>I need to wet-sand a burial urn which is finished with lacquer. What is the best lubricant for this job? Would a soft wax like Mylands or Bri-Wax work? Mineral oil?
Please help the dummy.
I am aware of the hazards of sanding too aggressively.
I googled for an answer and got some answers that I really didn't want involving personal lubricants. Oh boy! ;^)
>I'd use water and really fine paper. Some beautiful car finishes are done with lacquer. Should work on your urn too. After sanding you could rub the finish with red compound followed by white compound. If you have enough lacquer you should wind up with a finish that looks like you could dive into it.
>HI Ed, Water with a few drops of dishwashing detergent works well. You will need sufficient coats built up so that any sanding through thin spots won't hit bare wood. Lacquer melts into the layer below each new coat, so it won't matter if one layer is exposed when sanding...a serious lacquer finish will involve 15-20 coats, wetsanded between the last five or so coats. Buff with automotive compounds, in progressively finer grits.
>If I'm doing it in the house watching TV I use a spray bottle with water. If I'm doing in the shop I use the Murpy's oil. It seems to stay in the sandpaper longer.
>I use mineral spirits to wet sand turnings. I usually have a concern about the quality of the finish on the bottom, and the corner where the sides and bottom meet. I just don't get a heavy lacquer build there, and I don't want any water getting under the lacquer. I wear gloves to do this.
>It's a buffing compound you can get through Don. ( Don is a major sponsor of WC) I've got some coming and can't wait. I have turnings with a lacquer finish just waiting to get shined up.
>"PL" is for buffing plastics/acrylics and high build finishes like lacquers, polyurethanes, varnishes, and others.
The use of lower rpms (700-900) and the "PL" compound keeps the heat built up in the finish very low. Heat from buffing with white diamond, tripole, and other compounds and will put unnecessary heat into the finish. Although buffing with white diamond and tripoli can be done, you will, in addition to adding heat, remove more finish than is necessary and chance buffing through the finish. You might call this rubbing out the finish the quick and easy way as it works gentlely but quickly. This compound with an all flannel buffing wheel is awesome and a great tool for the job.
You're going to love the PC buffing compound. Don was just introducing it at this year's Desert Woodturning Roundup when I scored a complete buffing set up from him. ("Scored" meaning I paid him his DWR special price.) It's worked very well for me. It's great for film finishes, such as lacquer and CA. It's also great for plastics, like acrylic pens.
