Have a question? Ask Woody!
Parting Tool question
Scott Burr in Ben Lomond CA
>As I make my shopping list I'm looking at... you guessed it parting tools.
What's a good width to use? I'm thinking the thinner the better (up to a point).
I'm looking at 1/8" ones, particularity the P&N one (handle less) also Henry Taylor's offerings. Any comments on the P&N's?
Thanks for all the great help so far! I just pulled the trigger and ordered 4 of Doug Thompson tools.
I'm getting excited, I should be able to turn something soon!
Re: Parting Tool question
david
>I saw a Ray Key demo in Provo, and he used a 1/16" parting tool with a groove on the side where the point is. The point was on a bevel of about 45 degrees. The blade was 1/8" thick, but narrowed down to 1/16" for the last 4" to the point. The closest tool I saw like that came unhandled from Ashley Isles. To sharpen, you just put the bevel to the grinder. This is my favorite parting tool.
Don Evans
>Just fyi, I've never put my 1/16th inch parting tool on the grinder except to modify the tip once.
If you get a course or medium EZE Lap diamond hone, about $5.00 and use it on the point pushing it up the bevel towards the handle doing it often (after each parting). It will last you much much longer.
Don
>For general use I like a thicker parting tool. I use a 3/16 and 1/4" tools a great deal. I really only use the thin ones for parting of box lids where the grain needs to match.
I use the parting tool for making short tenons, for creating the dovetail for the chuck and parting down to dimensions for duplication work. I could not do any of the three with a thin tool.
My choice is a diamond parting tool. You can cut deeper without burning. The only downside is a little more care is necessary when sharpening to keep the point at the thickest part of the parting tool.
Ed Moore in SW VA
>In addition to a 1/16 inch thin parting tool, I find that I use a 1/8 inch 2030 steel parting tool from Packard quite a bit. This is especially true when making perches for birdhouse ornaments and earrings.
If I could only have one parting tool, it would be the 1/8 inch tool.
Ed
Bill Howatt
>I wouldn't be without the standard diamong parting tool which is around a 1/4" wide at the wide point of the blade.
BUT, I also have a 1/16" wide Firmager parting tool from LV and I also wouldn't be without it. IIRC, it was supposed to have a delicate groove in it but I don't bother worrying about it and it long since ground away with normal sharpening.
Bill
Roger Dunn
Roger Dunn
>I saw a Mike Hosaluk demo in Portland a few weeks ago and he uses Carving knives picked up at garage sales for little money. Then he grinds it so the thicker back edge has the parting edge.
Save yourself some $ and be like Mike.
Ed Moore in SW VA
>Roger,
I assume that Mike bought table carving knives, not wood-carving knives.
That's a clever idea.
Ed
Russ Fairfield
>A "chef's knife" makes a good parting tool.
TomCollins
>Also helps to keep riff raff out of the shop
TomC
Re: Parting Tool answer
GalenV in Iowa
>Being newer to turning:
After buying a cheap PSI thin parting tool and finding it warped in both the length and height I made this one out of a 1/8" thick stainless steel rigid putty knife. Works fine. After this one I cut another to a full point and not like the one shown.
About $5!
Pardon my fancy photo box "cheap scanner"
Galen
Now buying more Thompson tools and a few lesser quality, but pricey, Sorby.
>I have a 1/8". I also have a 3/16" Diamond parting tool. I also have a bedan. I usually use the 3/16" Diamond parting tool.
Bill Crommett
>Scott: I have some 1/16 in. sawmill bandsaw blade stock that will make a great thin parting tool if you have the ambition to make your own handles. Send me your snailmail address and I will send you a 6 in piece.
Bill
Texian
>Bill, May I have some too?
Roger Dunn
yes - old chef's knives
Roger Dunn
