THE WOODRAT IS BACK!
Jet 1642 revisited
Jet 1642 revisited
Roger in MO
Jet 1642 revisited
Roger in MO
>First of all, thanks for all the responses. With so many people touting the good points of this lathe and no negatives, I need to take a long look at it.
In my original post I was looking at a 14-42 as someone suggested. My error.
Now for some questions:
The 5/2008 catalogue shows two motor options--115V/1 phase input for 1.5 HP motor or 230V/1 phase for the 2 HP motor. The motor in either case is listed as 230V/3 phase. Is there a built it phase converter?
Both options are reversible, correct?
For a <50' input run, what wire guage is required for each?
My chucks are 1-8 threads. I know that Craft Supply and possibly others offer an adaptor. Do they have any impact on accuracy?
My face plates are also 1-8. I realize I will need to add a set screw to these if I reverse turn or sand.
I plan to go by Woodcraft Thursday when I'm in K.C. to take another look. Thanks again for all the input.
Roger
Re: Jet 1642 revisited
>The 5/2008 catalogue shows two motor options--115V/1 phase input for 1.5 HP motor or 230V/1 phase for the 2 HP motor. The motor in either case is listed as 230V/3 phase. Is there a built it phase converter? - Yes. There is a phase converter or inverter. I typically unplug mine so it won't be stealing power all the time. I also unplug it during thunderstorms.
Both options are reversible, correct? - Yes.
For a <50' input run, what wire gauge is required for each? - I prefer using 12 gauge wire. I don't know about anyone else.
My chucks are 1-8 threads. I know that Craft Supply and possibly others offer an adaptor. Do they have any impact on accuracy? - Depends on the chuck. I have a Stronghold and a Talon. These were originally on my Delta 742. I bought new adapters and switched them over to my Jet 1642. As far as I know, you should be able to switch them. Does it have any impact on accuracy? Possibly - but that depends on your chuck. On the Oneway chucks, the adapter slides out and the whole adapter is replaced. It fits into the chuck. I'm not sure about your chuck.
My face plates are also 1-8. I realize I will need to add a set screw to these if I reverse turn or sand. - Yes. You will get a faceplate with your lathe. If you want more, you will have to either purchase more or adapt them to the 1642 thread pattern.
One other thing...
>if you have 240 V. you may want to consider the Laguna 1847. The price is actually less than the Jet 1642-2 hp.
Spindle Adaptor
Doc Green
>Roger, I use a steel spindle adaptor to step a 1.25 x 8 thread down to 1 x 8 with no problems with runout or anything. Packard Woodworks has them for about $60.
I installed a switch in the line for input power to the lathe so I can turn it off without having to unplug it. A double-pole switch is required for 220V. For 120V, an ordinary light switch will work. Both are available from a home center.
Note: Don't buy what they call "a four-way switch" for switching 220V, which looks similar to the double-pole type. The four-way switch simply reverses the wires and doesn't turn it off.
Good Luck. ~Doc
Re: Spindle Adaptor *LINK*
Bill McWhirter
>I have a steel adapter (1 1/4" to 1") from Penn State. Works fine. Only $19.95.
Would avoid an aluminum adapter.
spindle adapter
Steve Kubien
Re: Spindle Adaptor
Steve Kubien
>I'm with Bill. I too have one of the PSI adapters of the same size. I use it for my Nova Midi chuck. Works great with noticable run-out.
Steve
Scott Hurley in N VA
>By the way - the EVS unit does not play nicely with GFCI circuits. If you get the 110v version make sure it's on a non-GFCI circuit. The first time I turned mine on, I could hear the GFCI click off...
Scott
