>I'm not getting successful results using a wood tap to make some chucks. I'm using maple and cutting face grain into a pre-drilled 1 1/8 hole for a 1 1/4" finished threaded hole. I find turning the tap and advancing the tailstock quite a challenge so I stepped to the backside of the lathe since my right arm is stronger and use my left to advance the tailstock.
I need to hear some tip/tricks/secrets to those of you who are successful.
>It can sometines be challenging, I agree. I use a pair of vise-grips on the tap, backing off every 1/2 turn or so, and slowly crank the tailstock. It is one of those things, that suddenly become "Now I get it". I put a couple of drops of thin CA on the threaded wood after blowing it out.
>I found a good tap wrench to be the key to success. Disk 3" dia of 3/4" MDF with three spokes about 3" long. Drill 1/2" hole in center, then enlarge slightly with a rasp or file and square the corners a little to give a slip fit.
Keep a little forward pressure on the tap with the tailstock. Use a back-and-forth motion. If the tap becomes hard to turn, clear the chips. Or, put differently, if you don't clear the chips, the tap will become very hard to turn and will probably tear out the threads.
The threaded piece must have a hub or a projection of some sort to butt against a flat bearing surface on the headstock spindle.
I use a tap wrench (or an end wrench that will fit the square part of the tap) on the tap and use the tailstock to help keep it aligned to tap the hole straight. The wood needs to be mounted with the grain perpendicular to the axis of rotation (i.e., bowl fashion).
For a 1"x 8 tpi spindle, I drill a hole that is 1" in diameter to the depth of the un-threaded portion of the lathe spindle and then a 7/8" hole all of the way through the wood, or at least to the depth that the spindle will reach into the tapped hole.
I use the same process for the 1-1/4" x 8 tpi tap. Except I first drill a 1-1/4" hole to the depth of the un-threaded portion of the lathe spindle and then a hole of 1-1/8" all of the way through for the threaded portion.
You do not need to use the tail stock live center to push the tap into the wood, its purpose is to help you keep the hole perpendicular to the face of the wood being tapped. I simply advance it occasionally to make sure the tap is running true.
The Beall Spindle taps work very well and helps to make an excellent mounting to glue to a bowl blank or a hollow form blank or wooden faceplates.
Incidentally, I always flood the threads with thin CA glue and run the tap through again after the glue has set. This just provides better support for the threads.
>I found MDF to be easy to tap, but the drawback was loss of pressure on the vacuum because the MDF was relatively porous. Flooding the threads with thin CA glue is a necessity, both to harden the threads and to keep the air leakage to a minimum.
Consider locking the tailstock quill but do not lock the tailstock to the lathe bed. Push the tailstock toward the spindle with one hand while turning the tap with other hand. Should give you a nice smooth feed and hold the tap approximately concentric with the hole. It doesn't have to be perfect.
>I set the lathe rpm to 60 or less and push the entire tailstock toward the rotating wood. The tap is in a large tap wrench or 12" adjustable wrench and is guided by a center in the tailstock quill. If the tap is small enough, I just put it in a 3/4" chuck in the tailstock.
