>Roger, the large point you describe on your live center unscrews and comes off. But, you need something to keep the shaft from turning -- that is what that little rod is for.
If you look on the body of the live center, you will see a hole that goes all the way through when the live center is in a certain position. Put the little rod in this hole, and you can then unscrew the point. :)
>My lathe came with a steel rod about 1/8 dia, maybe 10" long with a >larger dia. rod at the end. How is it used?
>The tailstock live center is heavy duty. It has a large 60 degree (+ >or -) point. Can this point be separated from the bearing/MT portion?
What you have described is a small knock out rod for the point at the middle of the cup center in the live center. In addition to being able to remove (and replace) the point at the cup center (once the large cone is removed, as described above) the replaceable center can be removed by knocking it out through the hole in the taper end of the live center. You would also remove this small point center if you were going to drill through the tailstock into the work; the small center needs to be removed first before the drill or auger is passed through the tailstock. I think this live center will accommodate a 3/8 inch (10 mm) "lamp" auger.
As was mentioned, you can also use it to stop rotation of the center to remove and replace any additional accessories that would thread onto the 3/4" x 10 tpi threading on the live center.
