Masur birch box....
Masur birch box....
Mike Stafford
Masur birch box....
Mike Stafford
>A while back I mentioned that turning an expensive piece of wood always provided me with a bit of anxiety because I did not want to screw up the piece of wood.
Here is the box I turned from the piece I had concerns about. It is Masur birch, 2 1/2" tall and 3 1/2" in diameter.
I do so love to turn this wood. It turns so predictably and sands and finishes beautifully. It may be the best wood out there for boxes as the insect trails which give the wood its distinctive appearance are so randomized that grain match is no longer a consideration.
Your comments appreciated....
Re: Masur birch box....
John Frazee
>Thats beautiful, way to go.
That one is very nice...
jake Niedling
>Excellent. You did that piece of wood justice. I would keep that one.
Mike Stafford
Re: That one is very nice...
Mike Stafford
>Thanks Jake. The wife did just that...she added it to her collection.
Lucky wife
Paul Zerjay
Cyril Griesbach
>Another beauty, Mike. Silly fears are now gone forever right?
Mike Stafford
Only until the next piece of wood....LOL
Mike Stafford
Beautiful!
keith zimmerman, Normal IL
>I have a hollow form blank on my shelf that I need to do. What did you use for a finish on your box?
keithz
Mike Stafford
Re: Beautiful!
Mike Stafford
>Thanks Keith.
This is finished in multiple coats of Qualalacq thinned 50% applied with a section of paper towel as evenly as possible, wiping off the excess and then rubbing it down between coats with cheesecloth and fine steel wool. About 6 coats topped with microcrystalline wax gives a nice soft finish.
david
>Very nice piece, Mike. I do like that form ;-).
Elegant Form winner
Matt Overton
>Mike,
where was this in the elegant form contest? Great vision for a beautiful piece of wood.
Mike Stafford
Re: Elegant Form winner
Mike Stafford
>Thank you Matt.
I did not consider entering a box in the Elegant Form contest. Boxes are usually overlooked by the "experts" unless they are in some way burned, carved, dyed, painted, sandblasted, or otherwise changed to obscure the wood. I am hesitant to do any of those things to a piece of wood.
