Lathe Height Question
>I have my lathe set up with the shaft at about elbow height. If I bent my arm at the elbow so that my forearm is level and parallel to the floor, it is level with the shaft of the lathe.
I turn mostly bowls and hollow forms.
When I turn a lot, I get a snarled muscle in my back under the shoulder blade. Not sure this is related to turning, but maybe so.
So, would it help to change the height of the lathe? Higher or lower? Higher would be easier. I built a very sturdy cabinet under it with drawers. It would be "H" to cut it down. Human growth hormone would be easier.
Any suggestions?
Re: Lathe Height Question
Wally Dickerman in Arizona
>Barry, the "rule" about elbow height is aimed at spindle turners. I do a lot more HF turning than I do spindle turning. I have my spindle height set so that I can comfortabley stand upright when hollowing. Much easier on the back. That height turns out to be about 3 inches higher than elbow height. I suggest that you temporarily raise your lathe to try it out.
Wally
What Wally said. It worked for me.
Jeff Willaford
Peter Charles Fagg (UK)
>Wally and myself both have the same set-up, it is rare for me to do any spindle work and with the lathe at a similar height my back is always saying thankyou after each days turning.
In most situations I would say that lathes should be adjusted upwards to match the turners needs not what some of the so called experts say!
Regards, Peter.
>Mine is a bit higher - not 3", but maybe 2". I do mostly spindle work and the closer it is to my eyes, the happier I am :).
>Mine is about 1" higher than my elbow.
Sean Troy
>I have my lathe raised 6 inches higher than the average hight or what one would say is the bent elbo height. Helps my back alot.
Re:Wally has it right, as usual! (;-D) Old age....
JamieD
>...make one smart, as long as you can remember what you were doing right! Now, what was the question.....?
Nipple Height
Jorge Castaneda~Downeast Maine
>Barry,
I like it high, at nipple height I don't bend and have little back or arm problems,
I turn mostly platters and bowls and some spindle work
Re: Nipple Height
>Jorge, I live in a retirement community. Your formula works for us guys but we have some lady turners. I've heard that average bra size here is 34 long.
Wally
Mike Stafford
Mike Stafford
>I have my lathe mounted so that the spindle center is midway between my elbow and my shoulder. Since I turn boxes far more often than anything else that height is for my comfort when I am hollowing boxes. I don't have to bend over to look inside as much.
That height does not seem to make much difference as far as turning other things so I guess it is what you get used to....
Gals, Help!
>Oops! Wally,
I was not thinking on the better part of mankind,
lets hope the gals tell us their preference.
Jorge
Bill Blasic
Re: Gals, Help!
Bill Blasic
>Wally,
You are truly funny, my first laugh of the day!
Bill
Cyril Griesbach
>That one cracked me up, Wally.
Steve Kubien
Re: Nipple Height
Steve Kubien
>That's a deep hole you are digging Wally. Good luck getting out!
Re: Nipple Height
Harry in Beautiful Downtown Kulpsville
>There was a lengthy discussion on this subject on WOW (I think) several years ago. After someone suggested nipple height, one of the women said she would not turn on her knees!
