Quick poll: # tool rests used?
Thad
>How many different tool rests do you use on a regular/frequent basis, and what type/style?
I know this will vary based on several variables, but I'd really appreciate your feedback.
Thanks,
~ Thad
Thad
Thanks,
~ Thad
Re: Quick poll: # tool rests used?
Lan Brady
>Good question Thad,
I only use 2.
One is the factory 14" cast iron.
Great for spindle and deeper hollowing
The other is a home made 4" of plate steel.
I like it best becasue the sound changes when a bowl/vessel is getting really thin.
Lan
Barbara Gill, Remlik VA
>Oneway- one inboard, one outboard. Modular with several lengths tool rests and one curved rest for the inside of bowls.
Mark Wollschlager
>I generally use 5
Stock cast iron short and long.
A drill rod 4", 8", and a curved bowl rest
Mark
Wally Dickerman in Arizona
>I regularly use 2 toolrests. A 9 inch and 4 inch Robust. For longer spindles I use my 14 inch Oneway.
I do have a special toolrest that I use when hollowing with my Stewart tool. It's an offset Delta that I've modified.
Wally
Gil Jones...Ga
>PM3520B:
The 12" OEM cast-iron rest, and RH OEM cast-iron bowl rest.
Plus, a 9" and 6" Robust Comfort rest, which I SERIOUSLY like, but wish I had known to wait for the latest version to better fit the PM lathe.
Gil
Jorge Castaneda~Downeast Maine
>Thad,
I use a bunch, 12", 6" and 4" straight, 4" box, 2 exterior for bowls and 2 interior for bowls (small and big). And one for platters that lets me do a face and the edge from one setting. I made most of them.
I own three, use 2 on a regular basis
steve antonucci
>#1 is 12" straight rest that I use almost always.
#2 & #3 are modular system from woodcraft. I have a 4" round bar short rest, which is rarley used, but I suppose would be useful if I needed to get close on something really small. I also have the interior bowl rest, which is useful for deeper bowls, but I'll often just use the flat rest out of laziness.
steve
P.S. I didn't count my mega-rest that I use outboard for platters...
Jeff Willaford
>Two t-bar 6" and 9" rests and one slick curve bowl rest.
keith zimmerman, Normal, IL
>I own several. A 6" round bar is currently the workhorse. I also have homemade rounds in 4" and 8". I use the 4" for finials. I also have the three OEM that came with my Jet mini and my new Delta midi and a 1st generation 6" Woodcraft bar.
I will be shopping for a Robust at Albuquerque.
keithz
Nick Tuzzolino
>Robust 6' and 8"
Marc Phillips
>I have 4...
The original cast iron that came with the Jet 1632, an 8" round, a 2" round that I use for pens when turning between centers, and a Oneway curved bowl rest...
Rick_Allen
>I like to turn platters between 14" and 18" across. The tool rest I use the most for this activity is a 6" oneway tool rest.
The tool rest post offset lets me get the tool rest close to the platter stock. The 6" length is easy to position.
>I switch between 2 for 80 percent of my work. A bestwoodtools 9" offset straight rest and a custom made Robutst 10 3/4" mini tool rest on a 1" tool post. One or the other is almost always on the lathe.
I have a selection of curved rests that I almost never use. They seemed like a good idea at the time, especially for bowls but I find that I just readjust the 14" long powermatic straight rest and just keep on turning without pulling the curved rest out.
I also use the 4" powermatic rest a lot for smaller work but I'm thinking about getting a 4" Robust to replace this one.
Jerry McCaffrey
>Powermatic 3520 stock toolrest(~12") and a modular rest with a 4" crosspiece. Also have an interior bowl rest and usually too lazy to dig it out and put it on.
Jerry
Bill Howatt
>12" comfort most of the time, 4" General, 6" or so homemade are the most commonly used. Curved PSI, curved modular and modular scraper platform are used less frequently.
When I first started turning I seemed to pay more attention to how close the rest was getting to the turning surface of bowls. Now that I am either more experienced or dumber, I am less concerned - I do a lot with just the straight 12" rest.
Regardless of how often you use them, it certainly is handy to have a selection available for the special case.
Bill
Bill Turpin in WNC mountains
>2, 4, 6, 12, 2/4 offset. Adding 1/4" hardened tool steel rod to all of them after buying Robust.
Eduardo sarmiento-hall
>Solid bar 5/8"-12" steel
>Typically two, a short and a long. I do have a box rest that I use upon occasion.
Dick Hines
>I have two. One is the one that came with my PM. I bought one of those curved ones for bowls but don't use it much. I keep forgeting I have it.
I want one of the Robust 4" ones. One day I guess I will get one. Then I can forget I have that one too.
Emmett Manley, Lakeland, TN------WebKitFormBoundar
>I use a Oneway 6 inch rest for 90% of what I do. Also, a Oneway 11 inch rest and a curved bowl rest are used when I remember to set them up. When I first started turning wood, I did not know you could not make your own tool rests so I made a 3" T rest from a piece of osage orange -- that was four years ago and I still use my wooden tool rest for tight places.
Thad
>adding the 1/4" rod to the post to increase post diameter to fit in the banjo?
That seems like a plausible solution to my issue. My rest post measures 1-5/16", and it's the stock one for this 70 year old lathe...the only one I've got. I'm not finding 1-5/16" posts anywhere.
~ Thad
Scott Hurley in N VA
>Three sizes of the Robust tool rests. They're great - never have a problem with the tops getting little pits and gouges.
gtwilkins
>Stock Vicmarc 12" and stock curved rests.
I would like a Robust 6" but it would need a 30mm post to fit the Vicmarc and I don't think they make them.
Trevor
Mark Wollschlager
>The rod is in a groove on the top of the rest to provide a dent resistant smooth surface for the gouge.
You might need a sleeve to increase the diameter of the post.
Mark.
