ebonizing oak
ebonizing oak
ebonizing oak
Brian George
>I have some 1/2" oak boards that I want to ebonize. If I do both faces will the ebonizing go all the way through the wood? I will laminate the 1/2" boards onto hard maple after ebonizing and turn a pepper mill.
Re: ebonizing oak
Re: ebonizing oak
>Ebonizing and or Dyeing only goes skin deep. It does not penetrate far enough to turn through. I would suggest turning the pepper mill and then ebonizing it.
Re: ebonizing oak
Re: ebonizing oak
Brian George
>I've thought of that, but the problem seems to be that the maple would be ebonized as well, right?
Re: ebonizing oak
Re: ebonizing oak
Chet Gelnett
>You can always use a sanding sealer on the side you do not want the ebonizing on. That helps but really that is only needed when the wood is thin, like John said it normally only goes skin deep.
Re: ebonizing oak
Mike Mills
Re: ebonizing oak
Mike Mills
>It will not ebonize it; however, you make want to try an old woodworker�s method.
Test it on some small samples first. I do not think maple will react like oak, which is high in tannic acid. Take a small dish and pour some ammonia in it, elevate the pieces above the ammonia and cover tightly (saran wrap, etc). The oak will darken a LOT. If the maple does not darken, make your project and sand to completion, fume the item, then apply your finish.
You can look up �fuming oak� online.
Mike
Re: ebonizing oak
Re: ebonizing oak
Brian George
>Thanks for all the input.
I had never herd of fuming until now.
Thanks, again
Re: ebonizing oak
Rob Wallace
Re: ebonizing oak *LINK*
Rob Wallace
>If you are experimenting with post-turning coloration, you may want to try painting the oak parts of your glued-up turning with ferric acetate ['iron' acetate] which will darken ('ebonize') the high tannic acid content oak much more than ammonia fuming will. (Very different chemical reaction.) Although it will raise the grain a bit because this is an aqueous solution, the dark coloration will penetrate deeper into the wood than fuming will; you can simply sand-off the 'fuzzies' when dry, and proceed with your surface finish.
You can make ferric acetate by taking distilled vinegar (use 'clear vinegar; don't spend the extra money on cider or wine vinegar) and add steel wool or iron nails to the vinegar in a glass jar and allow it to react for a few days (room temperature). There should be a yellowish coloration to the solution when reacted. Filter the solution through a paper towel or coffee filter, and test the reaction on scrap pieces of oak and maple to make sure the reaction is working and the solution is OK. Hopefully you will find that the maple is not effected very much by this solution (although as someone mentioned you can seal the maple parts with shellac before treating the oak); I might be a bit concerned with imparting a yellowish hue to the maple, which should be tested.
Have of a read of the 'ebonizing' thread below from the AAW Forum.
Good luck,
Rob Wallace
Ebonizing thread from AAW Forum
Re: ebonizing oak
Re: ebonizing oak
Russ Fairfield
>Ebonizing won't penetrate through 1/16" veneer from both sides, so there is no way it will penetrate 1/2".
I used the iron filings and vinegar solutions for ebonizing, but I was never satisfied with the result. The vinegar raised the grain, and that required sanding, which went through the grain, which required doing it again, and again until the grain raising was minimal.
Black shoe dye or an alcohol soluble black aualine dye is a much better way to get black wood. Either one will penetrate deeper than the ebonizing solution, and the solvents won't raise the grain.
Re: ebonizing oak
Re: ebonizing oak,use India ink
gary clarke
Re: ebonizing oak
Re: ebonizing oak
Jorge Castaneda~Downeast Maine
>Russ,
A long time ago I was a boatbuilder, and some times a fisherman. In both trades we used to boil green red oak to be able to bend it, the result is the oak gets black all the way through, but when it dries it is not really black, is some shade of dark gray, and in a few days it is really dry, comparing some wood of the same stock that was not boiled to the ones that were was quite a surprise for me.
Maybe is worth giving it a try.
$0.02
Jorge
Re: ebonizing oak
Re: ebonizing oak
Brian George
>Again, I say thank you to all of the suggestions. I did some reading on the fuming process and it seems doable. Maybe the India ink idea would work, also. I really appreciate all the input...
Re: ebonizing oak
Re: ebonizing oak
Brian George
>Black shoe dye - now that's worth a try on a sample piece of oak and then turn it down to see how far it penetrated. I"m going to try that. Thnk you for the suggestion...
