>I bought a moisture meter last week to help determine when it is time for final turning and finishing of lidded boxes and maybe bowls. As I started to play with it, I realized that I have no idea what the moisture content should be. Anybody got an idea? Thanks.
Where will your turnings be living? What is the RH there? Wood equilibrates to a Moisture Content (MC) that is about 1/5 that of the surrounding air.
So, if your turning will be in area where the RH is 40% then your turning should be an MC about 8%.
Keep in mind that the MC will always be changing unless the turning is in a very stable environment. So, If your summer RH is fifty percent and the winter one is 20% then the turning will gradually change from about 12% to maybe 4 or 5%. This is why you want to let the wood equilibrate in the space where it will be living and why it is important to use similar or identical wood species for various parts of turnings. If the wood of the top and box are from the same blank and the grain is aligned, there is a good chance they will move equally and the fit will remain fairly constant. If they are of very different woods or wood oriented in different directions then the fit will likely change and in some cases cause the lid to be jambed on tight or perhaps to fall off easily.
>I was having that conversation yesterday with a very high end woodworker. Here in Tennessee he thinks it should be around 12%. It will get around 8% sometimes in the winter and up to 15% in the summer but that depends entirely on your heating and cooling system and how much you leave the windows open.
I've seen a chart showing the average MC all over the US. You should be able to find that by doing a google search.
>With your meter, test the doors, jambs, furniture, and cabinetry in your house. Differing species read differing MC, but you'll get an average that will work just fine.
(A trip to the lumber yard with your meter can be an education!)
>You don't need to know the actual moisture content at any given point in time. It doesn't matter what the meter reads or what it should read. It only matters that it reads something, and that the reading drops as the wood dries.
Monitor the falling moisture content and when it quits dropping over the course of a couple weeks or so, you are at equilibrium. There will be no more loss of moisture until there is a change in the atmosphere.
>I've had good success with 9 to 10 percent in air dried walnut and cherry for flat work. About the same for bowls. Boxes however may require less moisture. I don't like to use air dried material for friction fit lids.
Measuring the weight as suggested will be more accurate.
