terrible time sanding NIP
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>This is weird! I've turned most of a straightforward NIP bowl, which sanded and finished perfectly on the outside. But on the inside I'm having a terrible time. The grain runs parallel to the lathe bed; so I'm looking into end grain and it looks like tiny spikes. Even with 60 grit sandpaper it's rough going. On top of that the sides are very thin and they have moved since I started out. NIP is a soft wood; so I'm puzzled. Anybody been there? Any thoughts are welcome.
Re: terrible time sanding NIP
Re: In such situations I saturate....
Jamie Donaldson
>... the parallel fibers with lacquer thinned slightly with acetone, similar to sanding sealer. This stiffens the fibers for cutting or sanding, and is the undercoat for my usual lacquer finish.
>Great idea! I'll try it. Thanks.
Turn it wet
david
>I have best results if the NIP is still wet when turned. Yes, the liquid can fly all over the place, but the wood cuts nicely with less tear-out. On the interior, what produces the best curls is a pulling cut from the center to the rim. Figure on the walls getting thinner with the unavoidable sanding. At least this softwood sands easily.
