Using a slip stone
Using a slip stone
Using a slip stone
Marc Phillips
>I just got the slipstones I ordered...
So, the bowl gouge...
I few swipes on the inside, rubbing the slipstone back and forth to remove any burr... then a couple/three swipes on the bevel, keeping the stone in contact (i.e. flat against the bevel) with the tip and heel.
This is what I was able to gather running around the internet...
Is this correct?
Any other tips would sure be appreciated too...
Re: Using a slip stone
Harry in Beautiful Downtown Kulpsville
>Sounds right to me. If you do this regularly, you will keep the tool sharp and minimize trips to the grinder. And that should extend the tool life.
>I do it the other way around but I'm not sure it makes a difference. I hone the bevel first ant then the flute. Probably like cutting tails first or pins first on dovetails.
