Re: Sanding Discs------WebKitFormBoundaryra4+I5BQn
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>First, let me say there is no "bad" sandpaper out there. Each has been carefully designed to meet a need. The problem is that none have been specifically designed for wood turners -- we have to adapt papers designed for other uses.
After a number of years of testing (and several thousand dollars) I have come up with three that work best for me. These are:
Astra Dot from WoodChuckers (only North American source -- call John at 1-800 551-0192)
3M 900DZ Ceramic with a psa backing from The Sanding Glove and Packard Woodworks. The psa backing is a problem as once you take it off the mandrel, dust sticks to the glue and it becomes useless except for hand sanding.. There are conversion pads -- put them on the psa sandpaper disk -- and keep track of them. I keep throwing mine out as I have gotten used to firing used disks in the garbage. Another option is separate pads for each grit, which is rather expensive.
Norton 975 (Dry Ice) -- another ceramic. It is available from Jamestown Distributors (www.jamestowndistributors.com). This is a boating supplies company. Any Norton retailer can order it, but it fairly new and generally available only at the wholesale level (except for Jamestown). It comes in 6 inch disks and you can cut iit with a hole saw in a drill press -- remove the teeth first on a grinder along with the centering bit. That way, you get 2- 3 inch disks for 32 cents and 2- 2 inch disks for 16 cents from each six inch disk.
For inexpensive, good paper, try Rhyno Grit from Industrial Abrasives (www.industrialabasives.com/zencart/. If you get it in sheets (36" x 39" and cut the disks yourself, you can get three inch disks for 10 cents apiece. A number of companies sell it cut into disks -- but you have to pay for the work.
In between, there are a number of very good papers, including Mirka Royal, (Steve Worcester) ASAP Blueflex (Jerry Horne) 255L Hookit Disks (The Sanding Glove) and Premium Green, a ceramic coated paper from Craft Supplies USA. {Packard and others. These are only a few. The list is much longer.
Do you always need the best? No. If I have a good clean piece of wood, I will use one of the best., and it almost makes sanding a pleasure. But, If I am working with CA glue, sanding sealer, shellac or other wood hardners, I will reach for the Rhyno. If I wreck a disk, I don't stop to cry.
------WebKitFormBoundaryra4+I5BQnefYAZbc
