The Shrinkage Thing - And Uniform Wall Thickness
charlie belden
>Uniform Wall Thickness? Why?
Common Knowledge is that wall thickness of plates, platters, bowls and the various versions of hollow forms should, ideally, have uniform wall thickness - to minimize warping - and cracking/splitting. This is especially true if you turn �green� wood since �green� wood changes dimensions far more as it dries than does �dry� wood.
But, thinking about it, it seems as though what you�re after is uniform shrinkage, not uniform wall thickness. I�m putting together some info, spreadsheets and illustrations examining shrinkage turners often have to deal with and will have that stuff available on my personal site in the next few days. But before I do that, I�d like to have a discussion about an overview of the subject to see if I�ve overlooked something important or if any of may assumptions are wrong.
For purposes of discussion, I�ve done some illustrations to use in what I hope will be a discussion of the affects of wood shrinkage on a hemispherical bowl, just to keep things simple, turned from a typical �half a logette� blank. (See attached PIC). Hope to do something similar for end grain hollow form such as lidded boxes.
Figure 1 shows the bowl�s orientation within the Half Logette starting point.
Figure 2 shows how the turned bowl is expected to change in terms of three views - top, end grain end and side.
Figure 3 shows how how the bowl will shrink �acrossed the grain� due to Tangential Shrinkage and shows that the AMOUNT of shrinkage as you go down from the rim to the bottom of the bowl progressively decreases, thought the Percent of Change remains at the Tangential Shrinkage PERCENT.
Figure 4 show an End Grain View and a Side Grain view of the bowl, with the resulting Radial Shrinkage that would result from going from �green� to �dry�. The farther you get from the End Grain end the more the rim will dip when viewed from the side grain side.
Comments, suggestions, discussion?
