Best Wood For Threading
Barbara Gill, Remlik VA
>No, not boxes. I have had a Beall tap to thread wood to go on my spindle for at least a year. Now I am ready to use it and started wondering the best wood to use. I would think there would be a balance between too hard and too soft. I am at the store so I cannot check the article on making the vacuum chucks that was in the AAW Journal right now.
Re: Best Wood For Threading
Cyril Griesbach
>Barb, I've made a number of face plates from Mahogany with my Beall tap for a variety of uses including vac chucks with no problems. After drilling the hole I applied thin CA to the walls before tapping to stiffen the wood and all has been well with them. I used the Mahogany because it's what I happened to have plenty of at the time and glued it up to get the thickness I wanted.
Allan Batty says that ...
Ed Moore of SW VA
>a dense hardwood is best for chasing threads. Then I think he said English Boxwood and African Blackwood were excellent. Lignum Vitae is apparently very good for threads. I would avoid any wood that is regarded as "chippy".
On his DVD Allan warns against open grained woods such as oak and ash.
Ed
Don Orr
>I have tapped Maple, Oak, Ash, and even MDF with my Beall tap. A little wax or oil helps a bit.
Re: Best Wood For Threading *LINK*
Doc Green
>Barbara, there was a fairly long thread on using the Beall spindle tap on 17 June 09. Try this link.
Thread on Beall Spindle Tap
Re: Allan Batty says that ...
>Thanks but I am not chasing threads.
Thanks Cyril.
Thanks Don
Thanks Doc
>I missed that thread completely.
>I've been doing threading demos lately and one of the things I demo is the beal tap. Most harder woods that I've tried so far tap well. I'm still kind of new with the tool and haven't done a lot but it seems like the woods that carve well, tap well. I have used common metal taps for cutting threads for a lot of years for making jigs and such. With these the good woods were always something like Maple,Cherry, or woods that don't have large pores or weak grain. I did some MDF the other day and it cut cleanly but I would assume the threads would be weak. Like was mentioned above, wax helps a lot both in making it cut easier and leaving clean threads. If I want a stronger thread I cut the thread and then use thin CA, then recut the thread.
Fred W Holder
>Hello Barbara,
I've been making threads in wood every since I first started turning some 20 plus years ago. A tap such as the Beall works pretty good in any of the hardwoods if you use a flat board with the grain running perpendicular to the hole in the wood. I've even chased threads in pine when the grain was running perpendicular to the axis of rotation. This way half of the threaded wood is end grain and half is side grain.
I recommend liberally coating the surface to be threaded with a soft wax such Kerf's Wood Creme, which I use, but I believe that any soft wax will work. I saw Michael Mocha chase threads in maple using dishwashing liquid as the lubricant.
I don't think it will make much difference what wood you use with the Beall Tap, but do make the grain run perpendicular to the threaded hole.
More Woodturning Web Page
Doug Turner
>Barbara,
For vacuum chuck I use Tex decking planks which contain a plastic binder. The you don't have to seal the threads, edges or faces. For small faceplated I use free wood from pallets such as oak, maple, poplar, hickory. They all work great.
Steve Kubien
Steve Kubien
>I've been using some hackberry that was too bland to even use as fire wood. It works well as it it is not too hard but is still strong enough.
Thanks So Much For All The Help. :-)
david
>Barbara: When I got my vacuum chuck from Johnny Tolly, he advocated stacking and glueing together MDF sheets. Making the threads was fairly easy if you used the correct sized pilot hole, which I believe was close to 1/8" less than the tap diameter. After threading, he used thin CA glue to harden the threads. You need to run the tap through after to insure the threads were clear of CA build-up. This works fairly well and the MDF is pretty easy to shape and turn. If used for a vacuum chuck, however, you need to seal the hole very well to prevent air leaks. Fortunately I was able to transfer everything on the vacuum setup when I went from Nova 3000 to Vicmarc. Everything except the all-thread lamp tube on the EZ Vacuum spindle, which required a different length shaft.
Thanks David
Jorge Castaneda~Downeast Maine
>Hi Barbara,
Better late than never.
In my college days, I had to write a paper on lubrication on 2 different factories, by luck both were textile mills, one running on electricity, the other from the shaft of a waterwheel.
In the mill with electricity, there was much clanging and screeching, everything was metal and needed constant attention to lubricate. Very noisy and stressful.
The waterwheel mill on the other hand was extremely quiet, most of the moving parts where made of wood, a much older mill, although most of the pieces of the looms were oak, for the places where there was friction the woods where rock maple, african black wood, persimmon and cocobolo and osage orange for the pulleys, with lingam vitae hubs, there was other woods that I don't remember.
Lubrication needed was virtually zero as the woods were dense and oily, and in certain spots a dab of tallow. Many pieces had treads, the small diameters had brass nuts, the large diameters were wood also.
That was in another life time...
Hope this helps
Jorge
