Atlas metal lathe question
Terry Quiram
>I have an Atlas metal lathe that has a 6" swing. Right now it has an independant 4 jaw chuck and I want to go to a 3 jaw self centering chuck. As near as I can tell the spindle size 1 1/2-8. My question is does anyone know for sure if my quess is correct?
Re: Atlas metal lathe question
u
>Try this link ,go to the drop down on lathes. http://www.practicalmachinist.com/vb/index.php?ubb=get_topic;f=17;t=001495;p=0
Thanks
Terry Quiram
>Thanks for the link. I did some searching and found that the size is indeed 1 1/2-8. I also found tips to mounting a chuck to a face plate and I think that is the way I will go instead of buying and using an adapter.
Re: Thanks
u
>Youe welcome from Indiana
Re: Thanks
u
>Fat fingers Your welcom
Re: Thanks
u
>Anyhow you get the message
David Belser
>Terry - I just went through this exercise. I ended up buying a Oneway Stronghold with a 1 1/2 X 8 insert and a set of flat jaws. Primarily because it was the cheapest way to go. If I'd felt like I could spare another $200 - I would have bought a Bison 4 jaw self centering chuck with 2 part jaws from MSC. The point of the flat jaws or 2 part jaws is that you can then make your own custom wooden jaws. The Bison has the advantage of being usable for both metal and wood.
I also got a 1 1/4 X 8 insert for the Stronghold so that I can mount it on my wood lathe by swapping the insert. I've already used it this way a few times.
What are you planing on doing on your Atlas? (I've got a South Bend model A)
- Dave
Roger in MO
Southbend model A?
Roger in MO
>David, What is a model A on a South Bend?
I have a 9" bench model South Bend with a tag that says War Production Board. Vintage must be WW II. No quick change--I have to pick gears to cut threads. Flat belt driven with jack shaft.
Its a pretty good old machine. I've used it for turning minature brass pulls to repairing farm equipment to building components of a front end tractor blade and small towable back hoe.
Roger
Don Evans
>I have a Logan 10" metal lathe that my Dad purchased new, made in 1945. I rebuilt it, parts are still available from Logan in Chicago for it, imagine that.
I ordered a SuperNova chuck to use on mine. Teknatool made a "z" body it was called that they threaded for me in 1 1/2" x 8. I also have an insert that will screw into that and fit my Oneway 2436 m33 thread. So I can use that chuck on both lathes also.
Don
Axmister
Jorge Castaneda~Downeast Maine
>David,
If I remember correctly the Bison is identical to the Axminster, I think made by Bison.
For whatever is worth...
Jorge
Terry Quiram
>Dave
Last year I fell into the deal of the century. A friend of my brother was cleaning up his FIL's basement and offered the lathe and anything related to metal turning to my brother. Borther didn't want it and offered it to me. I got a 12" lathe and half a truck load of stuff with it. Unfortunatly it didn't include any of the gear changes for thread cutting. Included in the extra stuff was a 3 jaw chuck and a faceplate. I am going to see if I can machine the faceplate to mount the chuck. The things I am making do not require the accuracy a 4 jaw independant chuck.
So far I have turned a handle for the allen wrench to adjust the 4 jaw chuck. Drilled rod for the purpose of making hollowing tools with cutter bits inserted in the end. Tapered the ends of rods that hold termite tools and turned down a pair of kickback risers to fit my motorcycle.
I need to find a retired machinest to teach me how to use this great old lathe.
Re: Southbend model A?
David Belser
>Roger - now you made me look a little harder.
I had assumed that mine was much older based on serial number. I guess South Bend changed from straight numbers to a number/letter combination.
After some online digging last night, mine is from the late 50's early 60's. It's in excellent shape and has: quick change gearbox, large micrometer dials, thread counter. The drive is flat belts to the spindle with an electric motor on a swing arm setup behind it.
I was also very fortunate that it came with a number of chucks, a set of collets, a turret for the tail stock, a 4 position tool post setup, dressing/grinding motor that mounts to the carriage *and* a milling attachment!
I just bought the 4 jaw self centering chuck so that I could mount wooden parts easy and change between this lathe and my Nova.
- Dave
David Belser
>I'm in the same boat.
I finally turned my first metal - with out any assistance. I needed to slightly enlarge the insert for the Strong Hold chuck.
RE. the chuck - the Bison chuck is 4 jaw self-centering (not independent) the same as a Strong hold wood turning chuck but less sloppy because it's for a metal lathe.
The work I do (and currently focused on) requires pretty precise machining of wooden parts. I mount "blank" material on the chuck jaws and turn whatever shape is best for holding the part.
Check my website - I'm using the metal late to do some of the work on my "Cryptex Tantalus" and I'm developing a more complicated "Safe Box".
I'd be interested in talking to other turners that are using metal lathes for wood work.
- Dave
