looking to try my hand at decorating some of my woodworking using a woodburning tool. What features and/or attachments should I be looking for in a decent quality woodburning tool? Any brands/models that you would recommend over others?
Re: Looking for Woodburning Tool Advice
Rick Allen
>If you can get some hands on instruction you will be way ahead of the game. Look for a class at your local woodworking store (Woodcraft or Rockler perhaps a county adult education program).
Re: Looking for Woodburning Tool Advice *LINK*
Don Evans
>I think each unit made has some pro's and con's.
Make sure the unit has a minimum of 100 watts output.
Understand that the units that allow you to plug in two pens at the same time will ONLY heat one of them at the same time. It is a slight advantage sometimes to not have to fiddle with unplugging and plugging in though.
I purchased several years ago a Detail Master Sabre and converted it myself for plugging in a second pen, pretty easy to do if you have some electronic ability.
Almost any make of pen can be used on any unit you purchase but you will need an adapter to use a Razor pen on a Detail Master is one example.
Everybody uses different numbers for their pens so it's hard to give numbers for what pen should I get first.
However, You will want a WRITING TIP PEN (in Details # that is a 6A.
There is a lot of information at the link below for Nedra's site.
Don
Nedra Hall
Meant Nedra Denison
Don Evans
>That should have been Nedra Denison.
Carol Reed - home in Strawberry
>I attended an all day demonstration with Molly Winton yesterday. It was great. She recommended the Burnmaster unit, calling it the best bang for the buck. And she recommended making your own pens and tips. She has booklet available at her demos. Email her for more information. She should be home sometime tomorrow. TurningMaven@hotmail.com or http://www.turningmaven.com
Dick Hines
Dick Hines
>I have some pens mde like Molly's and I like them better than the store bought ones. To start the handles don't get hot. You can also make them to fit your hand instead of haveing to use the factory made ones that are one size fits all. Not.
>Joe By the best unit you can. I purchased one of the less expensive brand name burners. I believe it was the Colewood. It was there bottom of the line. It did burn. I had trouble controlling the burn when drawing lines or writing my name. I purchase the Optima burner and my pyrography improved dramatically. I can recommend that but I think any of the top of line models will do well.
ebd
ebd
>Make sure to get a burner with very good insulation at your fingers. The one I got is OK for the first little while then gets HOT. It only has cork insulation and not much of that. I'm going to try and modify it as soon as I can find something that will work.
Steven Antonucci
You can make one for under $20
steve antonucci
>If you own a automotive battery recharger, you can make one out of common parts. Charlie Belden wrote up an article based upon materials I helped him with.
Steve
Re: You can make one for under $20
Bob Rogne
>Steve
Where did he publish the article? On paper or on line?
Bob Rogne now is Mesa, Az.
david
>In September Graeme Priddle did a demo here and in the hands-on class se opted for him to show us how to put together a burning unit using a NAPA battery charger and he provided some parts for the pen at nominal cost. Total cost under $100, and the charger cost around $65. The burner has a lightswitch dimmer for control and is very robust. The modifications to the charger unit are very minor if you know which wires to cut and connect. After I made my burner I felt I needed to upgrade the gauge on the wire to the pen--it can get warm. Think some details are on our club website: honoluluwoodturners.org
