small to mid size lathe
rick pixley
>My wife is insistant that we get another lathe,something in the midrange to small..I've looked at the Jet 1442,1642,the dvr,and even the laguna...My question is that the jet 16 has a 3 ph motor and says 110 only,where the jet 14 can be converted to 220..What are the opinions of the group for someone experienced at turning, but not familiar with the current mid-size to small lathes... Thanks,Rick
Re: small to mid size lathe
>For all practical purposes there isn't any advantage to converting the motor to 220 so both machines will run fine on 110. The biggest difference in the two is the 14" lathe has a mechanical variable speed and the 16 has the Variable frequency Drive. I prefer the VFD. It's much easier to change speeds and you also have reverse.
fredbear34
>The Jet JWL-1642EVS-2 is the 2-HP, 220 volt version of the 1642.
rick pixley
>I like that 1642 evs,220 option..Any idea where it's most reasonable..I didn't see it at Amazon..Thanks,Rick
Tony Latham
>Rick:
I bought my Jet 1642 at Woodcraft and simply love it. At the time, it was on sale with free shipping. Woodcraft has the DVR on sale right now.
One of the criteria I was looking at was footprint. With the Jet, you can slide the head inboard and limit it's footprint to it's bed length. It fits in it's normal shop-spot nicely that way and if I need the full bed length I can drop the home made mobile base and roll it out... I chose the Jet over the DVR partially because of the supplied leg system and glad I did.
TL
robo hippy
>The DVR is a nice lathe, but I prefer the Jet 2hp, 3 phase. Main reason is the sliding headstock. Just a personal preference as my lathe is in a corner, and outboard turning isn't possible. Another point is the dial a speed (Jet) compared to the push a button for 5 preset speeds, and a slow push button creep up or down for the other speeds. Jet has a slower minimum speed (50 rpm) to the 100 for the Nova. I actually want slower for sanding my warped bowls. The Jet can be programmed to go slower, but Jet doesn't like to do it.
robo hippy
Frederick Nelson
>The Laguna 18/47 is a nice choice as well: 2 HP, VFD with reverse, sliding headstock, fairly standard 1-1/4"-8 thread on the headstock, and solidly designed cast-iron legs. The features of the lathe compare favorably to the Jet 1642-EVS-2, but at a lower price. It does require 220 volt service, however, but so does that model of the Jet lathe.
I recently acquired one, but haven't had nearly enough time to become well-acquainted with it and do much turning. I expect that to change as the autumn progresses. I do like what I've seen so far, though.
Fred
Under scattered clouds in Eastern Missouri
The jet 1642 EVS is ... *LINK*
Ed Moore in Sw VA
>an excellent lathe. When buying Jet or Powermatic products I always check with Toolnut. They often have the best prices. I have also found them to be extremely helpful.
Ed
Toolnut
fredbear34
>It seems to be readily available at all the usual places, including Amazon, Sears, Woodcraft, Rockler, as well as others. Look for your best deal. With the usual woodworking shows starting up you may be able to get a good deal if one is going to be on display at a show near you (if you can get a truck and some friends you could save shipping).
>Go to www.toolnut.com and ask for a price. Most of the people in my club have purchased Powermatic or Jet lathes through him and been very satisfied. I did also and had great service and the best price.
I've had the Jet 1642 for a while...
>and I like it a lot. I would also consider the Laguna 18/47 Platinum lathe if you want a larger lathe or the smaller Delta 46-460 if you want smaller.
Re: I've had the Jet 1642 for a while...
Peter Lamb
>You might want to look at the new Delta 46-460. One HP, minimum 250 RPMs and bed extensions available. Around $600. This lathe has been test driven by many and is very well spoken of.
Peter
Dick Hines
Dick Hines
>You may want to check the HP rateing again. The 1642 only has a 2 HP motor.
Scott Hurley in N VA
>Don't get hung up on the 3-phase motor on the Jet. The VFD box on the back converts your household single-phase to the 3-phase for the motor. Otherwise, very few people could buy a 1642 because 3-phase power is generally not available in residential areas. The Jet 1642EVS is the 1.5 horse, 110 volt model, and the 1642EVS-2 is the 2 horse, 220 volt model. Good luck with your search.
Scott
Roger in MO
Roger in MO
>My 1642, purchased last summer, has a 1.5 HP motor,input power 115V/1 phase. The motor runs on 230V/3 phase.
Jet also advertises a 1642, 2 HP, input power 230v/1 phase with the motor running on 230V/3 phase.
I'm well pleased with my lathe but have not turned much yet. Winter is coming.
Roger
Re: The jet 1642 EVS is ...
rick pixley
>I just pulled the trigger on a 2hp (240v)evs jet from Toolnut..They seem fantastic to deal with and were cheapest of all,including liftgate residential shipping,beat Amazon by 125 bucks..Thanks all for the help..BTW, I did not go for the Laguna, based on site reviews, and dealings I've had with them when I purchased my bandsaw, Hope they improve,We'll see..
Rob Wallace
Rob Wallace
>Congratulations Rick - good luck with the machine.
Curious to know what the going price is right now for the Jet 1642-2HP...
I'm sure others here might want to know too...
Cheers,
Rob Wallace
GalenV in Iowa
>Rob,
I just got an electronic Jet flyer and the Jet 1642 EVS 2 hp is $2099.99 a $1021.01 savings they say.
Woodsmith store honored the last Jet flyer and it was free shipping into the store for a 1220 bed extension and stand extension package.
Not sure what policy is on heavier shipments though.
Galen
Rob Wallace
Rob Wallace
>Hi Galen!
I'm not really in the market for a 1642 - I've owned one of these lathes since they first came out (I paid $ 1,600, shipped), and was just wondering what the Toolnut price is at present, since he's reputed to be one of the lowest prices around.
Now if someone had a similarly low price on a Robust American Beauty, then you'd really catch my attention (...and likely my wallet).
Rob
rick pixley
>1974.98..That includes liftgate to the door...
Rob Wallace
Re: The jet 1642 EVS is ... *LINK*
Rob Wallace
>Excellent price Rick! I see why you took the plunge...
Good luck with your machine when it gets there - have someone around to help get it off the pallet and assembled. I assembled mine alone with some pretty good ingenuity, but it would have been helpful to have a few extra hands around when assembling the bed to the legs and to place the headstock on the ways.
You might want to have a read of the thread on uncrating a Jet 1642 from the AAW Forum, and consider tuning-up and prepping the lathe as you assemble it (see my comments in the thread).
This is an excellent machine - you will enjoy it! Turn safely!
Cheers,
Rob Wallace
Jet 1642 Uncrating Thread from AAW Forum
