Re: OT- Digital Cameras
DavidWalser
>Are you married to the Canon or would you be willing to consider another brand of DSLR? If so, take a look at the new Pentax K-7. It may be more money than you plan on spending, but it has been getting very good reviews and packs a lot of features for its price. Some of the advantages of the K-7 (and the cheaper K20D and K10D models that the K-7 replaces) include in-body image stabilization and extensive weather sealing. The advantage of in-body image stabilization is that virtually every lens that you can mount on the body has the benefit of image stabilization. The advantage of the extra weather sealing is you can use the camera in the rain or in dusty conditions without fear you'll damage the body. (Pentax is now making weather sealed lens, too. Otherwise, rain and dust are still the enemies of your lenses.) Another advantage of the Pentax system is that the DSLR bodies are compatible with virtually every lens Pentax has ever made (or others have made for the Pentax mount). There's a lot of high quality Pentax lens that are available on the used market.
As to your question about which lens to get. I have the Tamron 18-250 mounted on my K10D and love it. The lens has some vignetting at the extreme short end of its range when wide open, but it is decently sharp and is very versatile. Sometimes I wish I had a wider or longer lens mounted on my camera, but not often. If you haven't done so already, check out the reviews at slrgear.com Tamron's newer lens, the 18-270, is supposed to be even better. It's supposedly sharper than the Nikon 18-200 through most of the focal range. The Canon is slightly sharper than the Tamron at 200mm.
Good luck!
