REAL MILK PAINT
A strange thing happened at the feed store...
Scott Burr in Ben Lomond CA
>OK, OK, I know my lathe is not even running yet, I have to lathe tools but...
There I was getting some kitty litter, and I heard chain saws. Nuthing new around my parts...
I asked what was happening when the owner said he was having a walnut tree removed. I went Hmmmm... and asked how big it was. He lead me out to the tree that was being cut down as we spoke. I have no clue what I'm doing when it comes to gathering fresh cut wood as all of you do combined so I asked if I could have some pieces. He said the guys cutting the tree down were entitled to it. He inquired if I could have some and I walked away with this. No questions asked.
So I have these fresh cut walnut pieces. Branches are 6" dia. the crotch piece is 12" dia.
What should I do with them?
Are they work keeping?
If so I know to paint the ends to slow moisture, with what?
Also what about the bark?
Alas more nubie questions.
Re: A strange thing happened at the feed store...
Bill Crommett
>Scott: First off cut the large piece in two right down the pith of bothe the main piece and the branch. Seal the ends and put it away where it is cool in the shade and wait until you learn about turning big chunks. A crotch makes beautiful turnings, but you will have borrow a big lathe.
You will get more advise from this forum, so hang in there !
mike neitzel
>Lucky find, nothing beats free wood!
Not much heart wood there?
Maybe you should have gotten larger chuncks.
I always get the pith out...
cut each log in half length wise, remove pith with additional thin cut.
rough turn to inch+ thick,wax or not...
Microwave to quicken drying, or let rest for a year.
Those logs will crack if not end sealed, or rough turned.
Good luck!
Re: A strange thing happened at the feed store...-
Emmett Manley, Lakeland, TN------WebKitFormBoundar
>This sure does not look like the black walnut I know and love. Either it is some other California tree (English walnut?) or there is so little heartwood present as to make this wood essentially worthless. The sapwood for black walnut is poor wood.
I have so much black walnut available that I rarely seal the end grain, but you probably should. My experience has been that this wood end checks but usually does not experience major cracking.
Good luck.
------WebKitFormBoundarydLwik3M+7AgAIcvg
Keith Tompkins
Keith Tompkins
>Looks like a chokecherry to me....?
walnut sapwood
adrien------WebKitFormBoundaryiAvVzqkgDx+9LJtI
>I agree, the wood doesn't appear to have the dark heartwood seen in walnut. But I don't think the sapwood is "poor". It can make an interesting contrast with the dark heartwood, though it tends to darken over the years. Nakashima would sometimes put a light streak in his chair seats, or with the natural edge table tops have the lighter edging.
Not walnut
Carole Valentine
>Looks like cherry to me...both the wood and the bark.
Well I don't know what to tell you, but...
>Nuts were falling from the tree. That's why it was being cut down. It was making a mess and cloging the rain gutters with nuts, leaves, etc.
Not that I care, I know it's walnut.
Now can I get some help with my original question?
Thank you!
Scott
Re: Well I don't know what to tell you, but...
Mike Jones
>If walnuts were falling from this tree, it would be a walnut tree...but not a BLACK walnut. Likely is an English walnut. If you can't get to these pieces for awhile, put them into a garbage bag to keep the moisture in. English walnut is, generally, not as desirable for turning as the black walnut. If not too late, check the BASE of the tree for the color you want, not the branches. In California, it is most common to graft the English onto a black walnut root ball. The area of the graft can produce some wild looking grain.
Anchorseal, etc.
Doc Green
>Scott,
The stuff most people use to seal end grain is a white, milky-looking wax emulsion that you apply with a brush.
It is known as "Anchorseal," or "Green wood end sealer" from Woodcraft, or "Sealtite" from Klingspore. It doesn't seal the wood completely but lets the moisture escape very slowly.
Good Luck, ~Doc
Carole Valentine
>It's been my experience that logs with large areas of sapwood tend to self-destruct despite most efforts to prevent it. The sapwood seems to dry at a much higher rate than heartwood so it cracks. It also goes punky much faster than heartwood. My advice would be to turn it quick and turn it thin. Seal the ends and leave the leave the bark on if you are not going to use it right away but be mindful of little piles of sawdust - that means the critters have taken up residence. Is it worth keeping? I seem to remember not so long ago that ANY wood I could make shavings from was worth keeping, if only for practice!
Dick Hines
Dick Hines
>It could also be butter nut. I don't what the butter nut nuts look like though.
Barry Elder
>IMHO, and with respect to those with more knowledge, fruit trees throughout the USA have had most of the heartwood bred out of them because the sapwood feeds the fruit. Here in Florida the citrus trees have no heartwood at all but the fruit is the best in the world. I would think the same would apply to the California Walnut trees. But then again, maybe not!
Thanks everyone. A few more questions...
>More nubie questions. As stated I have no lathe tools as of yet. So if I sum up what I've been told, I should:
1. Cut all the pieces in half and remove the pith.
2. Seal the ends with sealer (would paint work?)
3. Leave the bark on for now.
4. Store in a cool dark place (will under the house work?)
Thanks for you patience,
Scott
Re: Thanks everyone. A few more questions...
>Yes, cut them in half lengthwise and remove the pith.
Yes, seal the ends. One of the prepared sealers may be best. You can order Anchorseal by going to UCcoatings.com. (No affiliation) A gallon is a lot. You can also melt paraffin in a double boiler and dip the ends. (Be very carefull, hot wax is dangerous and will burn.) You can paint the ends but it probably won't work as well as the wax based sealers. You can also use Elmer's (White) glue. Probably better than nothing but not as good as the wax based sealers.
Leave the pieces as long as you can. If you have a piece long enough to make three bowls and the ends split in spit of your efforts, you may be able to cut half a bowl off each end and still get two. If you cut the blanks close to the right length, and the split, you lose all of it.
May not want to put them under the house unless it is airy and fairly dry. If it is to wet, they may not dry and may get moldy or even rot. Perhaps a pallet and a loose cover.
Get some lathe tools and start turning. I'm a packrat and hate to lose any, but it is wood and it grows on trees.
>Anchorseal is horribly expensive and paint works well as a sealer. Think about it, the function of house paint is to keep moisture out of your wood, so it should keep moisture in your wood (losing moisture slowly). Lowe's and Home Depot usually have gallons of mis-tinted paint available for $5 per gallon -- or, you probably have some old paint in the garage.
I believe the best use of this wood is as practice wood for the tools you will have soon -- better wood will come along.
Jim Pugh
>Butternuts laying on the ground look like black walnuts - same green husk; black mess as the husk decays. The actual nuts are longer than walnuts, crack easier and are very rich tasting - hence the name - butternut. First cousins of black walnuts. Wood is a tannish color.
