How To: Spiral Flame Finial - Charles Neil Vids *LINK*
charlie belden
>Though most of his YouTube videos are about furniture making, he has three videos of his start to finish process for making a furniture sized "flame finial" which can be applied to smaller finials. He comes at things in a practical/praqmatic way and describes what he's doing in a simple, straightforeward, easy to understand way. Each video is about 9 minutes long, so it's about half an hour of pretty useful information.
I've seen three or four other How To approaches to doing spiral finials. This one's the easiest to understand - and remember - for me. Your mileage may vary.
Three Part Series On Making A Flame Finial
Re: How To: Spiral Flame Finial - Charles Neil Vids *LINK*
Roger in MO
Roger in MO
>Interesting video. Some of the older woodworking texts such as Herman Hjorth's Principles of Woodworking (Bruce Publishing, copyright 1930 and 1946) show essentially the same proceedure.
I built an ashtray stand with a tapered double twist from Phillipine Mahogany (back in 1958). Even that soft wood required many hours of filing and sanding.
Thanks for posting.
Roger
charlie belden
>The control points layout is a lot easier if you have some way of indexing the headstock end.
Set the tool rest height to the centerline of the lathe's turning axis and use it to draw a reference line along the piece. Align the zero degrees mark on the indexing head to this line, rotate 90 degrees, use the tool rest to draw a line down the piece, rotate another 90 degrees draw a line and do it again. Much quicker, and no dividing the measured circumference at two points each by Pi, dividing by 4 etc..
The use of narrow masking tape to layout the spirals is a nice useable trick, as is the tape on the saw blade for the depth of cut.
I think I'd look into a Legacy set up if I was going to do longer spiral pieces. Turn a crank and let the gearing and router do most of the work.
After seeing what's involved, my respect for Mr. Hunter's and Mr. Fennell's spiral hollow forms has gone up several more notches.
