ADVERTISE HERE - FREE TRIAL
I can't believe I did it
Roger in MO
Roger in MO
>About six weeks ago I requested comments on a 14" jet. Most of the advice was to go for the 1642 for size and reversibility. I ended up buying the 1.5 hp model. I bought an adaptor to fit my 1-10 chucks.
I want to thank you folks for sharing your expertise.
I modified my shop to accomodate the larger lathe and to improve the layout. Photo attached.
Also attached are photos of the first bowl from this lathe. Cherry, 2 3/4 x 8 3/4. Wall thickness between 3/8 and 1/2. The cherry had been cut about 2 years and sawed to a turning blank about a year ago. All surfaces sealed and stored in a closed building w/o heat. Moisture content checked at about 12% when hollowed about 1 1/2" deep. Turned complete yesterday and today. Mineral oil finish. Sorry for the quality of the photos.
Re: I can't believe I did it
Roger in MO
Roger in MO
>photo of bowl
Roger in MO
Roger in MO
>Bowl photo
Mike Hamilton
>I just love mine. Was limited to 110vac and this always seemed the nicest option. Bottom feeder in me laid in wait for over a year for the perfect sale. No regrets! Enoy - and nice bowl.
Regards,
Mike
WayneLeach - NW Ont
>Roger,
Congrats on the new machine-I am very envious as I only have a Jet mini and an old Rockwell. One of these days I will bite the bullet.
Love the cherry bowl and I bet you liked the smell from turning it.
Hope you enjoy every minute of it.
Wayne
Ken
>WTG,looks like your set for many yrs of fun,fun,fun an more fun.
Steve Kubien
Steve Kubien
>Enjoy yourself, I am sure you will.
Question... Is that a halogen "work" light on the left? Don't you find it brutally hot to work under or are you located in Greenleand? I hate using one for photo's but it is a necessary evil.
Marc Phillips
>Same choice I made... with advice from the same gang!
I couldn't be happier.. great lathe... no regrets at all...
Very nice bowl too...
Barry Turner
>Uh.........that's on the "right" side.........
Lyle Jamieson
Lyle Jamieson
>Since the Jets are the topic I wonder if one of you Jet owners can help me?? I need the tool rest measurments. Would you give me the distance from the top of the tool rest to the bottom of the tool rest post.?? And the measurement from the top of the tool rest to the bottom of the shoulder that would sit on the top of the banjo if the tool rest was at its lowest position in the banjo.
I need these measurments for both the 14 and 16 inch Jets. I appreciate your assistance, thank you very much!! Lyle
Roger in MO
Roger in MO
>It is halogen. And its hot. and its not effective. And its temporary.
Yep I need to get a gooseneck mounted on the headstock or the backboard. But then I will be able to see all the defects! (:>(
Roger
Steve Kubien
Ya but...
Steve Kubien
>I am looking at my monitor through a mirror. Hmmm, you're not buying that are you?
red-faced-in-Ajax....
Roger in MO
Roger in MO
>Lyle, 16" jet tool rest measured 6 1/8 overall height. This is measured with the rest laying flat on a bench. The post itself is 2 3/8 long, the difference, 3 3/4, is the height of the rest portion without the post. Hope this helps. Roger
Don Orr
>Believe it.
Enjoy it.
Nice bowl.
Re: Looks like a well organized....
Jamie Donaldson
>...work space Roger, and I'm curious about what appears to be another lower floor level behind the lathe? That sure would give good access for removing all the tons of shavings you will be making around the lathe in the future! (:-D)
keith zimmerman, Normal IL
>Congratulations Roger.
Your photo of the lathe set up in your shop has given me the answer to a quandry I have had since I built the bench for my new Delta. I have serious storage issues about where to put my drives and measuring tools, and seeing your backing board gives me the solution. There will be a backing board mounted on my bench so I can mount some shelves.
Thanks.
keithz
Roger in MO
Roger in MO
>Jamie, the photo is deceiving. My shop was originally built as a weekend vacation apartment with the intent to convert it to a shop when we moved to the farm. The backer board behind the lathe covers a sliding glass patio door. I later added an unheated enclosed leanto over the original patio. The floor is about 3" lower than the shop floor and is showing in the photo.
I usually let the chips accumulate and walk on them as a cushion, easing the leg pain. They also provide insulation from the concrete/tile floor in the winter. But with this lathe I expect to turn more green wood and will need to get rid of the wet chips.
Roger
Lyle Jamieson
Thanks Roger
Lyle Jamieson
>That is exactly what I needed, Thanks!! Lyle
