Bottle stopper
Bottle stopper
Roger in MO
Bottle stopper
Roger in MO
>I've not been satisfied with the transition between the metal of the stopper and the wood surface where it attaches. If the stem hole was off slightly from perpendicular, the metal didn't seat properly. Also it seemed difficult to finish the very bottom of the wood.
For the stopper in the pictue, I counter bored the bottom of the blank 3/4 x 3/32 as the first operation. I then drilled and tapped for the mandrel. I machined a brass washer about 1/4 thick x 3/4 diameter (from a stock bushing) and placed it on the mandrel before threading on the block. This allows room to turn the bottom face to the outside diameter of the stopper and to finish it. The very top of the stopper face ends up being buried in the counterbore.
The stopper if from Ruth Niles. The wood is Bocote.
Re: Bottle stopper
Roger in MO
Re: Mandrel and brass bushing
Roger in MO
Re: Bottle stopper
Re: Bottle stopper
Barbara Gill, Remlik VA
>I wonder what was going on. I drill and then make a slight recess with a parting tool to accept the bottom of the stopper. I then shape most of the stopper and part it off. I then thread the piece on the mandrel I bought from Ruth and finish off the stopper. There is no problem with the hole not being centered or the stopper not seating correctly.
Re: Bottle stopper
Re: Bottle stopper
Barry Turner
>Drilling the blank on the lathe would assure the hole is drilled straight. Ruth sells a mandrell that also taps the blank when you screw it on. It's well worth the $25 that she charges. If you drill and tap the hole straight, and make it the same size as the stopper fitting, it should not be necessary to turn a recess or finish the bottom of the blank. Doing this is really not necessary and just gets a little too fiddly and time-consuming.
Re: Bottle stopper
Re: Bottle stopper
Carole Valentine
>I think they look more "finished" with a tiny recess that the stopper fits neatly into instead of it just butting up flat to the wood. I cut a couple of groves in the flat of the recess to stop any trace of the epoxy that might get ideas of oozing up when I screw it together. I also sign my stoppers on the bottom, so I like having that little <1/8" rim outside the steel. I use Waterlox so finishing the bottom rim is no problem. Fussy...yeah, probably, but that's just me.
Re: Bottle stopper
Roger in MO
Re: Bottle stopper
Roger in MO
>Thanks for the responses.
I'm making these from 1 1/2 stock. My other chuck won't hold that size securely on the flats. I chuck on the corners which works o.k. for drilling but I'm not keen on facing off the block held only on the corners. I counterbore and drill on the lathe, mount on the mandrel, bring up the tail stock, and form complete.
If I find some 1 3/4 stock, I'll try partial turning while still in the large chuck.
Roger
Re: Bottle stopper
Re: Bottle stopper
keith zimmerman, Normal, IL
>I turn all my stoppers from 1 1/2" stock. This size fits nicely in the #2 jaws on my Talon. I put the corners between the jaws so I have grip on all four sides. I bore the hole on the lathe and tap it by hand. I also turn a sight recess with my skew and have a small rim around the bottom that the stopper fits into. I really dislike the look of flat wood against the top of the stopper. It doesn't look finished to me, especially if I can see light between them.
I finish my stoppers with Hut Crystal Coat, allow it to cure, then buff with carnuba wax on the Beall buffing wheel.
If it isn't obvious, I too, use Ruth's stoppers. They are selling quite well this year.
keithz
Re: Bottle stopper
Dominic in Bucks County PA
How about using a spur chuck?
>Roger,
Back in Winter of 2008 an article I wrote about making a shop built bottle stopper chuck appeared in "WoodTurning Design". This chuck was so simple to make that it took me all of 10 minutes to fabricate. After I made it I was able to turn a bottle stopper from start to finish in record time. If sized correctly, the spur chuck allows you to even turn a recess at the base of your stopper blank. And no re-chucking is involved.
bottle stopper spur chuck
Basically you need a piece of round bar stock. The bar stock should be roughly the same diameter as the stud on your bottle stopper. Then you grind angled flats on the end of the stock to form a point. Then you use the corner of your grinding wheel to give it it's "devil ears". Mount this in you drill chuck (installed in your lathe's headstock). Now get your turning blank and drill a hole just a hair smaller, or EXACTLY the dia of the round bar stock you made your bottle stopper chuck from. Make the hole about 3/4" deep. Take the now prepared blank and install it on your spur chuck. Give it a rap with a wooden mallet to seat it. Now bring your tailstock and live center up to end. Rough out the blank and when you get to the point where it's time to final turn, move the tailstock out of the way.
Re: Bottle stopper
Re: How about using a spur chuck?
Ruth Niles
>If anyone needs more pictures of Dominick's spur chuck, email me and I can send you a few with all the necessary specs and how-to.
Hi Dom! : )
Re: Bottle stopper
I use Talon Chuck #2 Jaws
>I too use 1 1/2" stock. I just round the corners so the jaws have a place to seat. You don't need round with round tenon.
Re: Bottle stopper
Leo Van Der Loo
Leo Van Der Loo
>I've only used Ruth's SS stoppers, with the smooth tenon, I also use something like Dominic, just not the sharpened ends but with a tight fit.
Drill the blank and finish the base, however I happen to feel like, then shuck the alluminium shaft and stick the blank on it, turn, sand, finish,........... done.
Re: Bottle stopper
Leo, nice wood in the background! ; )
Ruth Niles
