>I've got the lathe running again, and the reeves drive is holding just fine. I am curious about whether or not dismantling and reassembling it all may have thrown off the speed a bit.
There's no digital output, just the metal plate with the range from 600 - 3600 on it. I'm pretty sure some adjustments can be made to tweek the speed a little, but my question is this: how can I tell how fast it is actually spinning?
>I bought an inexpensive digital tachometer a while ago (via eBay); seems to function just fine. - I was thinking of trying to jury-rig something to measure the speed of my lathes (...as a ham radio operator, I tend to often try to re-engineer something I've 'found' to work for my needs, either to save money or to just say I did it...), or try to calibrate a xenon strobe, etc. just to check relative rotational speeds at each pulley setting.
I figured if I payed myself to do this and "tinker about" it would be FAR cheaper to just buy the photo instrument and be done; saves time for actual woodturning!. My tach came with some reflective tape that you apply to the rotating piece. Works pretty well and is accurate enough for checking ballpark lathe speeds.
>I can't answer your question either but I just turn at whatever speed is comfortable. My lathe has a readout but it's on the back side and just reads frequency so have to use a chart to interpolate. I never do that.
I've also done demos on a lathe like that and again, I just crank the speed up or down until it feels right and start turning.
>I have an older lathe with a Reeves drive, and I rarely use it at anything other than the 2 speeds - as slow as it will go, and as as fast as it will go.
You can get the maximum and minimum speeds from the data plate or calculating them by measuring the pulley diameters over the belt at the extremes. Everything else between the extremes is approximately proportional to the handle location. This isn't 100% accurate, but it is close enough.
I may play with the calculations like Russ states below to compare, but I really don't want to deal with getting the headstock positioned so I have access again.
I've handled that thing enough for this half-century.
Go to any bicycle shop and pick up a bike speedometer.
Just make sure it is one that will allow you to adjust for the size wheel (handwheel) you will have on your lathe. You have to attach a magnet (included with the speedometer) to the handwheel, the display and pickup are then mounted on the head of lathe.
I had one years ago on a 1956 Delta and it worked expremely well. I had converted that lathe to variable speed.
>As far as lathe speeds go you only need to understand two. If the wood is not turning you are way to slow. If the lathe is danceing all over your shop the speed is to fast. You need to be some where in between.
>When I was on the farm, we had a gauge with a rubber tip on the end. You held the tip of the gauge to the spindle (center of the pulley) and it would read out, in analog, RPM's. Don't think I brought it with me when we moved to town, but you should be able to find something at a Farm & Fleet or Tractor Supply.
>We had a mechanical dial speed indicator. The shaft that rotated with the pulley was geared to a dial. You applied the tip for a given amount of time say 15 seconds or 30 or a minute and read the dial to see how many revolutions had occured in that period of time. This was about 1953. We used it to set the speed of the cylinder in the combine. I still have the tool.
>Used to be a disk chart to calibrate phonograph turntable speeds. It had a couple of rings with alternating black and white blocks. When used with an incadescent light (with 60 cycle alternating current), the pattern would stand still.
Can't remember how I did it, but I made up one to check speed of shop equipment. Number of blocks per ring was some multiple of 60 and the desired speed. Mebbe someone else can chime in. Should be easy to put the disk chart on a faceplate and use with a light bulb for a cheapie strobe.
>If you know the speed of the motor (ie. 1725 RPM)turning it by hand one revolution and watching the chuck rotation (1/2 turn or 1 1/4 turn), you can multiply the input (1725 RPM) by the output (1/2 turn = 0.5) and get close the your turning speed. 1725 x .5 = 862 RPM. If you can't tell 2/5 from 1/3 turn the input more revs, 5 or 10, count the output and do the math. This should be close.
>I don't see your fasination with the speed the lathe is runing. I have a PM 3520A and I have never looked up the digital readout to get the spindle speed. In the turning I do I don't really care what the spindle speed is. If I am turning something small the speed is higher than when I turn something big and off balance.
I it could be said that I turn by the "if it feels good, do it" rule.
>I had to take the headstock almost completely apart to replace the belt, and after I did, the first piece I turned made the lathe dance even after it was rounded. I did not think it was that out of balance...thought I had turned worse on it in the past without much vibration.
This made me curious if there was some adjustment I had unintentionally made that resulted in the low end speed being higher than it was before.
The only way I could turn it w/o having to waltz with it was to take heavy cuts to slow it down a bit.
