Hey Keith Z -- Look at what I did
Paul Kramer
>All,
While at the last Indy-Fest Keith Zimmerman helped me with my first bowl (down there on the left). I'd never done anything like it before so I needed help with prepping the wood, mounting it, tool technique, etc. Keith is a very generous fellow with his time and talent. So, I got home with a roughed out piece from bradford pear with instructions on how to complete it. It has been in a paper bag full of the shavings for a long time.
I finally got around to finishing it recently. As it turned out the piece had distorted so much that in trying to true up the outside I was going all the way through the side. I decided that it wasn't to be so.
Using the knowledge I had gained I mounted and turned the other piece on the right out of bradford pear. You'll note that the wall thickness on that one isn't quite even either. The wood wasn't as dry as I thought it was. And if that weren't enough, I got a catch as I was finishing the bottom so to clean that up I ended up with a bowl that rocks around a little. It's just my first.
