How do you hold a ...
Ed Moore
>3/16" square bit in a chuck with pin jaws? I need to put tenons on square tool bits for hollowing tools I am making for my ornaments class at John C Campbell Folk School in November. Since the bits are too small to be held by the chuck I put 4 cut-offs of 1/4" round steel on masking tape and put them inside the chuck with the bit at the center. Effectively, you are holding a square with circles on each side. The 1/4" rod pieces are held by the grooves in the jaws and the bit is centered nicely.
With the lathe reversed and slowed, I use an air cut-off tool to shape the tenon. Before I turn the lathe on I smooth each of the four edges a little with the cut-off to make the process a little less bumpy.
When I get the tools completed I'll post a picture of the set.
Note: We have some places left in the class and would welcome a couple more.
Re: How do you hold a ...
alternate solution
Jim Pugh
>Another way to do what you need is to get a drill bit that is sized close to the dimension of the tool bit across diagonal corners. You may still need to break the edges of the tool bit a shade. A set screw will hold the bit but it. What I have done and it works fine for me. It also allows one to slide the bit in/out as desired.
Steven Antonucci
I don't understand what you are trying to do?
steve antonucci
>I looked at it twice and I don't understand what you are trying to do? I understand that you are making the holding capacity of your chuck smaller to hold a square bit, but you lost me after that...
perhaps a picture of the finished product would help?
Steve
Putting a 1/8" round tenon ...
Ed Moore in SW VA
>on a 3/16" square tool bit.
The bit is not glued in the shank.
Most things to hold a small diameter piece have three jaws, which makes it awkward. Using the cut-offs provides a way to hold the small square tool bit.
Ed
Steven Antonucci
I just approximate them on the grinder
steve antonucci
>If I am holding them with a set screw, I don't fuss that much. I knock off the corners and make the holes a little bigger. screw holds against the small flat.
Or glue em.
How are you keeping them in?
steve
P.S. Ellsworth has a small wooden jig that he uses on his grinder that spins against the rotating wheel- he was making tools for Crafts Supplies and had an assembly line mentality to speed things up. If I recall correctly, he needed to make 60 tools that weekend, which he did with very little bother...
I plan to use ...
Ed Moore in SW VA
>JB-Weld or epoxy to hold them in. I also have some metal filler (aluminum) that might work. I'll have to try it out first.
Ed
Jacobs Chuck?..
jwoodwright
>Ed,
How about using the Jacobs chuck in your lathe or on the drill press?
Penn State has a live Jacobs chuck they use in the tailstock. This would be great to hand hold at the grinder, the chuck would spin and you would get a more concentric grind... John
Re: Jacobs Chuck?..
Barry Turner
>I think Ed was trying to say that it's hard to hold something square in a 3-jaw chuck, which a Jacobs chuck is.
>Why not just make a a little block you can chuck in the four jaw chuck with a 3/16" square hole? It could be a jamb chuck or you could make it a collet so that the pressure from the chuck would close it.
Barry, I was about to make ...
Ed Moore in SW VA
>such a device when I saw the cut-offs of the 1/4" round steel. Actually, since the cut-offs are held in place by masking tape my system works pretty well. Another idea would be to use a little CA glue to secure the cut-offs to the jaws.
Ed
Re: Barry, I was about to make ...
Barry Irby------WebKitFormBoundaryooeciKESVDEAQ+9S
>You did what I would have done. My thought process is "How can I do this with the stuff at hand?" Just glad you weren't eating a cheese sandwich at the moment.
I probably would have chucked a little piece of wood about 3/4" square, drilled a hole a little over 3/16 with a Jacobs chuck in the tail stock and heated a piece of the 3/16 stock and "Burned" it in.
Texian
>You could make a jaw set from some rusty, scrap angle iron like this one, made to hold some small square blanks for finial practice.
Dick Hines
Dick Hines
>I would just glue them into the tool with thick CA, ED
