>I am finally getting ready to turn some pens. I read conflicting advice as to using epoxy or CA to glue the tube into the wood. I tried to find this subject in the achives, but couldn't. Hate to have a rerun, but, which is supposedly the "right" adhesive to use?TIA. Nick in HOT So Cal
>I use Meedium CA. Before applying the glue, I put the tube in an electric drill and turn it on to rotate the tube against either 150 or 180 sandpaper, whichever is handy, to scratch the surface, then apply beads of medium CA and rotate the tube by hand while inserting it into the pen blank. T
>Nick, on the one (1) pen I've made, I used 5-minute epoxy and it seemed to work OK. Medium CA is often recommended, but I was afraid it would set up and "grab" before I got the tubes into the wood. ~Doc
>Nick, I don't use either CA or epoxy. Instead I use polyurethane glue like Gorilla glue. I think epoxy is too messy and I'm always concerned that the CA will set up before the tube is pushed all the way in. With the polyurethane glue, the only downside, is waiting over night for the glue to cure.
Since PU glue likes a moist environment to cure, I'll often run water through the hole in the wood before applying the glue. The glue foams up and fills any and all voids. I have never had a failure using this glue.
BTW, there are other PU glues that are less expensive than Gorilla glue and work just as well. I buy in small quantities since I make very few pens anymore and the glue hardens in the container after being opened.
>I use epoxy or Gorilla glue. I can not get a good enough spread on CA hold fragile blanks. I've seen the most failures when I used CA, so no more. To sand the tubes, I bought a cheap 80 grit 3" dia flap sander at Menards and put it in the drill press. I can sand off a dozen tubes in a minute. The epoxy really grips to that sanding.
I use flexible CA. The flex gives under conditions that CA might otherwise break/shear.
I also use the potato method with the pen tubes. I get much better glue adhesion and coverage. I do this by using a 1/4" slice of fresh potato take the tube and stick it into the potato like a cookie cutter. This plugs the pen tube. I then slop glue down the hole in the blank, and all over the tube. I end up with a little extra glue drip out the end But when I pop the potato out and trim my ends I end up with a well glued blank. I passed this on to Kip Christensen many years back and it is mentioned in his book and videos. Wax can also be used for this.
>...on how many I am doing and how much time I have. If time is short, I use 5 min epoxy (and give it around 30 minutes). If I have a large quantity and time on my side, polyurethane adhesive like Gorilla Glue. I have had too many failures with med and/or thick CA.
>Like Harry, I prefer using polyurethane glue. I have never had a failure with this glue. CA glue can be too brittle and can actually crack when the pen is dropped. Epoxy can hold the wood so tightly that when temperature extremes are encountered the wood can split when the tube expands or contracts. I think the poly glue retains a little of its foamy structure and cushions the wood against these extremes. I don't have any scientific evidence of this; it is just what I think.
It can be messy however as it foams out each end. To keep the mess out of the tubes I learned a trick on another forum. I use dental wax in the ends of the tube. After sealing the ends by stamping each end into the sheet of wax I can coat the tube with the glue and insert it into the drilled wooden blank. After the glue has cured it is easy to poke out the little discs of wax.
I bought one box of wax sheets for around $15 and I don't think I will ever turn enough pens to use it up.
>Another way to keep the inside of the tubes clean is to invest in a couple of the brass brushes used to clean rifle bores. Available at a reasonable price at most gun stores. They will clean out the glue that sneaks past the dental wax plugs and they don't remove a significant amount of metal.
>A pen mill will remove most but not all of the glue from inside the brass tube. And I don't have a pen mill that fits all of the different sizes of brass tubes that I use.
Some of the larger and more deluxe pen kits don't have standard sized internal diameters. Or at least the pen mills that I have don't have a drill for every internal diameter.
