>There is not comparison. The 1236 is way down the totem pole from the 1642. The mass,lack of vibration and ease that everything works is way over the smaller Jet. I had the small Delta which was like the Jet. I had a chance to buy one of the 1236's and it wasn't much beefier than my Delta and only vibrated a little less. The 1642 is just a smaller version of the Powermatic 3520 and is just about all the lathe most people need. Granted the VS model is nicer but the single speed version has less to go wrong over the long haul. I used a Nova 3000 single speed lathe for years and it worked great. In my opinion it isn't quite as good as the Jet, although the newer 16/24 Nova is a lot better than my 3000 was.
>There is a 110 volt model. Don't pass up on the VS. The current VS technology is likely the best thing to happen to lathes in the last 25 years. This is GOOD advice I'm giving you. :)
"I'm looking at a 1642 (standard not electronic variable speed drive) as an upgrade to my 12-36 blue model.
I'll appreciate any comments about the 16-42, pro or con. or comparison to the 12-36.
The electronic variable speed model is more than I want to spend. Lack of 230 volt is also a deterrent for that model.
Thanks
RogerinMO"
Roger:
Don't LOOK at the Jet 1642....... ...BUY IT!
This machine is probably the best value for money in a mid-to-large size lathe.... I also upgraded from the 'old blue' Jet 1236 to the 1642-2, and haven't looked back - I'm very pleased with the performance of this machine.
You will want the EVS - I don't think the 1642 comes without it (EVS *IS* standard on the Jet 1642). You can buy the either 1.5 HP (110 V or 220 V) or the 2 HP (220 V only) - the extra 0.5 HP is worth the extra cost (I've turned on both, and own the 2 HP model). Running the machine on 220V is also a good thing to consider.
>I also own a 1642 after many years of turning on a cheap knockoff of the 1236. I love it! Although the GF has taken it over, LOL, there is not much you can not turn on this lathe. I have had 15" logs for various projects mounted and it worked like a charm.
Lots of power and heft make it a joy to turn.
A word of caution, when setting up this lathe have a friend help...
one of the legs fell over onto my leg and made for a painful next day.
>As others have said. All Jet 1642s are EVS. Your choice as to whether or not you get the 1.5 hp 120 V or the 2 hp 240 V.
I've had the 1642 1.5 hp for several years. I've turned many a chair part on it. I really like it. That being said, if you have 240 V available, consider the Laguna Platinum 1847. It is a lot more lathe. If it had been available when I was shopping for my lathe, I'd of really considered it.
>There is a great review of the Jet 1642 by Dominic in the Reviews section of the Articles (left side of the screen).
He was one of the first to purchase one when they first came out, and his review was all it took to convince me. I bought mine right away, also one of the early machines, and I never looked back. I'm really happy with mine, it does everything I could ever need.
>Thank you for mentioning that the 1642 is only available as variable speed - I have looked long and hard at this lathe, and only found it as a variable speed (which is part of what draws me to it), and I was starting to wonder if I was crazy.
>Roger, Heed John Jordans advice.......at the very least try any variable speed lathe before you commit to changing belts....there is no comparison.....Mac
